Computer keeps going to digital power saving mode, mainly when scrolling with the mouse wheel & now when attempting to play a DVD. Have updated to XP series 3 to see if that would help, but it didnt....Help!!
  • 23 Answers
Go into youre computer's Control Pannel and find the Power Save settings. then turn them all off. Hope I helped!
Posted on Jul 07, 2008
My monitor turn on then goes into power saving mode and wont turn on with mouse
Try resetting the power settings.
In Windows, go to Device Manager.
Scroll to the Mouse section and select your device.
Right-Click > Properties > Power Management tab.
Check "Allow this device to wake the computer".
Oct 25, 2016 | Computers & Internet
I have a compaq notebook and the mouse is stuck,how do I unstick it?
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
click start control panel administration tools computer management device manager scroll to mouse you might see a yellow exclamation or question mark ! ? or red x you will need to update driver right click to update driver
if your computer came with a motherboard disk the drivers could be on it
hope it helps
Mar 04, 2012 | Compaq Computers & Internet
My computer wont recognize new wireless mouse
Make sure the batteries are inserted correctly and have charge
make sure the usb device is properly inserted
make sure you turn the mouse on depending on type/brand of mouse it will vary it could be a button or switch on top or bottom also you might try safe mode
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer then if your mouse works
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
hope this helps
Nov 20, 2011 | Computers & Internet
My micro innovations PS/2 mouse isn't working
make sure the mouse lead is seated properly and the socket is clean you might have to open up your computer to check the back of the mouse socket for dust and connection status
or you could go into safe mode
restart your computer repeatedly tapping the F8 key to enter safe mode where the only things working will be your mouse and key board allowing you to attempt a repair on your computer
or
resater your computer during the boot up process you will see a certain key to enter set up press and hold that key to enter BIOS scroll to failsafe or optimised defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 11, 2011 | Computers & Internet
My mouse will not work on my sons pc but works on my daughters
you might need to install it and the drivers on your sons computer computer
make sure the lead is securely seated (if applicable)
make sure the usb device is inserted correctly (if applicable)
safe mode restart your computer repeatadely tapping the F8 key while screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer if your mouse is working in safe mode
click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver or you could
restart your computer for a short ammount of time you will see on the screen to press a certain key to enter set up press and hold that key to enter BIOS scroll you can load fail safe or optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps you
Jul 27, 2011 | Computers & Internet
Mousepad wont work then I remove the hardware component from the computer and it ask me to reboot this is done and all of a sudden it works again but then windows says to save the settings it needs to...
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
click start control panel mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp
Hope this helps
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
Jul 16, 2011 | Computers & Internet
Can t get out of digital input power save mode / computer directs me to press any key but theres no power to keyboard / mouse lights up but theres no response
click start control panel,keyboard hardware troublesoot or control panel administrive tools computer managent device manager scroll to keyboard you could see a yellow question mark? right click to install drivers or blow all of the dust out of your keyboard making sure there is no moisture in the airlines dust causes static which can affect all of a computers parts
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
((if applicable))
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 26, 2011 | Dell OptiPlex GX260 PC Desktop
While playing an online game my moniter goes in to the saving mode what can i do
is this a game that requires your mouse? if not move it from time to time to keep this from happening also, right click on your main desktop and click preferences then click screen saver, then click power and you can change it so it never goes into power save mode (can be changed at anytime)
Nov 15, 2010 | Computers & Internet
Power save mode
You have to have a wired mouse mouse to fix it. Purchase a cheap one, or borrow a friends. Reboot the computer and go to the power options to make the changes.
Feb 11, 2009 | HP Pavilion Media Center TV m7680n PC PC...
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
