Question about HP OfficeJet 4215 All-In-One InkJet Printer
Faxing Why is it asking for an "access code" when I go to fax to certain numbers???
How do I receive a fax from my hp officejet 4215 all in one printer
Posted on Jul 25, 2008
LEXMARK Z612 NOT PRINTING THE PAPER(PAGES) COMES OUT WITHOUT ANYTHING
Posted on Jul 18, 2008
We are having issues faxing to one particular number. We think our fax goes through, but spits out a Error 345*. Nothing is sent
fax machines talk to each other before sending data to ensure that the sender/receiver are on the same format and are compatible
for one particular number to be a problem indicates a fax number problem in setting the dialed number area code , dashes etc are all specific
ring the receiving department and ask to confirm that they are having trouble receiving faxes from your number as well
Dec 14, 2016 | HP Office Equipment & Supplies
When faxing certain out of state numbers it shows wait in Job status then says TX Failure. Not sure how to get out of wait mode?
Is a long distance code required? Is there a problem on the other end? If not, you can reset fax board by entering */1 mode and initializing 100/102/103. If this is performed, fax settings will return to factory default. If problem persists, certain VOIP settings will need to be changed.
Oct 02, 2014 | Toshiba E-Studio 4540c Copy/print/scan/fax
Trying to send a fax--it rings and rings, but never connects.
Are you certain you are faxing to a valid number. First verify by using another number that is a known working number and ask if it is ringing on the reception fax.
Feb 15, 2011 | Samsung CLX 3160fn All-In-One Printer
Faxing with a long distance code
after you dial the number you hit the pause button (usually 1-2 times) then dial additional numbers.
basically everytime you need the machine to wait for something to happen you need to hit pause
example: i have to dial five digit access code for my fax for LD calls it would be dialed on fax like this
1-234-567-8901 pause pause 12345 start
May 04, 2009 | Brother IntelliFAX 1170 Plain Paper...
FL511'S Faxes using Quick Scan
Search thru your menus to make sure GROUP DIALING and CHAIN DIALING are not enabled.
Sep 24, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
Broadcast Faxing with a Access Code
I contacted the Brother web site and they said it can be done, but has to be done using the speed dial feature.
Jul 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Faxing
Call the operator to find out the country code and the city code. I believe the overseas access code for Canada is 011, but you'll have to check with the operator
Feb 20, 2008 | Panasonic Panafax UF-890 Plain Paper Laser...
FAX
same as faxing any other document just put in prefix of the phone number you are faxing to 1 and then area code then the rest of the phone number.
Oct 31, 2007 | Canon imageCLASS D780 All-In-One Laser...
Finding a fax confirmation in memory
you can get a prinout of last certain faxes received or sent(appx 20), if the number is among them, it's your luck happy faxing omnipresent
Sep 20, 2007 | Brother MFC-8220 Fax
HP OfficeJet 4215 All-In-One InkJet Printer Logo
116 people viewed this question
Ben Johnson
