Question about HP Pavilion dv6000z Notebook
Computer to computer
My laptop has a brokein screen im trying to run it to my monitor but nothing shows up i dont know what keys to hit
  • jimco4 Jul 06, 2008
    its not working the fu/f4 key what else could i do ?
    Guru:
  • 859 Answers
To activate your external monitor you use the Fn key + the F key that has the monitor image on it. Its usually a rectangle with a vertical line on either side. Your press and hold the Fn key and then tap the F key with the monitor image in the same color as the Fn key.
Too confusing? Ask for more info or a specific clarification by using the comment box below.
Regards,
Worldvet
Posted on Jul 06, 2008
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jul 07, 2008
    You can reboot your laptop and while it is just restarting press F10 to access the setup screens. If you can see this on your external monitor this part is working. Laptops are designed to automatically recognize an external monitor and mirror your laptop's screen. Lets hope you see those screens. Otherwise, you have more wrong While in the setup screens (and these vary from model to model) look for the command to use the external monitor, since your Fn+F4 sequence isn't working for you.
    Most laptops are designed to recognize that an external monitor has been connected and will automatically enable this connection. If your laptop is not doing this something more than your screen has been broken.
    Here is the contact information for HP.
    And would you please just remove any rating, as I don't try anything. I'm here to fix problems and fixing a problem using Email is a Process. There is no one signal answer that will solve complicated issues like yours. So, please just remove the rating and only rate when we've been either extremely helpful or have fixed you issue and lets let his process run its course.
  • Glenn Rogers
    Contact info for HP:
    You can find all the contact points on this page.
    Can you tell use what happened to your laptop to break the screen?
    Thanks,
    Worldvet
  • Glenn Rogers
    Glenn Rogers Jul 17, 2008
    Did you change this rating from helpful to thanks for trying? We've had some trouble with people changing these and screwing up everyone's ratings. I recall looking these over this morning and it was Helpful.
    Can you help?
    Thanks,
    Worldvet
I have an hp pavilion dv9815nr notebook pc. My laptop turns on, but when I enter the first letter of my password the screen goes black. Computer sound like it is still running but just black screen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 30, 2012 | HP Pavilion dv9815nr Laptop
My hp pavilion dv6000 laptop comes on but my screen and keyboard dont please
May 29, 2012 | HP Computers & Internet
I have a XPS M1530 the screen is black I press the power button for a second it stay on everything lights up sounds and feels like its on gets warm but nothing on the screen Itrying everything taking out...
You either have a Video Card problem or an issue with your LCD Screen.
Does it every post anything to the screen? If nothing ever posts on the screen when you hit the power button and it will not do anything with an external monitor, then your Video Card is bad. I wonder if you have the Nvidia Graphics Video card on your system?
If it seems like the laptop booted up all the way (you hear fans running, hard drive spinning, see lights) but the screen is black then try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
May 16, 2012 | Dell Computers & Internet
Laptop screen wont turn on
If the computer seems like it booted up and is running except the screen is black, try the steps below:
May 12, 2012 | Samsung Computers & Internet
My Acer Aspire 5551-2036 wont turn on blue light turns on screen remains black
Does it sound like the laptop booted up except the screen is black? Do you hear the fan running and the hard drive spinning? If so try the steps below.
May 06, 2012 | Computers & Internet
Cannot open my laptop,acer aspire 4720 zo1 series
Totally No Display? Is the laptop running? Do you hear fans running, disk drive spinning and lights? If it seems like the laptop completed the boot process except the screen is black, try this:
Shine a flashlight on the dark screen to see ifyou barely see the icons on the desktop. If so, then the LCD Inverter isbad.
Apr 19, 2012 | Computers & Internet
Blank screen
Did it boot all the way? Do you hear the fan running, disk drive spinning? If it sounds like it booted but the display is black, try this:
When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Apr 14, 2012 | Computers & Internet
On but no display
So the power is on but there is no display. Does it look like the laptop booted all the way? Does it look like the laptop is running but there is no display?
If the laptop is running, you hear the fans running, the hard drive running, etc. but the display is black, try the steps below:
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card is bad.
Apr 07, 2012 | Computers & Internet
Lenovo G470 the power is on but no display
So Power is on but no display. Does it look like the laptop booted all the way? Does it look like the laptop is running but there is no display?
Apr 07, 2012 | Lenovo Computers & Internet
Power on but no display
my LENOVE G570 screen just got broke last time while im watchin dvd.a crazy RGB shown-up and i dont know why!! then i start looking for "how to open a Lenovo G570 screen" then i came up with this
http://www.youtube.com/watch?v=3FwSoAzEXsw
then i start cleaning the surface using pressured air from my balloon maker. .then i remove the "jack" or whatever you call that. . and erase it with a pencil eraser then put it back!!
when i open my loptop again!!it suddenly work!!
Apr 07, 2012 | Lenovo G570 Notebook
HP Pavilion dv6000z Notebook Logo
35 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
