Question about Panasonic Televison & Video
We have a panasonic dvd player/recorder but is not sure how to hook it up. We also have the cord red,yellow,white so what do we do
  • awsomedude Jul 07, 2008
    yes we got it thanks
Where is the rate button for solved ?
Posted on Jul 07, 2008
  • 790 Answers
Hi
hey dude!!! the red and white is for audio connections the yellow is for Video connection...
Thanks!
Posted on Jul 06, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Jul 07, 2008
    Hi
    can you rate me as solved...
    Thanks!!!
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I tried to hook up my dvd player and i get picture but no sound. when i put the cords in the back of the monitor there is yellow red blue green holes no white spot. Do i need different cords. I have tried...
That could be a result to that TV either not having the ports you need, or you may need different cords. On my TV. With the 360 they have two cords. Red,white, and yellow and also green blue and i think red but im not 100% sure. You may need to find a different port on your TV for your cords, or do what I do and have your VCR hooked up to your tv, and your DvD player hooked up thorugh your VCR. Hope this helps and don't forget to rate ^^
(and yes that yellow and white are a necessity)
Feb 23, 2010 | Computers & Internet
How do i hook up my dvd recorder to my dvd player? where do i hook my cords to?
You need RCA cables to do this.These have red yellow and white cable ends.The yellow is for video the white is for the left speaker,red for the right speaker.Run the RCA cables from the output of you DVD player to the INPUT of your dvd recorder.Run another set of RCA cables from the output of your dvd recorder to the input of your TV.Most modern tv's have these inputs. These RCA cables can be purchased at Radio Shack or places like Walmarts.
Jan 10, 2010 | Lite On LVW-5005X DVD Recorder
My tv only has a cable hook up how do i hook a dvd player with red white and yellow cords
put the tv on av
#yellow cord in yellow socket
#red cord in red socket
#white cord in withe socket
now power the dvd
#Yellow cord in yellow socket
there will be 2 places for the red and white cords
#the red and white cords must be inserted in the audio,
# you will see them next 2 each other
insert them you it will work.
For More Info Email To ruanelectronics@gmail.com
May 11, 2009 | GE 32GT740 32" TV
Help hooking a dvd player to a tv
  • have you try to hook the rca jacks to the tv they should be color coded red, white, yellow, yellow is the video, red and white is audio. same as hooking to tv box.
Mar 24, 2009 | Panasonic DMR-E30 DVD Recorder
Magnavox DV220MW won't record.
You need to plug a red, white, and yellow cord from the red, white, and yellow OUT of your cable or satellite box into the red, white, and yellow labelled VCR IN/LINE 1 on the Philips. To view what you are trying to record, make sure there is another red, white, and yellow cable plugged from the DVD/VCR OUT of the Philips to your television. Make sure the television is on the appropriate source channel (AUX 1, AUX 2, VIDEO 1, VIDEO 2, etc). Then press the VCR button on the Philips. You should now see your cable or sat channel (as long as it's not an HD Satellite box) on the television screen. Press record, and you are on your way. Good luck!
-Tha Mp3 Doctor
Dec 28, 2008 | Philips Magnavox DVD/VCR Dual Player
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic DVD-recorder
connect the incoming cable to the player then run a cable from the player to the tv. Connect the white yellow red cable from the player (out) to the tv (in) and you shoud be up and running. That is how mine is connected and it works fine.
Jul 22, 2008 | Panasonic DMR-ES20EG DVD Recorder
DVD and PS2 in Black and White
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Jan 20, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
