Question about Bosch Exxcel WFO 2264 Front Load Washer
Blue stains on laundry
My washing comes out with blue staining on some of the garments. It can be bleached out on white items but this cannot be solved on cloureds.
I am using a Bosch Exxcel 1600 Express front loader
I was talking toa repairmain about which washer/dryer to get and he mentioned that the Bosch can stain clothing blue. I don't know anything else about why...but I'd contact my Bosch dealer.
Posted on Jul 14, 2008
The machine is doing yellow spots on several clothes and it is clean from inside and nothing could cause rust stains inside
Search Results
    Washing Machine Stains: Possible Causes And Cures
    Have you ever experienced washing machine stains, where your machine is the culprit for ... Just never put clothes in when doing this as it will discolor them. ... I get largeyellow spots on my Battenberg linens after washing, or maybe they ...
    Removing Yellow Stains from Washing ' Clorox
    The Clorox CompanyFeb 4, 2010 - I do my laundry at a neighborhood laundry that has. ... into the machinefor the wash cycle but still get the yellow spots. ... Since you diluted it in a gallon of water, the yellow spots/splotches should not be from the liquid bleach. ... Rinse and air-dry to see if it has any effect before doing a large number of items ...
    Weird yellow spots on whites - Home Forums - GardenWeb > Home Forums > Laundry Room
    Jul 27, 2010 - I wash on warm/cold using powdered Tide and nothing else. The laundryemerges from the machine with yellow spots in places. Not pale ...
    Mysterious yellow spots on clothes, bedding, etc ..
Feb 03, 2016 | Washing Machines
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
Blue rubber glove in load stained dryer inside. How to clean?
take a boyyle of simple green solution, and get a clean rag, and this should take the stain off, after youwipe it down with this if it is coming off, wipe it down after with water, then dry it off with a clean rag, let me know if this gets it, it should thks larry
Apr 22, 2010 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
Random brown stains in random loads of laundry
Hi from Australia
Ok the problem with your washing machine is that there is grease and oil stuck in the machine and the oil will dribble out when you run the machine on a different cycle if you rince with cold water then the oil stays in there and the hot water lets a little bit out as it is stuck in the pipes of your machine ok the first thing is run an empty load on full hot water even the rince cycle with 1 cup of bleach nothing else let that go through the long cycle then do the same again with 1 cup of white vinger and 1/2 cup citric acid which you should be able to get over there or baking soda try that it will clean your machine and your pipes it is great way to keep it all clean by the time you have done this you should not have any brown stains
Have a great weekend
Jan 22, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag a112 manual on how to add bleach AND fabric softener
Choosing Your Detergent, Bleach, and Fabric Softener..
Learn what the different items you need to wash your laundry.
Liquid Laundry Detergent and Fabric Softeners
When using liquid laundry detergent, you do not want to poor it directly on your laundry. The dyes in the liquid laundry soap could stain your clothing. You will want to start your washing machine and add the liquid laundry soap while the water is filling the washing machine.
You then can add your laundry once you have about and eighth of the washing machine tub filled. This will ensure your laundry doesn't become stained by the detergent. You should only add the amount that is poured into the cup to the fill line. When you add more, you could find yourself wading through mounds of bubbles overflowing from your washing machine.
The same reasoning applies to liquid fabric softeners. However, liquid fabric softeners are added to the washing cycle after the initial washing cycle is finished. You will want to add the fabric softener once the washing machine has filled with water and started to agitate. This keeps the fabric softener from touching the laundry and will work it into your clothing better.
Powdered Laundry Detergent
You will want to add one cup of loose laundry detergent to your washing machine in the same manner you would do the liquid laundry detergent. By doing this, the powdered laundry detergent will dissolve easier.
When adding bleach to your laundry, there is a small triangular cup in the corner of your washing machine. By adding one cup of bleach into that dispenser, the bleach will be added to the laundry at a precise time during the wash cycle.
Setting Your Washing Machine
Most washing machines have three or four cycles. For instance, the Maytag Washer I have has four cycles, regular, permanent press, delicate, and soak.
Regular Washing Cycle
The regular cycle is used for the following types of clothes and other apparel:
• Jeans
• Towels
• Blankets
• Sheets
• Quilts
• Bedspreads
The soil types for this cycle are heavy, normal, and light. This means clothes or other articles that are lightly too heavily soiled should be washed in this cycle. This is due to the washing cycles can be set from a minimum of eight to fourteen minutes maximum. You can use all three of the water temperatures in this cycle.
1Permanent Press Washing Cycle
The permanent press washing cycle is used on the clothes that may or may not need to be ironed.
Such as:
• Blouses
• Shirts
• T-shirts
• Under garments. This would be your unmentionables and socks.
• Jackets
• Sheets
• Baby Clothing
The soil types for this wash cycle are normal and light. The washing times for the permanent press cycle are six minutes to ten minutes. You can use all three washing temperature modes for this cycle as well.
Delicate Washing Cycle
The delicate washing cycle is normally used for sweaters, cotton, silks, and other fabrics that need to be washed with care.
The soil types for the delicate cycle are normal and light. The washing times for the delicate cycle are four and six minutes. It is best to wash your delicate clothes in warm or cold water. Always wash clothing that is more than forty percent cotton in cold water to prevent shrinking.
Soak Washing Cycle
The soak cycle would be used for heavily soiled clothing, such as, football and baseball uniforms. This will help rid the uniforms of caked on mud and grass stains.
You can also use this cycle if you wish to only bleach your white's once a week or once a month with bleach.
Washing Your Laundry
Choose the cycle you need for your laundry. Add the laundry detergent, fabric softener, and bleach (remember regular liquid bleach is for white clothes only.) Start the washing machine and let fill to dissolve the dry detergent or to mix in the liquid detergent.
Now add your clothes to the washing machine. Clothes the lid so the washing machine will continue to wash your clothes.
If you are using a Laundromat, put your clothes in the washing area and shut the lid or door. Add your detergent and other cleaning items in the correct compartments. Put in the correct amount of change so the washer will start.
Thanks for contacting
Nov 13, 2009 | Maytag Washing Machines
Clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Jun 13, 2009 | Samsung WF328AA Front Load Washer
My Washing machine stains clothes; they come out with brown rusty stains. Otherwise the washing machine works fine.
I've had this problem for many months now.  Even when it ruined my favorite tops & jeans, I couldn't get myself to let go of them... Good thing though because I have found a solution!  Make a paste using cream of tartar and hydrogen peroxide.  Generously spread the paste over the stains and let sit for about 5 minutes.  Boil enough water to fully immerse the stained garment in.  While waiting for the water to boil, figure out a way to wrap/roll the garment so that the paste doesn't come off when put into the water.  You want the paste to melt onto the stain while in the hot water.  After wrapping/rolling the garment, secure it with string or thread (anything that won't melt) that doesn't have color, just in case it bleeds.  After the water has come to a full boil, immerse the garment into the hot water and let it soak.  After about 15 minutes, remove the garment from the water.  The water should still be very hot, so I use cooking tongs to get it out.  Let the garment cool down to room temperature while still rolled up.  After it has fully cooled, unwrap the garment.  There should be very little or none of the paste left on the stain.  If there is still a great deal of paste, you may want to soak it again until the paste melts a bit more.  Once the paste is gone, rinse of the garment and it should be clean & stain free.  :o)
Mar 17, 2008 | Washing Machines
Stains on clothes
Have you tried Calgon to get rid of limescale deposits? Also have you used any laundry bleach at any point, because it stays in the machine for ages and clothes come out with faded patches and bleach marks for weeks afterwards.
Sep 16, 2006 | Baumatic BTWM4 Front Load Washer
Bleach stains
try putting your washer on the highest boil wash this sometimes will stop any of these problems from accuiring again
Jun 12, 2006 | Hotpoint WMM39 Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
415 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
