Question about Nikon COOLPIX Cameras
Photo numbering I have inadvertently reinitialize the Coolpic 3100. Photo numbering has been reset to DSCN0001. Is it possible to set the numbering sequence to  begin at DSCN5050 which was my last pictures before reinitializing? Tanks! AB
I have found a solution, albeit for MacOS X (v10.5)
1) Take a dummy picture. 2) Connect the camera to the Macintosh computer. 3) The camera is mounted as a "NO NAME" disk. 4) Open the subfolder "100NIKON" in the folder "DCIM" 5) Rename the "DSCN0001.JPG" picture to "DSCN5050.JPG" 6) Eject the camera disk. It is done! 7) Take your picture, and delete the dummy one.
As far as it goes, it seems to work for me. Number sequencing will start at "DSCN5050"
AB
Posted on Sep 01, 2008
Please look this picture.when I switch on my Olympics camera then this type display only.what's the problem?
It's a very small image - is it possible that you have inadvertently altered a menu setting ? It looks as if it is offering some options, but I can't tell what. You may have to do a reset to factory settings. The manual may also help, as most of the menu settings should be illustrated.
Jun 27, 2016 | Cameras
Camera only taking one photo at a time. I've reset all settings but must have inadvertently knocked a button or dial and can't take more than one photo at a time. I usually shoot on Auto.
Most cameras only take one photo at a time. Do you mean you normally have it on continuous shooting, so that it takes a sequence of shots ? If so, that should be an item within the menu system. Failing that, try a factory reset. If that doesn't work either, then switch the camera off, remove the card and the battery and leave it overnight before replacing them, battery first, and trying again. There may also be advice on the manufacturer's website.
Jun 11, 2016 | Cameras
How do I reset the photo/frame numbers?
I'm afraid your camera can't set the photo count to 1.
At least the user manual does not show any possible hint how it could be done.
Feb 13, 2014 | Kodak EasyShare C913 Digital Camera
The camera works fine on auto settings, but when I try to use it in P, M, S, or A, the image is very dark.
When I've encountered this problem before it has been caused by a faulty aperture mechanism in the lens, but your answers to my questions pretty much remove that as a cause.
All that leaves as the culprit is the camera body. If there was a genuine fault then the same fault should be occurring when in fully automatic exposure mode, and the fact that you can compensate for the fault using the exposure compensation button is good news as it probably means that the fault is due to an inadvertent camera setting: the exposure compensation function is inoperative in fully automatic mode. The E-410 has two user-definable "custom reset" settings (page 70 of the manual) and I suspect these may be the cause.
I suggest that you go into Menu and then to the camera 1 symbol. From here you'll see "Custom Reset Setting" with the options "Reset", "Reset1" and "Reset2". "Reset" restores the camera to the default factory values and should cure your problem. Note that afterwards, the file numbering on the photos you take will also be reset so you may wish to manually adjust the file numbering afterwards to continue where you left off with you last photo. Not doing this will result in file name conflicts when uploading images to your computer.
If this doesn't fix your problem then the E-410 definitely has a fault and it will need to be resolved by an Olympus Digital service centre as the cause will be beyond any DIY resolution. The fault will likely be a software rather than a parts issue so a repair is likely to be cost-effective. Your camera had a one year worldwide manufacturer's warranty when sold new so it's possible that the camera is still covered (the E-420 was released early last year, but new E-410s were still being sold by some retailers early in 2009). There was also an option to extend the warranty so if the standard warranty has expired you might still have cover.
Normally I'd test all of this on my own E-410 or E-510 (same menus/software) but my wife has gone to France with them!
Hopefully I've hit the mark and been of some assistance. If so I'd be grateful if you'd return the favour by rating my answer.
Nov 10, 2009 | Olympus EVOLT E-410 Digital Camera
Slow in clicking photo on DSC-V1
The DSC-V1 can use a Memory Stick of up to 2GB so that's not your problem.
Rather than type out a whole step by step guide on how all the menu settings can affect the camera, it's easier to just reset the camera to the factory defaults to see if that fixes the problem.
There's a small hole about 1mm in diameter on the camera base plate, just by the battery cover hinge clearly marked "reset". There's a button inside which you'll need to press whilst the camera is turned on, use anything which fits in the hole such as a paperclip (don't use a pencil though!).
If the symptoms cease, then it was a user setting which was the cause. If not, then the camera will need disassembly to diagnose and fix but sadly it's an uneconomic repair.
Note that a reset also returns the folder and file numbering to zero as well. To avoid overwriting previously uploaded photos uploaded you'll need to go into the menu system to manually set this to your needs. if you don't know what file number you were up to then just start with a new folder instead.
Dec 07, 2008 | Sony Cyber-Shot DSC-V1 Digital Camera
Cybershot DSC W50 Flash Doesn't Work
have you tried resetting the camera? i had this same problem and i just went to menu>setup>setup1>initalize>OK
and it went away completely.
Oct 14, 2007 | Sony Cyber-shot DSC-W50 Digital Camera
CD1000 -multiple users & switching CD's & photo numbering
There should be no problem RS. I currently have 2 discs on the go. The numbering sequence (and folders representing finalized sessions) are kept in a directory on the CD-R.
Sep 13, 2005 | Sony Mavica MVC-CD1000 Digital Camera
Cameras Logo
77 people viewed this question
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
