Question about Dell UltraSharp 1907FP 19" LCD Monitor
No Composite Input Signal Message on Screen
About 4 inch sq blue message on upper right of screen which says
" No Composite Input Signal" Cursor goes behind it and no option to close. Also I try to access menu through buttons on front but a lock symbol appears.
Please help!
  • 1 more comment
  • wsnrpolice Dec 04, 2008
    no composite input signal in upper right hand corner
  • Anonymous Dec 22, 2008
    Mine does the SAME THING!!!
  • Anonymous Mar 11, 2009
    On monitor menu, switch PIP source to SVIDEO, then turn MODE to off.
Push the PIP button until it says off
Posted on Feb 19, 2009
    New Friend:
Pushing the PIP button solved the problem
Posted on Sep 28, 2015
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Dell 2407 Can't get rid of "No S-video input signal" message on screen. How do I get rid of this?
Your S-Video connection is referring to a round plug for a TV input signal. Most computers will not have this connection unless you have a TV based video card. If your using a TV 'monitor' as your computer's video device, their will either be a button on the monitor or your remote to allow you to choose the input signal. If you are using a VGA or HDMI or DVI cable as the connector between the two devices, most likely, the light is referring to one of these, as its video source. You will need to match the cable & monitor source detected to get a usable picture output.
Good luck.
Toby.
Sep 28, 2015 | Dell Computers & Internet
I have a Polaroid FLM-373B 37 " tv and I get a blue screen with "No Signal" in the top corner. Cant seem to get it to find a cable signal, dvd signal or anything. I have successfully...
That situation clearly indicates that no signal is coming to the set in its present setting. Have you checked to make sure that the tv's input is set on the right input setting. Mine always defaults to "Antenna" which drives me nuts cause I get that big blue screen with "no signal". It seems to do that at the slightest provocation, too. After 5 years, I still have to think twice before checking it. If that is not it, make sure that the cables are plugged in. If that doesn't fix it try another type of input such as HDMI or S video, composite, etc - one that you are not using. Don't forget to switch the input to it. Good luck!
Nov 06, 2010 | Polaroid FLM-3732 Television
How to remove "no composite inpute signal"
If you have the same problem with both monitors, it sounds like a display card setting or problem.
The chances of you having the same problem with different units is 1- 50.
Try the monitors on a different PC and get back to me.
Sep 02, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
I have a 32" LCD TV that I can't seem to get any of my DVD players to work on. Keep getting error message "no video signal" but They use to work. help
How do you have your DVD player hooked up to your TV(i.e. composite, s-video, component)? Some DVD payers and TVs have menus to switch inputs and if you somehow switched off the input your players are connected to, you'll get a "no signal" message.  First try hitting the input button on your TV or the Input/connection option in your TV's menu.  If that doesn't work try hooking up the DVD player(s) with the composite Cable(yellow), the component(red,green,blue) and S-Video(black/round) at the same time. If you scroll through your TV's inputs you should get a picture on one of these connections and the TV should display which one. The display will usually be in the corner of the screen.
Apr 27, 2009 | Televison & Video
No composite input signal
Try the following:
Right after power on, tap the F8 key to see if you can get a short menu to come up.
If it does, select "Safe Mode."
If your screen looks different, it may be just the driver for the display card or monitor is trashed (Windows like doing that, keeps us challenged).
- Open Control Panel, then System, then Hardware, finally Device Manager.
- Locate Display adaptors, open and delete the adaptor listed (all, if more than one.)     - Locate Monitors, open, delete any listing there.
Reboot.
Windows should 'find' two 'new' devices and install the drivers for them.
The display may still be different if you had other than the default settings.
Go then to the Display folder of the Control Panel, click on 'Settings' and experiment. Depending on your Windows version, if you choose something dumb so it makes the screen unreadable, ignore it and Win will ask if you want to keep it and give you some time to acknowledge that you like it. When you don't, it will just go back to the pre-tinkering settings.
Apr 03, 2009 | Dell UltraSharp 1907FP 19" LCD Monitor
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
Hd tv
My HDMI has stopped working. I have had a technician from Dish network out to my house 3 times and they have replaced the receiver and the HDMI cable and were unable to get the set to work all I get is a blue screen and a message which reads no signal. I also cannot use mt set using 3 rca cables connected to the component input when set to 1080 I keep intermittenly get a black screen then a blue screeen and sometimes a no signal message. I have to watch the tv set to 720 on component 2 and it is the most stable in that setting. Please send help
Jul 06, 2008 | Protron PLTV-37 37 in. LCD Television
Yahoo Messenger
1- click on top of the window on the title bar, while holding your left mouse button...move the window to the left until you see the right bottom corner about 1 inch from the right corner.
2 - click on the right bottom corner to resize the window and drag it all the way to the left about an inch away from the edge.
3-repeat step 1 until the window is back to normal size
Feb 24, 2008 | Computers & Internet
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
Dell UltraSharp 1907FP 19" LCD Monitor Logo
3,868 people viewed this question
Alun Cox
