I need codes for REM110-NZ Magnavox 3-Device Remote
  • 1 more comment
  • Anonymous Nov 04, 2008
    I am in the same boat
  • Anonymous Dec 15, 2008
    I have a "Philips Magnavox" TV with this remote? Why can't I find any information about it?
  • Anonymous Mar 03, 2009
    How similar is the REM110 to the rem110nz. the manual for the 110 is available on remotecentral.com
2 Suggested Answers
gopakumarg43
  • 74634 Answers
SOURCE: iIneed codes for my Phillips Magnavox rem110-nz remote. I have a Mitsubishi tv
002 102 206 502 510 619 709 803 814 914
These are the codes to check.
Posted on Sep 05, 2012
NEED CODE FOR GE URC FOR MAGNAVOX SDTV
These are the codes most likely to work for a GE URC and a Magnavox SDTV.
Your remote will only use 3-digit codes or 4-digit codes, and not both.
004, 008, 009, 062, 068, 069, 074, 075, 076, 077, 089, 133, 141, 163, 165, 226, 288, 456
0062, 0004, 0009, 0456, 0183, 0226, 0288, 0008, 0068, 0075, 0141
1. Manually turn on the device TV.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the TV. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off. If it turns off after 004, it uses 3-digit codes only. If not, enter a 1 for code 0041, which will not work, and go to step 2 for 4-digit codes.
5. Aim the remote at the TV and press the POWER button. If your device does not turn off, go to step 2 and try the next code.
(6. If none of the codes work, please reply.)
Jun 22, 2014 | Televison & Video
IIneed codes for my Phillips Magnavox rem110-nz remote. I have a Mitsubishi tv
Sep 05, 2012 | Televison & Video
Hi I am tring to find a MAGNAVOX TV KM-42010P remote control
Hello
Buy one COMCAST CUSTOM DVR-3 DEVICE Universa Remote Control. Magnavox is listed in its codes. Codes are:
0054, 0030, 0179, 0186
You will get its catlogue and all other details, about how to enter codes, and a colde list for different devices to which this remote can be used. OK.
May 03, 2011 | Philips Magnavox 27MS343S 27" TV
I lost the booklet with all the codes for my remote and i need the code to work my tv my tv is a symphonic
I suggest you try these steps..
1.Turn the television set on by pressing the "Power" button on the set.
2. Find the "Code Search" button on the Philips Magnavox remote. This button will be labeled or will be a different color than the other buttons on the remote (depending on which Philips Magnavox remote you own)
3. Hold the "Code Search" button down for about ten straight seconds. The light on the Philips Magnavox remote should then stay on.
4. Starting pressing either the "Up" or "Down" channel button on the Philips Magnavox remote. Continue pressing the same button until the television responds to the remote. It could take a few minutes for the channel to change so you'll need to have patience when searching for the remote code in this manner.
5. Press the power button on the Philips Magnavox remote once the channel has changes. If the device shuts off, press the power button again to turn the TV back on. If the TV turns on, the remote has been programmed correctly. Repeat the entire process if your remote is not programmed.
I hope this helps...
Jun 10, 2010 | Philips Magnavox Learning Universal Remote
Cant find codes for rem 110
I have the same remote. I googled "philips magnavox universal remote rem110" and found the manual here: http://www.rockabilly.net/files/manuals/REM110.pdf
Sep 29, 2009 | Philips Magnavox Learning Universal Remote
Need tv codes for magnovox misplaced code book
Hey there juice0619
MAGNAVOX ..... 002 009 109 118 209 309 402 408
502 508 510 807 914 917
Direct Philips Magnavox Universal Remote Code Entry PM335
1. Press and hold the Code Search button until the red
indicator stays on. Release the Code Search button.
2. Press and release the desired mode button (TV,
DVD, etc.).
The red indicator blinks, then stays lit.
3. Enter the 3 digit code from the code tables. Note:
after a valid code entry, the red indicator turns off.
For an invalid code, the red indicator flashes.
4. With your device on, press CHANNEL Up. If the
device responds, no further programming is
required. Note: If some buttons do not operate your
equipment, try one of the other codes for your
brand.
Hope this helps
Chris (ziraffa)
Dec 20, 2008 | One For All URC-3021 Remote Control
Need codes for a philips universal remote code sheet
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 21, 2008 | Philips Magnavox Learning Universal Remote
3 Digit Product Code for Magnavox tv RR1337 W101 (13S401-00AA)
0807 works with a Philips Universal Remote on my Magnavox RR1337 101
Apr 28, 2008 | Televison & Video
Televison & Video Logo
290 people viewed this question
Top Televison & Video Experts
Electro Med Services...
