Question about Frigidaire FAC124 wall/Window Air Conditioner
Frigidaire FAC125P1A6 when AC is on mist is coming out
When AC is on mist is coming out. Also water droplets are also shooting out.
  • pgapay Jul 07, 2008
    Cleaned the filter which didn't help. What I did was tilted the unit so that the water would drain and not collect as much. Ran it for awhile and it looks good for now. This unit is about 1 yr old so I hope it doesn't need service already. Thanks for the tips.
    Novelist:
    Champion:
  • 230 Answers
Try cleaning the filters and running a couple of degrees warmer. If this does not work have the refrigerant levels checked by a professional.
Posted on Jul 07, 2008
How to repair drain on ac
Hello Jerry,
Are you referring to a leak (Drain) on your vehicles Air Conditioning system?
PS: It is quite normal to see water dripping underneath a vehicle which has been running their A/C. This water is not coming from the A/C...it is water that collects as droplets on a cold surface when humid air is in contact with your systems A/C Evaporator.
Aug 30, 2017 | AC Cars & Trucks
Frigidaire gallery dishwasher model#DGHD2433KF1 water droplets remaining on top lower water not draining all the way leaving an odori
Two things to consider....clean water or dirty water?
Clean water usually indicates the fill valve is not shutting off all the way and the fill valve is "weeping" water in all the time = new fill valve time!!
Dirty water usually is not a dishwasher problem but more of a plumbing issue. Often the sink drain that carries the sinks water outside is not fast enough and some of this sink water is backing up into the drain hose and filling up the dishwasher through the drain hose. The drain from the sink to outside needs attention as this type of a problem indicates a slow house drain for that sink.
The dishwasher drain line should be clamped to the top underneath part of the counter before entering the sink drain plumbing, this may help the water from coming back inside the dishwasher.
Jul 20, 2012 | Frigidaire Dishwashers
WHY DON'T MIST COME OUT OF MY HUMIDIFIER
with cool mist humidifiers your not suppose to see any mist. if it's a warm mist there should be. but by your model number i'm finding that it's a cool mist. that's why your not seeing any mist.
Aug 15, 2009 | Vicks Cool Mist V3500 Humidifier
Water shoots out when i flush
either your fill tube came out of the tube in the center that the flapper is connected to or the fill valve wore out.Usually this happens when the little plastic or rubber hose coming off the fill valve comes out of the over flow if you secure it to the center tube so the water goes down it you'll have a dry floor and better working toilet
Aug 11, 2009 | Home
Honda acac sometimes blows some kind of dew air throught he vents
u most likely have some condensation building up in evap box ,,need to clean it out before it gets worse,,,if u are running it on low blower ,it is going to put out mist sometimes (if the air is really cold) because of the expansion valve pulling down the tempurature
Jul 06, 2009 | 1996 Honda Accord
White powder coming from dehumidifer.
Commercially available cool mist humidifiers sonicate water in order to create a fine mist. In other words, intense vibration liberates millions of tiny droplets of water from the reservoir. This water contains all of the salts of the original tap water. Consequently, over time, you will begin noticing that a fine white powder covers EVERYTHING in the room. This is the same stuff that is trapped in the reservoir of a warm mist humidifier.
its harmful but very annoying !
please rate me
May 29, 2009 | Maytag M7DH65B2A Dehumidifier
No mist, but i can see a water droplet fountain on the surface
if it's a cool mist unit it will not produce any mist. now if it's a warm mist unit it should. that's normal. it is possible to replace the transducer if it is damage but you are going to have some leakage from it. but the only way to get the transducer mainly is from the manufacturer
Mar 12, 2009 | Sunbeam Ultrasonic Humidifier
FAC124P1A1 window unit
It is probably freezing up and then thawing. Try cleaning the filters and running it at a higher temperature for a while. If it goes away then you are finished. If it does not go away you may need to bring it to a service center to have the refrigerant levels checked.
Jul 07, 2008 | Frigidaire FAC124 wall/Window Air...
Frigidaire FAC124 wall/Window Air Conditioner Logo
767 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Donni Steen
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
