Question about DSC DV182 Camcorder
Sd card not reconsized by pc
Got a dv182 took photos but unable to download to pc which is running xp using a 2gb sd card, have used another 2gb sd card and that works ok sd card is new
  • ssandip22 Apr 24, 2009
    when i conect my camera to my PC it give me replay cam recorder not reconigesed.when tried to open videoimpression it gives reply that canot found VFW driver.
Omg same thing keeps happening i have a vista and i try to download the photo's on my vista but it won't work
Posted on Oct 11, 2008
I was unable to download pics from my fujifilm 2gb sd card to my pc when full (using card reader), but unable to view photos and when put back into finepix camera now says card error so cannot view...
I have had success with this photo recovery program called asoftech photo recovery... Download the program
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Mar 21, 2011 | Fuji Cameras
All accidentally deleted.
I would suggest you "NOT" to copy anymore files on your SD Card to prevent data loss or data corruption. Stop using it immediately.
Download an undelete program such as Undelete Plus. I think its a free download. and run the
program to recover your pictures. If you attempt to continue to use your SD Card you are at
higher risk of loosing your data.
Feb 04, 2011 | PNY 2GB microSD Memory Card
2GB Micro SD needs format code that I never gave it
You can format your micro-SD Card using a software which you can download by clicking this link. I uploaded it to my FTP site for you and it will be there for a limited time. Download that file and save it to your PC. Then unzip that ".zip" file.
If you format micro SD card connecting it to your PC via USB port, it may not ask for password. (I think your phone asks password to format.)
To format your micro-sd card:
- First plug in your micro-sd card into you PC.
- Run the downloaded "HPUSBFW_2.2.3_MASTER.exe" file.
- In the program menu window, select the device (your memory card).
- Select FAT32 as file system,
- Confirm that all the format options unchecked. (Uncheck the quick format option)
- And click the "Start" button to begin formatting.
Hope this helps you.
If you would like to vote for the answer, this will help the others to see the similar problems solved and also will be a satisfaction factor for me to continue helping you.
All the best.
May 12, 2010 | SanDisk 2GB microSD Memory Card
Digir8 dv182 help uploading content from sd card
you should purchase a sd card reader, they are very cheap. ( ebay, amazon etc )
May 18, 2017 | DSC DV182 Camcorder
Unable to view pics
Copy the existing photos on to your PC, switch off the camera. Remove the SD card and format the SD-card using a SD-card reader, this will clear all the card contents. Now try using it in your Camera again. Ideally, you should be able to save photos on this SD card. Other way would be to insert another SD card into your camera and click photos and check whether those photos are being saved into the SD card(this can be done using display option in your digicam.)
Dec 17, 2008 | HP Photosmart E327 Digital Camera
Sd memory card
this camera with firmware below 1.03 has a problem with 2gb cards , i recommend 1 gb cards ( i have tried many until now it never stopt working ..so yes go back to where you bought the card (not accidentaly switched the white write protect switch ?? )
Apr 09, 2008 | Konica Minolta DiMAGE Z3 Digital Camera
DSC DV182 I can not get the camera to store videos or photos
is your sd card > 2 gb?
only supports up to 2gb
Mar 14, 2008 | DSC DV182 Camcorder
Panasonic DMC FZ18 2gb digital camera: consistently crashes when downloading images to PC (Windows XP): e.g. will detect 40 images for download, but will only download the first 10. Switching the camera...
try using and SD card reader instead of the software that came with it. then you know if it is a software issue or a problem with how your camera saves the photos.
It's also quicker using an SD card reader and drag/drop - copy/paste etc.
Mar 10, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Sd memory card not read by computer
Reformat the card from the camera. You didn't specify camera model but every digital camera has a menu to format media.
If you don't succeed try to connect your camera to the computer and read the photos.
If that doesn't succeed either take your camera to service.
Jan 15, 2008 | Cameras
DSC DV182 Camcorder Logo
143 people viewed this question
Top DSC Video Cameras Experts
Tony Parsons
Tony Parsons
Kas S
Kas S
Are you a DSC Video Camera Expert? Answer questions, earn points and help others
