Duke Aerohot Electric Steamtable W Exposed Elements 2 Wells 120v Logo
Posted on Dec 28, 2010
Plugged in and not getting any power or heat to any of the 4 heating elements
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Dec 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
530
Points
15
Check to see if there is a fuse that is blown. If all elements were on, all at one time, it could have overload / over heatedand blown the fuse.
My RICOMA PSP-990C doesn't get hot
If your RICOMA PSP-990C isn't getting hot, there are several things that could be causing the issue:
  1. Check the power supply: Make sure that the machine is plugged in and that the power supply is working properly. If the power supply is faulty, the machine won't heat up.
  2. Check the temperature setting: Make sure that the temperature setting is set correctly. If the temperature is set too low, the machine won't heat up.
  3. Check the heating element: The heating element could be faulty, which would prevent the machine from heating up. In this case, the heating element would need to be replaced.
  4. Check the thermostat: The thermostat could be faulty, which would prevent the machine from heating up. In this case, the thermostat would need to be replaced.
If you are unable to determine the cause of the issue, it's recommended that you contact the manufacturer or a professional technician for assistance.
Mu 8200 living pure heater the power light is red and it says 75 degree but not heat what do I do
If your Mu 8200 Living Pure heater is displaying a red power light and the desired temperature but is not producing heat, it could be due to a malfunction in the heating element or thermostat. Here are a few things you can try to troubleshoot the problem:
  1. Make sure the heater is properly plugged in and that the outlet is functioning properly.
  2. Check the heater's control panel for any error messages or codes that may indicate a specific problem.
  3. Check the heating element for any damage or wear. If the heating element is damaged or worn, it may need to be replaced.
  4. Check the thermostat to make sure it is functioning properly. The thermostat controls the heating element and can cause the heater to shut off if it is not working correctly.
  5. Check the power cord and outlet for any damage or loose connections. Make sure the cord is securely plugged into the outlet and that the outlet is functioning properly.
2helpful
2answers
I have kitchenaid dryer, #KEYS677EQ0, no heat. Have replaced heat element, & checked all the thermostats. I have power on the thermostat side of the element, but none on the motor side. Motor or timer
1) Have you checked to makes sure all of the connections for the heating element are correct and plugged in?
2) Have you checked to make sure any and all fuses (if any) are good?
3) Have you cleaned the interior of the dryer?
4) Have you opened the dryer up and turned it on to check to see if the heating coil is heating or not?
If you haven't done these go back and do so.
1helpful
2answers
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 • Dryers
1helpful
Element not heating
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance: http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad). 2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
2helpful
Dryer runs but does not get hot to dry clothes
Hello there:
There are a couple of things to check if the dryer does not heat properly
There's no heat If your dryer doesn't heat, check these: Power from the house Heating element Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected. Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable. Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Feb 27, 2010 • Dryers
Oven Element
are you sure you have 240 volts now, if one leg is still out it wont heat,also check your electronic control panel if so equipped for an electronic fuse
No heat, 120 power to only one leg of heating element. The power was read on the side of the heating element that came from switches. I do not have a schematic, so it is hard to ttrouble shoot, not knowing...
Heating element
Thermal fuse
Wiring
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Jul 31, 2009 • Dryers
Rowenta precision iron DM 561 will not heat up
Most irons for which you pay more than $10 (like this nice Rowenta) will have a replaceable heating element. The problem seems to be to try to find where you can get the heating element. My best bet would be for you to contact a Rowenta service center (see listing at http://tinyurl.com/danr9x). They should be able to tell you where you can get the heating element.
Before you go that route, I am assuming you already plugged the iron directly into the outlet in the wall (not in the surge strip)? Wouldn't be the first time a single outlet of a power strip goes bad.
Good Luck,
11helpful
3answers
Gevalia CM-500 12 cup problem.
Underneath the hot pad that the carafe sits on, there are two thermal fuses that are inside tubes that are clamped to the heating element with spring clamps.
Remove the bottom of the unit (5 screws), unclamp the thermal fuse tubes, slide the tubes to one side and check the each fuse with an ohmmeter. If one of them is open, that's your problem.
Top Duke Kitchen Appliances - Others Experts
john h
Are you a Duke Kitchen Appliances - Other Expert? Answer questions, earn points and help others
