Hi. Recently I found a leak under the washer (Maytag model LSE7806ACE) at the front right side and it does not seem like the hoses or joints leak. Is it possible that the drain pump itself leaks? Do I need to replace it? Thanks. Valery
  • valanko Jul 08, 2008
    I did exactly as you just recommended and found no leaks during the entire washing cycle. I repeated it several times and again found no leaks. But it happened twice before. Thanks.
    Valery
    Novelist:
  • 177 Answers
Start by removing the front panel, have a flashlight or other light source, then starting a wash cycle I would do a regular on the small setting. Start looking for the source of the water drips etc?
if you dont find any thing during the fill process or wash agitate I would stop machine and then turn to spin, again look for the leak source.
If you find the pump is leaking, you need to replace the pump, you can find parts on line, I like Partselect.com or repairclinic.com or some local in your area.
If you find some thing else is leaking come back and ask more questions. It maybe a tub seal and that is not a do it yourself job, special tools are required.
Posted on Jul 07, 2008
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
I have a LAT9700AAW model Maytag washer ...why does water shoot out of the translucent air gap device located midway back on the left side above the wash tub?
It seems like it has sprung a leak. If it is on the joint you can try tightening up the hose, otherwise you may have to get a new injector assembly.
Jul 13, 2011 | Maytag Washing Machines
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
17 year old maytag washing machine leaking water under washer towards the right front.
The pump is at the right front. When the seal goes bad the pump will leak down the shaft. Check the hoses too.
Feb 02, 2010 | Maytag Washing Machines
Washer is leaking. If facing washer, water is on
probablly water pump or hose tilt machine to view where water is coming from
Jan 17, 2010 | Kenmore HE2 Plus Front Load Washer
Maytag A482 washer from 1985. Leaking water from
probably has a pin hole leak where it has been rubbing the tub. Does the tub have a seal at the top of it where it meets the top. Could be the seal is going bad.
Sep 07, 2009 | Maytag PAV2300 Top Load Washer
Maytag stack unit Model LSE7806ACE leaks
It is most likely the tub seal. Take the two phillips head screws out of the front cover located low on the cover lift forward and remove. Set the machine two low level and fill with water only no soap or clothes when unit starts agitating look at the bottom center of the clothes tub if water is leaking here then you will need to replace the tub seal and tub bearing assembly.
Apr 06, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washer does nothing during rinse then leaks during spin cycle
hi thanks for the question i would check the drain hose your problem is the washer is not draining check the drain hose thanks the appliance doc
Sep 27, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Neptune MAH8700AWW Front load
I have a maytag neptune front loader (MAH8700AWW) unless I turn the water off @ the faucet the water continues to run into the washer after the load is done .How can I fix this.
Oct 20, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
