Microsoft Xbox 360 Console Logo
Louis Duarte Posted on Dec 28, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Its saying system error and at the bottom of the screen it says E 68
sonic boom electronics
Level 3:
  • Master 1,557 Answers
  • Posted on Dec 28, 2010
Master
Level 3:
Answers
1557
Questions
Helped
386187
Points
5474
Its a hard drive problem according to all the data my games guys tell me there is no easy fast fix the hard drive needs replacing or fixing by a lic microsoft tech.
sorry
hope this helps
Rheem furnace error code 68
Rheem furnace error code 68 is a mechanical relay system which signals the blower motor to stop because it has not received a signal from the thermocouple.
Jul 20, 2022
Rheem furnace error code 68 - HVAC Contractors
Motor Power And Communications Issues (Fault Code "68")
ManualsLib https://www.manualslib.com > Rheem-96v-Series
Motor Power And Communications Issues (Fault Code "68"); Line Voltage And Low Voltage Connections To The Communicating Motor - Illustrations - Rheem 96V Series ...
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
My xbox has one red ring and it says e 68 at the bottom of the screen
This error pops up when your hard drive goes bad. Try pulling it out, then reconnecting it and see if that helps. If the error still persists, you may need to buy a new hard drive.
System error e 68
E 68 is a hard drive error, try removing the hard drive and turning the system on. If that works, turn off your system and reconnect the hard drive, then turn it back on, if it still works YAY!! If not, you may need a new hard drive....
My electric dryer tell me ERROR 68 on the screen ¡¡ Plus every 5 minuts stop for she self ¡
The data sheet says "One of the buttons is stuck closed". If you can't solve this by inspecting & jiggling the buttons, open the lower front panel of the machine, & look behind it for the "Tech Data Sheet*. Follow the instructions for error 68.
1helpful
One red light - Error: E 68 - Problem code 0110
Hard Drive Error... It could be a problem with the Hard Drive itself or a problem with the internal connection to the hard drive, Try removing the hard drive and playing without it, This can also be caused by a Hard Drive Eprom Error.
We offer a repair service.
FixMyConsole
System error 1 light code E 68
error 68 means that the xbox has insufficient power to operate. make sure it is directly plugged into the wall. try removing accessories on your xbox like intercoolers and USB devices.
Screen says system error. A large E 68 is at the bottom of the screen and the red light on the front of the xbox is flashing.
E68: Voltage Error... This error means that the Xbox 360 has insufficent power to function properly. This can be caused by an error in the hard drive or the fans that make them **** up too much power, it can also be caused if you have unnecessary accessories attached to the console like an external fan unit. Attempt to remove unnecessary accessories first, and then necessary components such as the hard drive and USB devices. If you have any case mods you may want to investigate those as well.
Also try removing the HD, and starting it up without it.
2helpful
ERROR CODE 68 ON AFFINITY ATF7000EE
check tech sheet located inside washer cabinet at bottom. remove lower kick panel to access.
2answers
Red light bottom right corner
this means some type of hardware failure and yes it can happen from time to time depending on whats wrong with the system...well i did some quick reserch and they say its a hard drive issue...so luckily you will only have to pay 100 dollars instead of buying a new system....unless you vae a warranty...hope this helps
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
