Question about Sunpentown Heating & Cooling
I have a WA-1230E and it was working fine yesterday. When I returned to the room, it was off and only the "comp" light was flashing. No button would have any effect and only unplugging the unit will turn it off. I did clean the filters which were very dirty, nearly clogged but the unit will not turn on? Solutions?
The flashing light indicates the water tank is full. Unscrew the cap at the back of the unit then pull the plug to drain it into a pan. Replace the plug and cap. The unit should work as normal.
Posted on Jul 07, 2008
Hi, we have a wa-903 air conditioner that doesn't cool as much as it should. I have cleaned the filters. What else should I do? Thanks
Was it ever satisfactory? If not maybe the room size, conditions, location are to blame. If it was working fine before then the only issue might be with a freon leak resulting in low refrigerant.
Jun 17, 2017 | Heating & Cooling
Pause light is constantly flashing
Pause is not a term ive seen on a dehumidifier , but one would assume that its waiting for something to occur in that mode , and with these the only logicial reason to wait is to "wait" for Moisture to return to room , maybe your room has been voided of %rh to the setting on unit and its waiting for more water to return ??
Dec 13, 2014 | Dehumidifiers
Machine stopped - alarm light flashing
just saw this yesterday. remove the top rear paper guide. on the left side between the tractor feed and the input slot for the paper, there is a sensor flag that pivots. check for paper scrap caught under the flag. it prevents the flag movement, causes a paper out alarm.
Jul 13, 2012 | OKI MicroLine 420 Matrix Printer
I have a Panasonic TH-58PE75U, that I purchased Nov. 2007. Yesterday it was working fine; however, I left the room and returned. The screen was completely dark (out), but the audio is working fine. I...
When you turn the plasma on do you get a solid indicator light on the front of the tv? You also get sound just fine, but a blank screen and no picture. I'm still looking for a definite answer, but I repaired a Hitachi 42edt41a that had the exact same problems. On that plasma there was an X-sustain board and a Y-sustian board that needed to be replaced. Hopefully someone else can give their assistance as well.
Dec 08, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Air conditioner wont cool below 75 degrees
Hi, Does thermostat on a/c goes lower than 75? put hands close to air coming from a/c is it cold, like 50, if it's cold like 50, maybe you a/c are to small for space, check a/c b.t.u's ( british thermal units) how many b.t.u's is your a/c , there are a chart, for size of room and how many b.t.u's you'll need to cool space (room), or possible if air coming from a/c are 75, your compressor could be short cycling, it hard to tell when fans are working, listen carefully to hear if compressor makes clicking sound, place thermometer close to a/c vent and let me know temp, maybe there's freon leak. let me know temp of air coming out from a/c, then i could tell you exactly what's problem. good luck.
Aug 11, 2009 | Sunpentown WA-1230E Air Conditioner
My Sunpentown WA-1220E portable air conditioner is not working. Comp light is flashing (red light). Any idea what could be wrong?
Sounds like compressor failure, overheat or some other reason can't get started. Make sure everything is clear and unplug and let it set for a while and try again. If that don't help take it to shop.
Jun 28, 2009 | Sunpentown WA-1220E Portable Air...
How do you get this machine to drain water better?
You should raise the machine so that it drains better.
Jun 24, 2008 | Sunpentown WA-1230E 12,000 BTU Powerful...
Heating & Cooling Logo
406 people viewed this question
Top Sunpentown Heating & Cooling Experts
Dan Webster
Dan Webster
Steve F
Pete Norton
Are you a Sunpentown Heating and Cooling Expert? Answer questions, earn points and help others
