Question about Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator
Maytag MFI2568AEW Not Working
We just got the Maytag MFI2568AEW, we plugged it in, the lights inside turn on, but the display does not. If you push one of the buttons all the lights will turn on. The compressor has not kicked in yet and the fridge has been plugged in for ober 30 minutes. Is there a combination of buttons to push, a hidden on switch or what?
  • Anonymous Dec 06, 2008
    EL PANEL DE CONTROL QUE SE ENCUENTRA A EN LA PUERTA SE DESPROGRAMO Y NO SE COMO VOLVER A PROGRAMARLO
  • 883 Answers
SOURCE: maytag french door fridge model mfi2568ae
unplug it. wait 15 minutes. plug it in. any change?
Posted on Jun 06, 2007
dididsaythat
  • 291 Answers
SOURCE: maytag model RTC17A
how is freeezer side doing? Do u have any frost build up in freezer back wall and is you fan in freezer blowing?
Posted on Sep 02, 2007
SOURCE: Fridge freezer has power but
You may have a bad start relay or capacitor on the compressor.
Posted on Jul 10, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Maytag, side by side refrigerator stopped working
Check the thermostat which is located in the top left hand coner of the refrigerator. Also check the relay on the compressor to make sure it is not staying open all the time. Also there has been a huge recall on Maytag side by side refridgerators made between 2001 and 2005. I would also try calling Maytag and get the problem fixed by them by recall
Posted on Apr 13, 2009
  • 572 Answers
SOURCE: water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Posted on Feb 11, 2010
Water will not dispense.
have you try replacing the water filter if that does not help check your water solenoid valve.
Feb 22, 2015 | Maytag (MFI2568AEW) Bottom Freezer French...
I have a Maytag MFI2568AEW refrig. and the ice maker is not filling up. I checked the dual water valve and it is not getting power to open the solenoid valve with the ice maker switch on and the ice bin...
On typical ice makers that signal comes from within the ice maker. It sends a signal from the ice makers thermostat and the ice maker begins to pre-heat the ice cube slots and the ice rake begins turning to push the ice out of the slot's and into the ice bin. The last function is to refill the water with a signal to the dual water control valve that last about 7.5 seconds. Once the ice maker senses the water is frozen again it begins this cycle again. Here is a refrigerator parts PDF for your model=> MFI2568AEW and on page 10 you will see part=> 627985 Pin Style Icemaker Thermostat
Adhesive - Alumilastic (Cement)
That is just silicone rubber you can also get locally. If you have any other questions please let me know, Thanks, Sea Breeze
Y13068002 or Repair Clinic 1266731 Ice Maker Assembly
Feb 17, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Water and ice stopped working. Display screen flashes
If you don't mind following with me on this I can help you locate the problem even if it requires me calling Maytag. I am a Whirlpool Technician and have access to all of their material and phone calls. You may begin by looking below at the wiring information at this link. Then click HERE if you should lose me. Then let me know when ready. All you need is someone that will follow my directions so we can find were the low voltage stopped at the dispenser control. You will need an OHM/Voltage and a few tools, The problem is most like here=> 67006294 or 1187173 Electronic dispenser control kit with thermistor. Or here=> 67006293 Keyboard Overlay
It could also be a loose connection at pin-plug where wiring comes through cabinet to door.
I am ready when you are, Thanks Sea Breeze
MFI2568AEW MAYTAG REFRIGERATOR WIRING INFORMATION
Feb 11, 2011 | Maytag (MFI2568AEW) Bottom Freezer French...
Filter needs changing
You don't need a plumber. The filter is located inside the fresh food section, in top-right corner. There is an elongated cover with a tab in front. Press the tab towards the back of the fridge slightly and pull the cover front down. There is your filter. No need to turn the water off either. Just twist the filter counterclockwise and it will pop off.
The part number of the filter is UKF8001, can be purchased in any appliance parts store, for example here. "New10"coupon takes 10% off.
Nov 09, 2009 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag refrig (french door) water and ice on door stopped working at the same time.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Maytag (MFI2568AEW) Bottom Freezer French Door Refrigerator Logo
199 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
