EP 1083 service /reset codes
Hi, I bought a Minolta EP 1083 and the maintenance counter on my Minolta EP 1083 has reached its limit and I wonder how I can reset the codes and get it working again.
  • dan-hagman Jul 17, 2008
    I don't get a counter with a negative sign when I press 4 to enter counter mode.
  • dan-hagman Jul 31, 2008
    When I pressed stop-0-stop-1 and then pressed 4 on the keyboard, I got the three digit counter (the zoom procentage display) displaying the digits 650, and the two digit counter (for number of copies), displayed two zeros.
    Then when I had the machine open (the upper part tilted up) and again pressed stop-o-stop-1, and pressed 4 to enter counter mode and then pressed the cancel key, both counters were zero'ed, but the lamp for the developer is still on.
    Sniper:
  • 57 Answers
Press on keyboard, stop o stop 1. Press 4 to enter counter mode., the first counter should be the pm, displaying a counter with a negative sign. Press cancel key to reset to 0. Exit service mode by pressing panel reset 2 or 3 times and you should be back in business.
Posted on Jul 14, 2008
My sharp MX-C311 shows maintenance required Code TA
Hi, TA code refers to maintenance all counter has reached its specified limit. This usually means all the consumable parts have reached the end of their service life. If you have a maintenance contract with a Sharp dealer then they should replace all the units that require replacing & reset the maintenance counters for you, if you don't then, if the copy quality is still ok, you should be able to continue to use the machine as normal.
Hope this helps.
Dave.
Oct 15, 2017 | Sharp Office Equipment & Supplies
How to solution services call m1 for Konica Minolta 164
11.5.4 MAINTENANCE COUNT.
A. Use
• To display the count of the maintenance counter.
• When the counter reaches "0", maintenance call M1 or the service call will appear, according to the setting on MAINTENANCE COUNT. of SERVICE'S CHOISE.
See P.85 below
e
• To enter an appropriate counter value (0 to 999999) as the tentative maintenance time.
• Specify the setting on maintenance counter to "1" or "2": If the maintenance life is
reached, the maintenance call (M1) or service call [Call Service (M1)] will appear.
"0" : Not counted
1 : Counted (The maintenance call display is given when the counter reaches 0.)
2 : Counted (The service call display is given and the initiation of any new copy cycle
is inhibited when the counter reaches 0.)
NOTE
• The counter value is decremented until it reaches -999999 even after it has
counted 0.
B. Procedure
• The default setting is 0.
• When "1" or "2" is selected, a screen will then appear to allow the counter value to be
entered.
• To clear the count, use [CLEAR DATA] of the SERVICE MODE.
Procedure below to enter::
11.2.1 Starting procedure
1. Press the Menu/Select key.
2. Press the following keys in this order.
Quick Settings Quick Settings left arrow twice the right arrow then left arrow
11.2.2 Exiting procedure
• Press the Back/Stop/Reset key as many times as it is required to display the initial
screen.
11.2.3 Changing the setting value in SERVICE MODE functions
1. Select the desired item using [??/??/??/??] key.
2. Select the setting value using [??/??/??/??] key.
3. Validate the selection by pressing the Menu/Select key.
4. To go back to previous screen, press the Back/Stop/Reset key.
Sep 29, 2016 | Konica Minolta Office Equipment & Supplies
Minolta EP 4000 error M2 how to solve this problem?
Sir, Need to dump the waste toner box and clear the waste toner box counter in service mode. Stop 0 stop 1. select Counter clear Waste toner count count should be set to 180,000 copies for overseas
Panel reset for exit service mode
Apr 24, 2016 | Minolta Office Equipment & Supplies
How can I remove code m2 in Minolta 215 coppier
Hi fatma, this is most likely a maintenance counter error. You need to reset the maintenance counter. Do so by pressing: Select [Service Mode] [CLEAR DATA] [PM COUNTER]
This should enable the printer to start working again.
Hope this helps!
Oct 28, 2014 | Office Equipment & Supplies
Maintenance call indicator light is blinking on my Minolta 1083, how do I get rid of it?
The light is a counter inside the copier that needs to be reset by a service tech after replacing the drum & developer in the copier. If it is working let it go till there is a problem.... Good Luck
Oct 09, 2012 | Minolta EP1083 CS/PRO Copier
Minolta ep 4000 Copier shows: Call Maintenance M4
stop 0 stop1 sets the machine service mode. select consumable clear the copy kit counter
Mar 31, 2012 | Minolta EP4000/5000 CS/PRO Copier
Help please - my Minolta EP 1083 won´t work properly.
did you try to cleane the optic section ,make sure to remove the lens cover and clean mirror on the right side too underthe len cover,2 remove drum check and c if toner on drum?
Sep 24, 2008 | Minolta EP1083 CS/PRO Copier
My minolta 1083 forgot how to count
minolta normally use the following code to get into the service mode so you can reset back to defaults. Be warned you can damage the machine further by doing this.
A. Procedure
1. Press the Utility/Counter key.
2. Touch [Details] on Meter Count display.
3. Press the following keys in this order.
Stop → 0 → 0 → Stop → 0 → 1
This all depends on age of machine.
Thanks Jason
Aug 16, 2008 | Office Equipment & Supplies
Service
it means it time for the cleaning web, and waste toner bottle to be replaced. once you replace it you can reset the indicator.
thanx,
mikey
Mar 19, 2008 | Minolta EP4000/5000 CS/PRO Copier
Please help
It means that the maintenance counter has reached its limit or you may have an error. If it is time for maint. then usually you replace the drum, cleaning blade, and developer (or the entire process unit) and reset the counters in service mode if the parts do not reset the counts automatically. Or you could simply reset the codes and not preform any replacements. Could you provide a bit more detail on the exact model number (EP-2010, EP-2030, etc...) and such and I can provide you more information on how to rectify the situation.
Jan 14, 2008 | Office Equipment & Supplies
443 people viewed this question
jasbo
jasbo
