Question about Kitchen Ranges
Whirlpool electric range model rge-6700. Oven lock is locked with oven door open. how can i disengage?
  • Anonymous Mar 30, 2014
    Oven door smashed
  • 868 Answers
Good the door can open ! Replace the door latch assembly.
Please Rate this!
Posted on Jul 06, 2008
I have a frigidaire gas range model FGF379WECG, the control panel say that my oven door is locked, but the door opens, when I turn on the oven to bake or broil the lock engages and disengages for about 30...
Good Afternoon Donna, thank you for your post!
Let's try resetting your range by either unplugging it or flipping the household circuit breaker off. It is important to wait approximately ten minutes and then turn the unit on. Is the unit still advising that the door is locked? An experienced service technician may need to further evaluate this issue if it was not resolved with the power reset. In this case, your unit may possibly be experiencing a communication problem with the EOC (Electronic Oven Control) and door latch assembly, or a potential wiring failure.
Sep 29, 2013 | Frigidaire Gallery GLEFM397DS Electric...
F9 error code while cleaning oven
F9 = oven door lock failure
Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If that looks good, replace the lock. What is the complete model number? Look in the oven door area.
Feb 14, 2013 | Whirlpool SF315 Dual Fuel (Electric and...
Manually unlock oven door
1. Defective potentiometer. Test and replace if defective. 2. Replace UIB 3. Check for moisture contamination in potentiometer.
Sep 03, 2012 | Frigidaire FEF336BC Electric Kitchen Range
I have a double oven electric whirlpool oven and turned self cleaning on and by mistake as it was loking i opened the door and cannot turn on its showing locked the opens and i can not turn on oven
Hi, Door locked flashing after the attempt of the cleaning cycle. After taking the oven appart to get the door open, I began troubleshooting. I discovered that the door lock motor failed in the locked position. I opened up the motor and found the magnet inside was cracked! The coil winding for the motor was also open. Hope that helps! While your waiting on the new part you can trick the oven by using a zip tie on each of the two lock motor micro switches to hold them closed and remove the lock lever. The oven will work just fine.
bye
Jul 05, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Locked oven door
What make and model? Your oven may have a latch release button on the control panel. Or you could try setting your controls for use again and then turning them off while holding the door in. Were you baking or self-cleaning? Is the range plugged in? Some locks will not disengage if there's no power.
Nov 16, 2009 | Kitchen Ranges
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Kenmore 790 Oven Locking mechanism problem
hold down the stop/clear button for 3+ seconds
Jan 13, 2009 | Kitchen Ranges
F5 error
F5
Board failure
Need to Replace control board (also called ERC or clock).
If you need to open the door, it can only be done by dismantling it.Do not apply force on the door.
Here is the manual link, in case you need one.Am sorry but whirlpool manuals are mostly not free online.and this is one of the cases
click here for manual
please do post further comments if you need any more help.Am glad to help you out.
Jan 13, 2009 | Whirlpool GR399LXHS Electric Kitchen Range
Self cleaning oven directions
MAKE SURE OVEN IS EMPTY LOCK OVEN DOOR AND TURN OVEN SETTING TO CLEAN, IF YOU HAVE A VENT TURN IT ON THERE WILL BE SMOKE! LET RUN TWO HOURS,TURN OFF,LET COOL BEFORE TRYING TO UNLOCK IT (WILL NOT UNLOCK WILE STILL HOT!) OPEN DUST OUT ASH ITS CLEAN!!!
Dec 07, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Kitchen Ranges Logo
243 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
