TV turns itself on, keeps changing it's own channel
We've had this TV for 1.5 years, and it has been mostly fine.  But recently it started turning itself on at random times.  If it is left plugged in, it will turn itself on within a hour or two.
Obviously, we can just unplug when not in use.  But now it is also changing it's own channel.  I have it programmed to stay on one channel for the satellite, so it just makes the screen go blank for a second and then the channel number shows on the screen.  It's annoying when it does this over and over in a short amount of time.
We've tried calling the company and they are no use.  It is off warranty.  Any ideas for how we might be able to fix?
  • unohisname Aug 10, 2008
    I had my tv for 2 years I barely used it before it was my mom's she gave it to me when I moved.I keep changing channels by it self what should I do.
The problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Posted on Sep 07, 2008
I have the same problem with my Pioneer plasma. It randomly changes channel inputs. I have tried removing batteries form all remotes (sky,TV etc), switching off broadband, laptops phones etc. I now think it may be down to my Nokia E66 mobile phone. It hasn't happened whilst I have the phone switched off. Any help would be appreciated.
Posted on Mar 02, 2010
  • rayneal Aug 03, 2011
    My neighbpurs house alarm system was faulty and when she had it repaired the channel switching stopped for about 6 months. Unfortunately the TV has started to randomly change inputs again (and I don't believe there is a problem with her alarm). It was nothing to do with the Nokia. The changing of inputs is totally random. Some times it is every few seconds, then it changes to occasional and sometimes no changes for a few days. Aaghhhhhh.
I had a very similar problem with a flat screen tv I keep in the bedroom. Suddenly one day it was difficult to get the thing to work at all from the remote control and once you moved to a different channel or changed the volume it would continue to change going around the channels or moving the volume to the maximum or minimum. this happened using the remote or the on board controls. I checked the aerial & power supply both were OK. I noticed if I moved the tv to the floor it stopped happening, finally I moved the tv to the other side of the room & this cured the situation. Cause unknown
Posted on Oct 19, 2011
Try replacing the batteries in your remote control unit
Posted on Oct 15, 2008
Sony bravia tv constantly changing channels
Is the tv new or has it started to do this recently ?
Try to eliminate the obvious.
Does the remote continue to flash when you release all of the buttons? Is it a stuck button ?
If you cant' see the remote output, try using your smartphone camera. Most phone cameras will capture infrared light ( invisible to the eye). Aim the remote at the camera and see if you can see the flashing light, which is data being sent to the tv. When you release the buttons does the flashing stop ? If so remote is ok
Next turn all of the lights off in the room with the tv. Also turn off any lights that may shine in from other rooms. Try using the remote
If your tv functions normally, you may be getting interference from your lighting. Some LED and CFC fluorescent lights flicker at a rate which may be close to the remote IR output frequency.
If turning off the lights fixes the issue, turn on each light to isolate the issue. Replace the bulbs with ones from different manufacturers.
Let me know
Oct 24, 2017 | Sony Bravia KDL-26V4000 26 in. HDTV-Ready...
Keep changing channel without any input
Most of the time it is the front contact switches Dirty clean them with contact cleaner or replace contact buttons on front panel board 29 cents each Call Mats 1-800-628-1118
Nov 19, 2009 | RCA F36673ET 36" TV
Cuts on and off and changes channels
change your tv chanel program button or its problem in programing devise or video frequency
Aug 28, 2009 | GE 31GT740 31" TV
Tv turns itself on and off
IC pin is dry in Micropro. IC
Jun 10, 2009 | Televison & Video
Black Box
You have inadvertently activated one of the closed-caption modes called T1 or Text 1. Find out how to turn the closed-captioning off and on and you'll be able to turn this off.
Mar 30, 2009 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
TV turns on and changes channels on its own
Keeps changing channel
Check voltage on D12 if below 4.8V then change
Changes channel or volume adjusts by itself
Check S900/1/2 on pcb H1, alternatively this could be due to failure of IC005 (CD4052BCM-FL63) on pcb A
Oct 17, 2007 | GE 31GT740 31" TV
TV turns on and off by itself
you need change memory ic 24C08 near microprosessor.
Oct 10, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
4,811 people viewed this question
Top Televison & Video Experts
