Question about Garmin StreetPilot c340 GPS Receiver
No volume on Garmin C340
Voice volume was OK one day. No voice now, all I get is some static sounds.tried resetting but no luck.
  • arunjotshi Jul 18, 2008
    I tried everything but did not help :(....
Thanks a lot for the helpful replies. I believe this is the case and I need a "trip to Garmin for repairs".
Best regards,
Posted on Jul 18, 2008
  • 52 Answers
Some of this may be stuff you've already done, but you didn't say what "reset" you did.
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get teh unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
If you have done these, it 'sounds' like your TTS has a problem. Have you tried changing the voice? If this doesn't help, you may need to force a reload of the latest firmware through WebUpdater, or downloading the latest firmware and updating it manually.
Hope this helps!!
  • Ron Chinnery Jul 18, 2008
    If the "noise" comes at a rate and time that sounds like it could be "bits & pieces" of real speech, it's likely that the audio amplifier chip has been blown.
    If it's just "static" that has no relevance to speech and makes sounds at any time (not just during speech), then it's more likely either a firmware problem, or the audio D-A.
    ...either of whiich means a trip to Garmin for repairs
No sound
Turn the volume up. Turn on the Garmin Nuvi. Tap the "Volume" button on the "Where to?" or home screen. Move the slider for the volume up.
Unmute the Garmin Nuvi. Tap the "Volume" icon again. Uncheck the "Mute" option, if it is currently checked.
Make sure the voice is not faulty. The navigation instructions are provided by a voice.To verify whether or not the present voice is faulty, you must switch the voice. Power on the Nuvi and tap the "Tool" icon. Tap "Settings" in the Tool menu. Tap the "Language" option and tap the language you want. Then select another voice to use. Now go back to the home screen and enter an address into the "Where to?" option. See if you can hear sound now.
Update the Garmin Nuvi with WebUpdater. Download and install WebUpdater from the Garmin website (see Resources). Launch WebUpdater on the computer, and connect the Nuvi to the computer with the USB cable. The software will detect the Nuvi and locate all updates for the device. Confirm that you want to update the device when prompted and WebUpdater will download the updates to the Nuvi.
Reset the Garmin Nuvi. A master reset will restore the Nuvi to its factory configurations and delete all favorites and waypoints that have been added. Power off the Nuvi and unplug it from any power source. Hold your finger down on the bottom right corner of the Nuvi screen, at the same time power the device back on. When asked "Do you really want to erase all user data?," remove your finger from the bottom corner of the screen and tap "Yes." The device will reset and sound should be restored.
Here is a direct link to the user manual >>
Jan 06, 2012 | Garmin Nuvi 1490LMT GPS Receiver
Sound does not work on Garmin Street Pilot GPS
is sound enabled in the settings? I will get you instructions if you provide me with your model.
also you could try reseting the device, there is a reset hole or button. Model would help.
Oct 23, 2008 | Garmin GPS
It just stopped talking. No voice directions, on
Hit the menu buttom, go to settings, then go to volume and see if it is muted. Sounds like the mute or volume down button got inadvertantly hit and turned down or muted. If this does not work, turn the unit over and look under the fold up antenna for a reset button. Depress this button until the unit restarts and should reset the unit back to factory default settings and get you on your way. Good luck!!! If these don't help you, call the garmin support number at :1-800-800-1020. Hope this helps!
Aug 01, 2009 | Garmin nuvi 885T GPS Receiver
Garmin 760 - No Voice Directions
Go back into your tools and settings and re select the voice of american jack and see if it comes back on.
I lost the voice 2 days ago while on a trip from tenn. to florida and this fixed it. we never shut off the voice but somehow while using bluetooth or FM trans it shut off voice transmiting.
Dec 14, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
I had the same issue. My C340 fell of the dash and the volume control (potentiometer) broke off and was rattling inside the case. I tried to find a replacement (103B stamped on the pot) but have not been able to find one. I tried a mini 10K ohm pot from Radio Shack, but the posts were not properly positioned for the circuit board inside the Garmin.
I took the easy way (for now) and simply strapped the two control points together with a piece of wire giving me maximum volume. Orient the circuit board with the missing volume control to at the bottom right. The control mounts with 5 points, two on the right edge of the board are simply physical mounts. There are three other connection points just to the left in a slight arc. The top and bottom point have holes to place the legs of the pot. The broken off legs may still be in these holes. Solder a piece of wire between the top and bottom points. Be careful since the solder pads (to the left of the holes are very delicate.
Not an elegant filx, but you get the voice back.
Jim H
Sep 03, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin nuvi 760
Go to tools-settings-language-voice and make sure it is set to "American English-Jack (TTS) or to American English-Jill (TTS)
Aug 10, 2008 | Garmin Nuvi 760 Handheld GPS Receiver
GPS has no sound.
The screws are hidden behind the front faceplate.
The faceplate snaps off by a fingernail slot located directly below the GARMIN logo on the front panel.
Jun 23, 2008 | Garmin StreetPilot c340 GPS Receiver
Directional voice not operable
did you unintentionally turn the volume down or mute the volume?
Jun 15, 2008 | Garmin nuvi 200W GPS Receiver
Voice quit working
I assume you have made sure the volume knob on the right side of the unit is adjusted all the way up. Have you also made sure the volume icon has the volume up? Does the unit make any sounds at all?
May 18, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 startup
The clue is that the voice is slowing and low pitch. The main processor time base has slowed... which means everything will be buggy.
First try would be to Reset the unit. Remove the face cover (GENTLY pry it loose by the fingernail groove directly under the GARMIN logo), press the RESET button, then reattach front cover... this is covered in the owners manual, available online.
If not, then it sounds like a hardware failure... time for a 1-800-800-1020 call (their customer service number)
Aug 06, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
69 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
