Question about Akai LCT3201AD 32 in. LCD Television
Power supply was this by chance for the akai lct3201ad?? this tv is only a year old and had two techs out and they cannot fix. i feel its a pwr sply patti
  • 3 Answers
Hi, this was for the TV model LCT3201AD. My TV was about a tear old when the TV went out. It may be that the power supply is out. TIto
Posted on Jul 06, 2008
Need power supply board for akai model lct32d do not know if same as lct3201ad ?
You can have more than one manufacturer of power supply for the same TV model, best thing to do is to actually get the printed numbers from the actual power supply to match it correctly.
Here are the parts for LCT3201AD, see if it looks right: http://www.shopjimmy.com/catalogsearch/result/index/?q=Akai+LCT3201AD+&limit=200
LT32D is not listed.
Dec 24, 2009 | Akai LCT3201AD 32 in. LCD Television
Akai LCT 328STA,Comes on Akai screen appears then goes off.
Akai LCT 3285TA (notice the "FIVE") uses the MLT169A Power supply. This is available from shopjimmy.com for about $100.
Jul 22, 2009 | Akai LCT3201AD 32 in. LCD Television
Will not come on
Loook at power supply board. Chances are you will see two to seven capacitors with the top slightly puffed. Replace all capacitors you see like that and your TV should pwer up again.
Mar 13, 2009 | iLO LCT32HA36 Television
I have a 32" HD AKAI TV that keeps turning itself off
If the service shops didn't charge people $200 to fix this I would not post.. But since they do - here's the $8 fix.
If you are electronically inclined, replace the three 1000uf 16v electrolytic capacitors in the power supply board located above the power switch. They are likely bulging out at the top and failed. They are the three in a row at the top - center of the board, located between the two black heat sinks. Make sure you get caps rated for 105c degrees! I recommend replacing them with 1000uf 25v caps. 35v caps will work but might be a tight fit as they are larger diameter.
Should cost you about $8 for the parts shipped. You can get them from partsexpress or digikey or any good local electronics store. Your local radio shack may have them but they won'y be 105c and thus may not last long.
Not handy, ask around, there is usually some electronic tweaker guy around that will install them for a few bucks.
This has solved the turns on / then off problem every time in the 3 I've done.
Oct 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Power supply/ no output voltage
Actually i haven't fixed the problem as yet but i did find some info that would help me to fix problem.
I went to google and entered keyword,,, Electronic parts,,there came up a page,,and i went to several manuf sites till i found a replacement transformer,,then i disassembled the power supply and am now waiting for a replacement transformer.
Sep 21, 2008 | Boston Acoustics MicroMedia Computer...
Power supply
I found THIS weblink having info for Akai LCD TV parts. Please check it as it might help you.
Aug 06, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai TV with Megmeet power supply
Hi artoo
if you want you can fix the power supply. i know service tech who fixed my tv power supply. His email is jah2mil@hotmail.com.
Apr 10, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai lct3201 ad power supply
The MLT169A is a version number issued by MegaMeet in asia who built the supply. The correct part number for the SMPS for that unit is: E7802-005008 and unfortunately they are no longer available... However, there is some good news, those supplies can usually be rebuilt but you need to have the equipment, knowledge to make the repair...
Bill
Mar 26, 2008 | Akai LCT3201AD 32 in. LCD Television
AKAI LCT3201AD Tv will not stay on when you turn it on the light changes to green and then in about 10 seconds turns red again. TV is 1 1/2 years old. For awhile we were able to unplug it and plug it back...
I have just repaired one of these sets for the 2nd time. The problem is definitely the Capacitors on the Main Power Supply Board. If you are handy, you could replace them yourself, or You can send your board to me and I will make the repair for you. Akai initially used what I feel are sub-standard Capacitors on these boards, and I have found that by replacing most of them, this problem can be eliminated. My email address for repairs is Lakers4life42@yahoo.com
Mar 14, 2008 | Akai LCT3201AD 32 in. LCD Television
Akai LCT3201AD 32 in. LCD Television Logo
122 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
