Question about Palm TX Handheld
Palm TX power button and touchscreen
This is my second palm TX and both have the same problem. The touchscreen goes out of calibration and the power button does not respond when I try to turn it on
I have reset the touchscreen in preferences many times. Sometimes it will let me finish what I am working on and sometime I have to recalibrate it.
The power button does not respond at all sometime. None of the buttons do... so I remove the SD card and that brings it back to life..??
What can I do to fix-it?
  • shane_soule Dec 31, 2008
    I cannot do a hard reset because the power button does not respond, I have to do a reset to turn it on
  • Janet11 Dec 29, 2014
    That IS a problem, and the reason I finally gave up on the TX.
We have three TX's in our family with non-working power buttons. I downloaded the program Au Dodo http://www.freewarepalm.com/utilities/audodo.shtml and simply now use the far left button (button 1) as my 'power' button. It works wonderfully.
I haven't found out how to fix the calibration problem, but power on/off has been totally fixed. Good luck for you.
Posted on Dec 30, 2008
The touchscreen does not work. It selects the wrong area on the screen. I am on the business trip in California, Menlo Park 94025 and will stay till October 10. Where in San Francisco area can I repair my...
try screen calibration you can find it in prefs. if not solved, try installing powerdigi. it calibrates screen almost perfectly! it's not free though, you can try first the demo version :)
Sep 12, 2010 | Palm TX Handheld
Palm TX is going crazy
It sounds like something I had trouble with before.
There is probably either a pinch in the unit (like it got slightly kinked when dropped, or there is some debris under the edge of the screen causing it to calibrate or touch improperly. I would suggest taking your drivers license and run it just under the edge of the frame. It should dislodge any problem matter and allow it to work properly but you will probably need to recalibrate your digitizer. Good luck!
Dec 21, 2009 | Palm TX Handheld
When trying to sync, error message reads (sys 0505)(0,841).What can I do? For Palm TX handheld
Try to perform a System Reset (see article linked below). If it works to break the loop, you should then be able to delete the offending "My Palm" software and perform a Hotsync to backup your data to your desktop.
If that doesn't break the loop, you'll have to perform another Hard Reset. Sometimes, a Hard Reset takes a couple of tries to get it right, since it's easier to do it wrong than to do it right.
This article discusses the various types of Reset for different Palm devices:
http://tinyurl.com/zlwza
Until you break the TX out of its loop, you won't be able to get the data from it.
To see the Palm OS version running on your TX, enter the Menu, select Info, then Version.
To Get Out Of A Loop:
  1. Perform a SYSTEM RESET by doing the following:
a) Press the UP Button
b) And THEN press and release the RESET Button
c) When you see the second Logo (Palm Powered) release the UP Button
d) Now check if your SYSTEM RESET worked by going to Beam Receive. If it goes back to Off even after you put it to On it means you were successful
2. Now Perform A SOFT RESET by pressing and releasing the button in the back once
  1. After a soft reset, a logo screen appears, followed shortly by a Preferences screen asking you to set time and date.
  1. If a soft reset does not break it out of the loop, you may need to try one of the other resets below.
  1. Do an INCOMPLETE HARD RESET by holding down the power (on/off) button on your device.
  1. While holding down the power button, Press and release the reset button on the back of your handheld device
  1. Keep the power button pressed and release it when the “Palm Powered” logo appears.
  1. A message will now appear warning that you are about to “Erase All Data”. And this will happen if you press UP or DOWN.
  1. Instead you press left or right to begin a soft reset, leaving your data intact.
  1. Your device will then take you through a series of screens to calibrate the digitizer and verify the time and date.
Sorry this was so long, I tried to put everything down that might help you.
Aug 03, 2009 | Palm TX Handheld
BOTTOM OF SCREEN NOT WORKING,
This happens a lot with Palm digitizers. The only permanent solution is replace the plastic digitizer with an upgraded glass type. Before considering that, see if removing screen protector helps. (yeah, didn't think so. Worth a try!) Try Powerdigi, a better calibration program. Get it from http://www.palmpowerups.com
It worked for me.
Jul 03, 2009 | Palm TX Handheld
Palm TX Touchscreen does not work
Search youtube for Palm TX Digitizer Replacement and Palm TX Take Apart Direction. If you think you can do it, or know someone who can, you can order a replacement digitizer on ebay for from somewhere like www.pdaparts.com.
Before ordering the part, you may want to start by opening the palm and cleaning the connecting ribbon cable contacts to make sure that a loose cable or oxidation has not caused your problem.
Feb 03, 2009 | Palm TX Handheld
Touchscreen
I had a similar same problem. It occured when pluging or unpluging in the USB cable into the bottom of the Palm TX when the other end of the cable was already pluged into a live USB port on my PC.
The solution was to make sure the cable is unpluged first from your PC before you plug or unplug the cable into the bottom of your Palm TX.
Sep 09, 2008 | Palm TX Handheld
I have a Palm TX. 3Years old. 6 Months ago had to calibrate Touchscreen every day. 2 months ago had to calibrate touch screen 2/3 times a day. Recently can't calibrate touch screen. Targets go into loop...
Same happened to my 3 month old TX. I just recharged it, and all was OK! Sounds strange at first, but in my hometown, it is very humid, so maybe it got some moist inside and that caused some variations in the power or battery or voltage... dunno, maybe you need some cleaning, or try to calibrate while plugged.
Hope to be useful!
Jul 03, 2008 | Palm TX Handheld
Touch Screen does not work at all
My touchscreen was acting batty, not responding where I was touching. The solution for me was to:
1. remove my screen protector
2. Take a piece of paper, fold it in half, and scoop under the lip the case where it holds the touchscreen in to fish out debris that were distorting how the digitizer recorded.
Nov 14, 2007 | Palm TX Handheld
Touchscreen no longer works
Well watch this video and after you follow the directions get the screen and find the glass like cover and remove it from the screen bend it in a very lightly way, then put it back on and put the PDA back together and BAM.
Nov 07, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm TX Handheld Logo
287 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
Don Eagan
 steve
steve
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
