Question about Graco Ultra Deluxe 5-in-1 4605 Crib
I need upper track (plastic pieces) for my Graco 4 in 1 Sleep System Model 4600CL. There are two lower track pieces, and two upper track pieces. All I need is ONE of the upper tracks. Please help!
  • segan1212 Aug 17, 2008
    I need upper and lower track (plastic pieces) for my Graco 4 in 1 Sleep System Model 4605W. There are two lower track pieces, and two upper track pieces. Please help!
  • 3 Answers
I have a Graco 4 in 1 Ultra Sleep System Model 4600 CL. There is a recall on this model for the track guides breaking. The website is www.simplicityforchildren.com You can get a replacement track system for free and you can also order parts at 1-800-858-8323.
I also have the complete instructions for assembly of the crib, toddler bed and day bed.
Posted on Aug 02, 2008
I Have lost my instructions for my GRACO 4 IN 1 ULTRA SLEEP SYSTEM MODEL 4600CL can you help me
I have a copy of the instructions you need. I will try to scan it and attach it.
Aug 16, 2010 | Toys
Instructions for Graco 3 in 1 sleep system crib model 8740
Most if not all of the simplicity brand drop-side cribs have been recalled, including the Graco 8740.
Here is the CPSP link reguarding this crib:
http://www.cpsc.gov/CPSCPUB/PREREL/prhtml09/09260list.html
http://www.cpsc.gov/cpscpub/prerel/prhtml07/07307.html
According to the CPSP information the company appears to be out of business to some degree and are not providing repair kits.
If you know where you purchased the crib, check to see what their policy is reguarding recalled baby products.
We had purchased ours at walmart almost 8 years ago and were able to return it to another store in a different state for a full refund last summer. They did not need a reciept received, they just needed the manufacturer label on the part that the mattress lies on.
Because ours was older, the customer service clerk did have to work hard to find the crib in their system, but once she did, it was not problem at all.
Toddler conversion on at least some of the cribs is simply to remove the front dropside from the crip (you may want or need to unscreen the dropside tracks to remove the actual side) Then screw the toddler rails to the front side of the crip. There should be pre-drilled holes for the toddler rails, if there are not then you may have the mattress support on backwards.
Jun 08, 2009 | Graco Apsen 3-in-1 8740 Crib
Instructions
need plastic round pieces that holds head and side together
Mar 26, 2009 | Graco Ultra Deluxe 5-in-1 4605 Crib
2000 bonneville, one rear cable on the left rear power window
On my 2000 bville, all four of my windows came off. All four had the same problem. the upper and lower cables go around the pulleys then connect to a plastic piece connected to the track. This plastic piece breaks and lets the cable free. I fixed them all by removing motor assembly and reconnecting the cable with coat hangar wire. Kind of a redneck fix, I know, but beat paying 160 dollars per window for a new assembly that would probably break again!! Good luck!!
Feb 26, 2009 | 2000 Pontiac Bonneville
Upper and lower tracks for crib
contact graco as the crib is recalled, they will send u new ones for free.
Aug 18, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Drastic Need for 2 Upper Tracks...
if you have the conversion kit for the crib to convert to a toddler bed, you should also have the white caps that go one the end of the guard rails for the toddler bed. I found with mine that they are the same ones as that are on the stationary side of the crib on the back side. if you do not mind having a crib with out a drop side you can remove both tracks and take those pieces and make it a stationary crib by merely following the way the rear side is put together. I have done it with mine as a guide was broken on mine. there should be four caps in the conversion kit that go on the two rails on the front side when you convert to a day bed. I figured out that they are the same as the ones on the back because you do actually use the ones off of the back side when you make it a toddler bed and put all four rail on.
Aug 15, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
Need insturtions for graco
Most if not all of the simplicity brand drop-side cribs have been recalled, including the Graco model #4600.
Here is the CPSP link regarding this crib.
If you know where you purchased the crib, check to see what their policy is regarding recalled baby products.
We had purchased ours at walmart almost 8 years ago and were able to return it to another store in a different state for a full refund last summer. They did not need a receipt received, they just needed the manufacturer label on the part that the mattress lies on.
Aug 08, 2008 | Graco Apsen 3-in-1 8740 Crib
Need parts for white graco metal crib with arched ends
i need to know how to get another round piece that goes into the conversion rails for the toddler bed.
May 06, 2008 | Graco Ultra Deluxe 5-in-1 4605 Crib
CONVERTING TO TODDLER BED
i found this on the simplicity website, hope it helps. i got mine done i minutes!!!!
Remove Drop side.
Lower drop side. Push in on the tabs at the
bottom of both lower tracks to slide the drop
side down off the tracks as shown.
Position Mattress Support.
Mattress support must be in the lowest
position. If not, use the allen wrench to
remove bolts. Lower support into position
and re-attach to headboard.
Remove upper and lower tracks.
Aug 29, 2007 | Simplicity for Children Ellis 4 in 1 Sleep...
Graco Ultra Deluxe 5-in-1 4605 Crib Logo
438 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
