Question about Canon FAX-JX200
I have a canon fax-jx500 and i cant get it to work.. it took me 20 minutesto get the ink cartridge in. and now it says on the lcd screen that the line is in use and the phone is dead... any suggestions?
    Problem Solver:
  • 3 Answers
I had a bit of a job putting the ink cardtridge in but it needs to pushed in a downwards action, I was trying to push it slightly upwards
Posted on Jul 13, 2008
How do i print off a comfirmation report when i send a fax to say it went through ok
Posted on Jan 29, 2009
I have a canon fax-jx500i cant work on it. after some minutes a have tune it on it give a message " line in use"
Posted on Oct 29, 2008
I have a canon fax-jx500 and i just want to know how do i change the languege from dutch to engish cause i dont understand a thing that is on the fax.
thank you
Posted on Aug 11, 2008
Can i send a fax without ink?
my fax machine is a Canon mx860. it would not let me do ANYTHING without a black ink cartridge, even tho all the color cartridges were full (black can be made without a black ink cartridge, it just waste your color ink a lot.)
Since it was an emergency i scanned the document to fax from my desktop as a .jpg file, sent it to my laptop containing a modem, and faxed it from my laptop with windows 7's "fax and scan wizard". I know its not a fix, but its an emergency work around.
May 23, 2012 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My canonfax-jx500 wont fax it has5100 on the screen and i dont ma
The carriage did not move
up or down properly.
You need to remove covers, manually move the carriage in home position, manually rotate gears to put scanner in home position, clean gears, use wd40 to neutrallize grease, ink, dust on clutches and gears,...
or replace:
- PR lift shaft - Sheet feed unit
- Main Board ***'y
- Carriage lift sensor unit
Jul 01, 2010 | Canon FAX-JX200
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Clearing LCD Screen from RECOMEND NEW CRT
if u refill it may can't remove that message but try to press stop button for 5 sec to clear it
Apr 28, 2009 | Canon FAX-JX200
Alram light
Did you replace the Black ink cartridge or the Color cartridge, or did you replace both?
Facing the front of the Canon Pixma MX310, did you install the Black ink cartridge to the left side, and the Color cartridge to the right side?
Do Not reverse how the ink cartridges go. Do Not install a Black ink cartridge, in the Color cartridge holder.
If the Alarm light came on, check to see if you have an error message in the LCD. (Not trying to insult your intelligence. The LCD is the little rectangular Liquid Crystal Display on your Pixma MX310 Operation Panel, to the left of the numeric buttons)
Do you have the Pixma MX310 On-screen manual?
Start>Hover on All Programs>Canon>Pixma MX310>On-screen manual
Click on the Troubleshooting heading.
If you have an error message code, click on the heading ->
An Error Message is Displayed on the LCD.
Also suggest you click on the heading -> Problems Sending Faxes.
See if the information provided has a solution to your problem.
Apr 22, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon jx500, getting 'check 5100'
I had this problem and solved it = )
You turn off the fax, take the paper out, then open the cover just after you turn it back on.
Leave it open for a minute and let the cartridge go back and forward close the cover and wait till it tell you to press stop and it should be back to normal.
Hope this helps
Mar 10, 2009 | Canon FAX-JX200
I cant work on my canon fa-jx500
Someone or something IS using the phone line. Check the handset also.
Oct 29, 2008 | Canon FAX-JX200
Canon FAX-JX200 Logo
362 people viewed this question
old marine
old marine
