Question about Kenmore 23812 Top Load Washer
Kenmore 23812 top load washer
Worked fine 2 days ago now will not drain for the spin/ rinse cycle-
dont know other cycles worked- not sure how to trouble shoot
switch seems to be working.....thanks in advance
  • 1 more comment
  • uniquekristi Oct 20, 2008
    I have the exact same problem. Washer worked fine and all of a sudden washer filled up for a wash cycle, it will wash, but then just stoped in the cycle and will not rinse or spin or drain the water. If I turn the switch to any rinse cycle it washes back & forth and where it should drain the water and then spin it just stops. What can we do to drain the washer and get it to spin? Could it be the pump? COuld it be something electrical in the system? Please let me know as soon as possible. Thank You
  • rockarmstron Dec 04, 2008
    I have the same problem
  • Anonymous Apr 26, 2009
    same problem
    Genius:
  • 1,198 Answers
The lid switch is ususlly the first to go. Luckily, it is easy to replace. To test the washer, connect the lid switch wires together. If the washer spins, you need to replace the switch.
Posted on May 04, 2009
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Won't complete cycle, stops at rinse. and can't get hot water.
Are you on well water? turn off the cold water to the washer and clean the screen filter out. do not leave filter out.
the machine probably has a cold only final rinse so it won't work properly.
Mar 22, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Kenmore 80 Series - machine won't rinse or spin
Manually move the timer to the SPIN mode and turn it on.
If nothing happens, replace the lid switch.
With a model number I could be more specific.
Feb 27, 2009 | Kenmore 24032\24036 Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Won't spin or drain
Check to make sure your lid switch is working.
Nov 17, 2008 | Kenmore 22422 Top Load Washer
Kenmore 80 Series won't spin out
if the unit washes ,,and dont spins check your lid switch first...
Oct 25, 2008 | Kenmore 24902 Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Machine doesn't spin/rinse/drain
not sure why, but the timer is lacking supply power during this event. look on back of timer for power connections to the motor. now monitor the 2 terminals for supply with a voltmeter to be sure. usually a schematic is taped to inside of machine so you can trace where that supply is on it.
Nov 20, 2007 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore 23812 Top Load Washer Logo
212 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
