Question about Broderbund The Print Shop 21 Deluxe Full Version for PC
A visus wipe out one of the files (21.msi) I can't find my disk. How can i fix this?
Please insert usb flash disk with BIOS file
You need to use a computer with Internet access, then go to the MSI WEB site to download the BIOS file for you model motherboard and then copy this BIOS file to an USB memory stick.
You and then insert this USB memory stick into your MSI computer and boot up the computer.
May 14, 2013 | MSI K8N Neo4-F Motherboard
Please insert usb flash disk with the BIOS file..
MSI Support > K9N6SGM-V > Main Support page,
http://www.msi.com/product/mb/K9N6SGM-V---K9N6PGM-FI---K9N6PGM-F.html
Hover your mouse on the Download tab.
(Overview / Specifications / Download / Support / etc)
Click on BIOS in the list
Regards,
joecoolvette
May 14, 2013 | MSI K9N6SGM-V (7309-020(K9N6SGM-V))...
How do i fix windows update error 1722
According to the error code 1722, it is actually a windows installer error. What we need to do is to fix the Windows Installer.
Try the following fix below...
(Please note that before trying any of the solutions below, you must be logged into your computer as an Administrator.)
  • Check whether Windows Installer engine is functioning.
  1. Click Start > Accessories > Command Prompt.
  2. At the command prompt, type MSIExec and press Enter. MSI refers to the Windows Installer.
  3. In the MSI engine is working, you should see no error messages. However, if you see an error message, note down the error. Search for it in a search engine such as Google to find troubleshooting solutions.
  4. Now try to install or uninstall the program again. If the problem persists, go to the next fix.
  • Check that Windows Installer service is not disabled.
  1. Click Start and type service.msc in the Search box and press Enter.
  2. The Services window is opened. Right-click on 'Windows Installer' service, then click 'Start'. The service needs to start without any errors.
  3. Now try to install or uninstall your program again. If it persists, try the next fix.
  • Check for latest version of Windows Installer.
  2. Once the command prompt window opens up, type MSIExec and press Enter. If MSI engine is working, you should see no error messages, and it should open a separate dialog box, which shows the MSI version.
  3. If the installer version doesn't show as version 4.5, download the latest version athttp://support.microsoft.com/kb/942288/
  4. Now try to install or reinstall your program again. If it still persists, try the next fix.
  • Reregister the installer engine.
  2. At the command prompt, first type MSIExec / unregister, then press Enter and type MSIExec / regserver
  3. Now try to install or reinstall your program again.
  • Clean your CD or DVD media.
  1. If you are trying to install the program from a CD or DVD media, use a CD or DVD disc cleaning kit.
  2. You can also gently wipe the silver side of the disc with a soft, lint-free cotton cloth. Make sure you do not use paper or other rough cloth as this can scratch the plastic or leave streaks that can damage the disk. Make sure you wipe the disk from the center outward and not circular motion.
  3. If you use a damp cloth or commercial disk cleaning solution, wipe the disc thoroughly before inserting into the drive.
  • Copy installation files to your computer.
  1. If you are using a removable or external media to install the program, copy the installation files from there to your computer's hard drive and then run the installation file from that location. It is usually called autorun.exe or setup.exe. If you are not sure, just check the Readme file in the setup folder about how to start the installation.
  2. Unless there is no .exe file present in the setup folder, we do not recommend that you run .msi files directly.
  • Terminating other programs running on your computer.
  1. Click Start and type msconfig in the Search box.
  2. One the 'General' tab, click 'Selective startup', then click to clear the 'Load startup items' checkbox.
  3. Click 'Services' tab, click 'Hide all Microsoft services', and then click 'Disable all'.
  4. Click OK, then click Restart.
  5. After the computer restarts, try to run your program installation.
  6. Once you have finished troubleshooting the problem, restart your computer again.
  7. Click Start, type msconfig in the Search box. Click on the 'General' tab, click 'Normal startup', click OK, then click Restart.
    Hope this helps!
Sep 09, 2011 | Computers & Internet
Being a silver surfer I require a manuel for my laptop MSI cr630. Also how do I switch on the camera
Here's the official MSI support site for the MSI CR630 Notebook PC - just select "USA".
http://www.msi.com/service/download/manual-13442.html
It'll download a ZIP file - unzip it (using WinZip) to get a PDF file
PDF files are viewable (free) using Adobe reader from www.adobe.com
As to how to switch on the camera - you'll have to read your new manual.
One trick from this computer tech: you may want ot store the PDF file on a CD-RW
disk (in addition to saving it on the CR630 itself). Since, if the MSI CR630 PC refuses to boot,
you can take your CD-RW copy of the manual to a local library's computer, load it, and read about
how to fix your MSI CR630 from a computer that's working.
Aug 03, 2011 | Computers & Internet
Microsoft Windows asking me to backup the files in drives because hard disk has encountered a problem. How to solve the problem without backing up of the files?
There is no way you can avoid this because if the hard drive fails you will lose your data.
Do you want to risk losing your data?
The problem could be some bad blocks on the hard disk and Scan Disk may fix this problem BUT there is a risk this process may wipe out some data files or may require re-formating the hard drive.
The hard drive may be corrected by re-formatting the hard drive, but this process will wipe your data off this hard disk.
Nov 29, 2010 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
New portable Win7 won't make recovery disk
Okay....take a deep breath, we'll do this step by step.
1. Go to the following link: http://www.msi.com/index.php?func=driverfile&dno=9927&i=0
2. Select where you want to download the file from. It's best to pick the one that reflects your location.
3. Once the file has been downloaded, extract the folder to someplace you can find it again, e.g. Desktop or MyDocuments or something like that.
4. Run the file called "setup.exe" (without quotes)
5. Follow the directions of the installer
6. Taadaa! All done, you can relax again.
Good luck and don't hesitate to message me if you have any questions/need help.
Dec 26, 2009 | Computers & Internet
I updated a friends Vista PC to SP2 and now her SPrint Wireless card does not work. Its asking for a data interface disk. What is this
The installation program is not completing the install with the necessary drivers.
The fix: you must extract all the files from Sprint's .MSI installation file. I downloaded a free utility called Lessmsierables-20050611.zip by searching for an MSI extractor. It will allow you to right click the MSI file and extract all of the files to a folder.
After extracting all of the files, I inserted my Aircard 580 and the Data Interface box came up again. Point the driver installation to the folder you extracted and presto, it will install both of the Data Interface drivers (which are Aircard 580 drivers)
Nov 16, 2009 | Computers & Internet
1706 need PROPLUS.MSI file fix/patch to run xp pro
I am not sure what exactly you need.
I suppose PROPLUS.MSI file is a Microsoft Installation Pack for MSOffice XP.
Incase you have a CD for Office XP and that particular file is corrup, you can download the same from the following link:
http://brianmedavoy.com/Office%20XP/Proplus.msi
Similarly you can download all the files of the Office XP disk from this link:
If you need any further help pls feel free to get back to me.
If this is what you were looking for
Please do not forget to give your feedback and say thanks
Sep 04, 2009 | Microsoft Windows XP Professional for PC
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
62 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
