Question about Mitsubishi Televison & Video
My 2000 mitsubishi projection tv 's color is not working right gives off double image with a red cast around it what could the problem be?
  • Mitsubishi Master
  • 8,617 Answers
Most probable cause is the convergence amp ICs. Please post the model number of your set and I will post the correct IC numbers for your set as well as a link of where you can get replacement ICs.
Posted on Jul 06, 2008
THE COLORS SEEM FINE BUT THERE IS A DOUBLE IMAGE. THE TV IS TEN YEARS OLD BUT UNTIL NOW IT WAS IN PERFECT CONDITION. DO YOU THINK IT'S THE ICS OR THE RESISTORS OR THE TUBE. THANKS
Colors fine but double image: does picture have red or blue outlines around lettering or images?
See attached photos, it they look like your trouble it is convergence problem, if not try to give better description of problem.
You can post a comment here and I will assist you-I am here to help.6b564f8.jpg
Regards, SD TECH
Aug 23, 2010 | Hitachi 60DX10B 60" Rear Projection...
Mitsubishi TV 1080 Gives green color and red (pink) color double images for every character and object. This is not LCD but rear projection 55 in TV.
It appears as though your convergance chips need to be replaced. If you can handle a soldering iron and are good an soldering, then you can handle this repair.
Go to this web site, and look up the kit for your tv. Your model numer is most likely going to start with WS. It can be found on the back of your TV, in the same area where all the connection ports are.
http://www.tvrepairkits.com/xcart/home.php?cat=1413
Hope this helps.
Mar 31, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Double image mitsubishi wd-60735 have to cut tv off let cool down cut back on to get rid of double image
There are two common problems with these sets.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 23, 2009 | Mitsubishi WD-60735 Projection Television
Color is separating (red and Green double images
Yes everything is repairable.....
The problem is in the Croma section of the TV
some times it ma happen due to 99% of moisture.........
Try Hot air Blow drying for 1 HR in side the TV i.e on the circute and blow clean if any dust partical are there
and then re check
if the problem prestis....contact the TV repai expert or the service centre....
May the Croma chip needs replacement....
Regards
Sep 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Samsung HCN4727W Rear Projection TV, green screen, audio works
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai2_bing.gif,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jul 10, 2009 | Samsung HL-R4667W Rear Projection...
Red&green cast upper left
It's the convergence IC(s) gone bad. $300 for repair at a shop
Jan 20, 2009 | Mitsubishi VS-45607 45" Rear Projection...
I have a Panasonic HDTV Projection PT-47WX42 with double imaging.
Projection TV sets have two very common problems listed below.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
*Screen Looks 3-D
*Colors wont align
Nov 17, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Double image - colors out of sync, concave image
bad converage ic's, check reisters around them and fuses for -&+VCC
Apr 09, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
