Question about Gigabyte GA-8I848P-G Motherboard
Computer restart whith new ram
I'm using gigabyte with 256 mb twinmos ram, now when i try to upgrade it with more 512 twinmos ram. the computer keep restarting to infinity.
  • kammz666 Apr 01, 2009
    i have the same issue, i didnt even upgrade the ram, just took it out to ge the info... D:
Ga 81915me
Posted on Jul 23, 2008
Maximum Ram can the Elite K755A Motherboard take?
The specifics for that motherboard can be found at the ECS website below which will detail the hardware limits for your motherboard.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=420&CategoryID=1&MenuID=22&LanID=0
May 17, 2014 | AMD Computers & Internet
RAM upgrade on Packard Bell Columbia mainboard
you can only use as much as the motherboard are made for.
May 01, 2013 | Computers & Internet
How to do jumper setting on RAM upgrade from 2 x 256 MB to 2 x 512 MB.
Good day,
Theres no need to jumper anything in upgrading your Ram, Just remove the 256 mb rams and replace it with your 512mb ram. Then try turning your PC on.
Feb 01, 2011 | Acer Aspire SA20 PC Desktop
I have a Gateway 838GM. It has 4 slots for RAM. It came with 1/2 gig RAM (2 sticks, 256 Megs each). I tried installing new RAM- 2 sticks, 1 gig each. If I replace the original 2 sticks, the computer...
Here are the specifications of the Gateway 838GM: You will have to replace the existing memory with thesesettings only: The machine comes with: 512 MB = 256 MB (removable) + 256 MB PC3200DDR SDRAM DIMMs. Supports Dual Channel DDR Nowyou can only upgrade to 4.0 Gig total. I would recommend going to this link and order the correct memory foryour computer I use them quite a bit. http://www.memorystock.com/memory/Gateway838GM.html Rob
Dec 01, 2010 | Computers & Internet
My pc was working fine with 128 + 256 ram. few days ago it didnt boot.it was restarting automatically. then i removed 256 ram and it booted normally.means pc works normally with 128 ram but not with 256...
i guess u have 2 different RAM cards in the RAM slots....
the main issue is both dont work together...the primary reason is compatibility....or one of the RAM cards have worn out...
u must use exactly similar kind of RAMs in both slots....
i suggest u use one 512 MB if your motherboard supports....
RAM technology has advanced so mush that you wont get RAMs for old PCs (motherboards)....so u decide...
pls revert back...and kindly leave a feedback and rating for this solution...it will help me move to Guru" here from Expert at Fixya....
regards...
Sep 29, 2010 | Gigabyte GA-8I845GV Motherboard
I have a Fujitsu Lifebook E2010 with one 256 MB RAM module. When I try to upgrade to one (or two) 512 MB standard Kingston memory (266MHz Pc2100), the notebook won't boot, I only get 1-3-3-1 beeps which is...
Make sure that you got the right memory module with this specs:
Memory
  • DDR266 (266 MHz) so-DIMM 200 pin
  • 2 DIMM slots; upgradable to 1 GB total memory (512 MB x 2)
or better go to this link http://support.fujitsupc.com/CS/Portal/supportsearch.do?srch=GUIDES
there's a step by step troubleshooting for memory modules. Also make sure you purchase memory module from Fujitsu or Authorized Fujitsu Dealers .
You can also find us over the web, visit us at www.fujitsu.com or for Around-the-Clock Expert Technical Support you may contact us at :
Phone Support (Direct to Service Desk)
1-800-8FUJITS (1-800-838-5487)
Available 24 hours, 7 days a week.
Consumer Sales - 1-800-FUJITSU
Corporate Sales - 1-800-831-3183
Tech Support - 1-800-8FUJITS /1-800 8385487 or 1- 888 -3854212
-ERNZ
Feb 03, 2010 | Fujitsu LIFEBOOK E2010 PC Notebook
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
I have 256 MB RAM which is slow, can i upgrade it to 512 MB RAM
Depends completely on what motherboard the computer has and what it supports, I could check on it if you have and brand and model of the computer, or from the motherboard.
Sure the prosessor speed doesn't affect the memory amount possible don't worry about that, just need to find out how much is supported and at what speed etc.
Thanks,
Ekse
Jun 03, 2009 | E-Machines -T1840-CELERON-1.8GHz,40GB...
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
Not able to install RAM > 512 MB
Try to run a system repair.
Jul 14, 2008 | ASUS K8S-MX Motherboard
Gigabyte GA-8I848P-G Motherboard Logo
201 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Alun Cox
Tony
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
