Indesit WIDL 126 washer/dryer
Don't have a handbook. Need to know how to work built in dryer
Look at http://www.indesit.co.uk/indesit/productsheet.do?productId=30538UK
Posted on Jul 08, 2008
I have an Indesit Washer/dryer (WIDL 126 S), and it is dot draining the water. I set in on drain or dry and nothing happens, it just fills with more water.
HI,
Check back of washe with a flashlight for a bent or clogged drain hose. Do not move washer to check it. When you move it , it will straighten out and you will never know if it was bent
Also while it is pumping , pick up end of drain hose at drain and observe the volume of water being pumped.
If no water then the Pump needs replaced.
Thank you for using fixya
Leo Ponder
Please rate me if this helped
Aug 12, 2011 | Washing Machines
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 28, 2009 | Washing Machines
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit widl 102 extra rinse button always on!
Check that the button isn't stuck it if not remove top lid and check the PCB and see if the switch hasn't collapsed causing it to be on all the time. Also if you hold in the go button for about 5 seconds this resets the program try this.
Thanks J
Feb 07, 2008 | Indesit W 123 Front Load Washer
Indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Jan 25, 2008 | Indesit WA 115 Front Load Washer
WIDL 126 S WASHER DRYER
what u can check is the outlet hose does it go down a plastic pipe if so pull it up slightly until it stops a simple mistake if its gone down slightly too much what happens is if its low down the pump kicks in as it thinks the pipe is lower then the washer to drain it try it if i isnt this then it will more then likely be a faulty timer which u will have to replace m8 let me know how it goes m8
Dec 13, 2007 | Indesit WA 125 Front Load Washer
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
