Question about StompSoft BackUp My PC 2005 (05004) for PC
File is not accessible. Access is denied message
After a complete reinstall of my operating system was necessary due to a virus, I am trying to access my iTunes files. They reinstalled using Back Up my PC. I have uninstalled and reinstall the program but am still unable to use/run/see My Library of tunes. The message is that the files/folder is not accessible. Access is denied. I can not delete this file--no authorization. Please post an answer in English- I have a hard time with computerspeak.
  • Anonymous Sep 13, 2008
    i have the same exact problem!
  • 2,427 Answers
Hi.
Sorry for the delayed responce. Ok first thing is first. The "files/folder is not accessible" occurs because the program cannot find the files in the place where they should be. for example if you put your socks in a draw and your wife moved it, when you return you wont have axcess to them right :) will basically its the same thing here. What you will need to do is find the default directory of itunes it should be in the Options or tools ir settings menu (I dont use itunes so i am not sure just play around in the program until you find it) once you do you need to search you computer for where the PC Backup put your files ..
click start then search and type the name or piece of the name of a song you know should be there. Once you find it browse to the directory of where the song is located. Click start then my computer then local disk to get to your harddrive. Go to the folder that has the songs and copy them. then paste them into the directory where itunes is looking for them.
Posted on Nov 13, 2008
No audio on speakers or headset. Both worked fine a few days ago. Activity is visible on mixer for speakers or headset (symbol bottom right), when music program is chosen. Relevant data: PC Vaio...
The error states file access denied.
It seems your login is not able to access that specified file
due to permission constraint.
  • Firstly disable UAC.
  • If you have mcaffee installed or norton, disable access protection.
  • If you created a system restore point with the True Crypt image mounted, you won't be able to restore back to that point. It needs to be unmounted before creating the restore point.
  • If you use Panda Internet Security you need to uninstall it completely in order to be able to restore to a previous point.
Before trying the above solutions you can try the following that exploit a bug on windows:
  1. turn off System Restore,
  2. Shutdown,
  3. Power Up,
  4. enable System Restore and
  5. try to Restore.
Best of luck.
Feb 13, 2014 | Computers & Internet
How to delete notepad logs from certain files
if you are using the windows 7, and want to delete any log file which shows 'access denied' , you just need to login with your admin account and you can access and delete that file easily.
Nov 29, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Sir when I plug in my pen drive and try to access it, the comouter shows a message "access is denied".Please give me the solution to fix the problem
Delete the autorun.inf file on the drive.You may have to set your computer to show hidden files and system files to see that file.
Mar 01, 2011 | Computers & Internet
My operating system is XP S3 Antivirus - Norton
that's common in norton that's why i'm not using it anymore,they are repeating scanning virus even you delete or remove..and they also hard to remove from your system..on my part i restore my system to when before i installed norton..so do the restoration system
Feb 14, 2011 | Microsoft Windows XP Professional
When i try to install a critical update it was denied access by 7 zip. even after uninstalling 7 zip and installing winzip i still get the same response when trying to install updates 7 zip access denied....
Install Winrar, Here is the link
http://www.rarlab.com/rar/wrar391.exe
if you double click the file,the files will be extracted in the temp folder,so after installing winrar,right click on the file and select extract here. and try to install the update now,
Sometime when you extract files and it contains Malware or Trojan,Anti-Virus which support real time scan just block the files and the access denied message is displayed.
Scan the extracted files before installing so that you know it's Virus free.
Sometimes,even if you have administrator right,sometimes due to malware infection, you are denied access to some system hidden giles like folder under Local settings.
Dec 30, 2009 | Compaq Computers & Internet
Virus Side Effects; Safe Boot; Drive Access denied
try to restore your system ;
start, all program, accessories, system tools, system restore and try to restore an earlier point which you will choose
Sep 14, 2009 | Microsoft Windows XP Professional With...
Access denied when installing win xp service pack 3
Are you logged in as an administrator on your PC? Access Denied is almost always an indicator that the current logged in user does not have sufficient permissions to install applications. Let us know if this is not the case. Hope this helps!
Dec 28, 2008 | Microsoft Windows XP Home Edition
Accessing a folder.
This will sound off the wall, but we had something similar to this happen with my last laptop, where it was "access denied" in lots of areas, and we would have to find little backdoor ways to get into control panel and document files. The problem with our computer was that it had previously crashed, and we had rebooted and reinstalled the xp, but didn't have the registration number, so it would run ok, but to get into all those access denied things (which you eventually need to get into) we had to come up with our registration number.
Did it prompt you to enter the product key when you re-installed it?
Jun 27, 2008 | SmartDisk FireLite USBFLB120 120 GB USB...
StompSoft BackUp My PC 2005 (05004) for PC Logo
1,194 people viewed this question
Top StompSoft Computers & Internet Experts
Sandeep Kumar
Tom Chichester
Are you a StompSoft Computer and Internet Expert? Answer questions, earn points and help others
