Emagistics sx2100 error code A6 - Office Equipment & Supplies
I have a Brother DCP 8020 Multi printer. Im getting machine error code A6. After replacing the fuser
This is what is written in my service manual for Error Code A6:
Error code 6A
Print Unable 6A
Turn the power off and then back on again.
Fuser unit failure (The side thermistor does not detect 60degreesC within the specified time.)
Dec 05, 2012 | Brother DCP-8020 Laser Printer
Just bought a used audi a6 and check engine lite came on . as well as a beeping noise
Bring your car to an auto parts store. The will plug a box in to see what error codes are causing the check engine light. Look up the code and fix as needed, the auto parts store will help you out, usually for free.
Aug 18, 2011 | 2002 Audi A6
Keep getting error A6
Error Code(Hex) : A6
Symptom: FAX scanning failure. (retry)
Probable Cause:- CIS defective White-level reference
film stained in the scanner cover,- Main PCB defective
Solution:- Replace the scanner cover(scanner unit),-
Replace the main PCB.
Hope it helps..
Oct 29, 2010 | Brother IntelliFAX 4100 Laser Fax
My Audi A6 has a solid yellow ABS light and a flashing Red Brake light. It won't pass inspection now because of this. Whats wrong?
you will have to have someone scan the abs computer to pull the error codes.. this is the only way to know what ares is at fault
Apr 23, 2010 | 1999 Audi A6
Audi A6 RPM Signal from ECU
dont think you are reading the codes right because PO in front of the code is not a genuine Audi code ,well not according to my information ,try autozone who issue these codes or a snap on code reader booklet
Dec 26, 2009 | 2002 Audi A6
The fax paper can not go through, and the window turn red light said error A6
You will need to take it in for service.
Machine Error A6 is an indication of a mechanical malfunction and the unit will require servicing.
See this link on the Brother website:
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=100000005512&Sympt=Why+does+my+machine+display+the+message+Machine+Error+A6%3f+MEA6&Model=101&ProductGroup=5&Keyword=A6%20error&ProductID=MFC8220
Aug 10, 2009 | Brother MFC-8220 Fax
I am getting an A6 error on my brother MFC8220
The a6 error is Scan Unable, So i assume your trying to scan something? Dont know how to fix it, But i figured id try to help by giving you the meaning to the error code.
Nov 25, 2008 | Brother MFC-8220 Fax
Scanner not working
I work at a brother authorized repair center, the bad thing is that there is no specified A6 error, in any manual and when you call brother and tell them that you are calling from an Authorized repair center and that you need help with an A6 they*gasp* tell you to call an authorized repair center. Sorry about the rant.
The A6 is a general error relating to the scandeck on most MFC machines(9700/8440/8640) etc...
try changing the main PCB, it can be a little costly, however it generally doesn't take long, that is the general cause of the error. However, sometimes that doesn't work, so to save yourself a little time and money, just go buy another printer.
Sep 25, 2007 | Brother MFC-8640D Printer
180 people viewed this question
jasbo
jasbo
