Question about Dishwashers
Bosch hydrosensor dishwasher works Ok except the water is cold! Suspect heater or thermostat failed but is there a known common problem with these?
  • Anonymous Jan 03, 2009
    no hot water and mould
I have a Bosch hydro sensor dishwasher but no matter what I do it will not wash the dishes/cups,glasses properly. It leaves a scum on every thing
Posted on Feb 19, 2010
My Bosch she45mo6uc/50 dishwasher will not advance to the wash cycle. It makes a series of clicks, but nothing happens. It just stops. Any ideas?
The most common problem that causes this with this particular unit is the water heater unit failing. It will clod rinse but then when it fills and tries to heat the water, it senses that the heater unit isn't functioning and errors out
Sep 21, 2015 | Bosch Evolution 500 SHE45M06UC Built-in...
What is cold resistance of heater element? Bosch SGS56E02GB
If the heater element had infinite resistance, it would be defective. Possibly a defective thermostat.
Jul 01, 2015 | Bosch Dishwashers
Dishwasher runs for to long
most likely the inlet hot water is not of correct temperature or if dishwasher has its own heater then the heater in dishwasher is failing to heat water to correct temperature or the thermostat is failing.
Apr 18, 2014 | Bosch Dishwashers
Siemens hydrosensor dishwasher, no water
If your plumber has looked at it and said hydrosensor is faulty then replace hydrosensor, or get a new dishwasher. Just compare cost of fixing or replacing.
Apr 15, 2014 | Empire Heating & Cooling
My Bosch Dishwasher is not drying my dishes now. The model number is SHE44C05UC.
Unfortunately, it seems that the heating element has failed. The dishwasher uses steam to heat the tub to dry the dishes. I suspect your dishes are also being washed in cold water.
To check this, please run a regular full wash cycle. Allow the washer to fill with water and run for about 10 minutes, then open the door and feel the water temperature in the bottom of the washer. If the water is cold, it's more than likely the heating element has failed.
There are other possible faults which would cause the element not to heat, but these often prevent the dishwasher from completing the cycle. If the water is cold but the dishwasher still drains the water at the end - and completes the cycle - the heating element has probably failed.
Please try this simple test for water temperature and let me know if you need further assistance.
Regards,
BElectric
Feb 18, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Model not sure 10yrs? HydroSensor,(only title On
Try and drain water out completely and restart cycle. Note if water comes in and if so, once in is there a hum (audible) when in effect the motor should run. If so, the motor is jambed and needs to be cleared. Check the door limit has not malfunctioned as well. It can be bridged temporary to confirm.
May 27, 2010 | Bosch 24 in. SHE43C05UC Stainless Steel...
My Bosch dishwasher is no longer using hot water to wash dishes, only cold. I have checked all the connections and they are ok. What gives?
Check the thermostat, heater element. Finally check whether the power supply reaching the element terminals.
Take care if you are doing it keeping the machine ON.
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher not drying - Bosch Integra SHU9952
Bosch generally drys through evaporation from hot water rinse. There is a common circuit board issue where a cold solder joint on the heater relay pops.The water does not heat sufficient to evaporate any longer. Consult your manual for self diagnosing trouble shooting codes or go to appliance aid.com.
If the board connection is the issue I have repaired several, however Bosch recommends replacement only and sometimes supplies the parts free.
Aug 14, 2008 | Bosch SHU5315UC Dishwasher
Bosch dishwasher will not drain
how do you disconnect the waste pipe from the back of a Bosch hydrosensor dishwasher
Aug 09, 2008 | Dishwashers
Bosch dishwasher shu4302uc
Common problem with these. Control panel (behind all the buttons on the door) has a thyristor in the middle of the PCB for switching the heater element ON/OFF.
After many screws and a bit of fiddling about, get access to back of PCB (print side) to find dry joints. Clean and re-make joints and all should be well.
Caution, this is a high voltage area. Disconnect from mains.
Please see photos.
Cheers…..Dave
Mar 05, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
510 people viewed this question
Top Dishwashers Experts
