Question about Sony Handycam DCR-TRV27 Mini DV Digital Camcorder
Tape compartment stuck
Tape comprtment ****
how to open the compartment
  • 1 more comment
  • m_david2007 Aug 06, 2008
    The door opens but the tape compartment is stuck, it doesn't pop-down like it's supposed to!
  • Anonymous Sep 17, 2008
    The
  • mnouhan Sep 17, 2008
    The tape is stuck and won't come out. This is the third Sony camera that I have and this has happened. What is the process to get the tape out? What options are there for Sony to repair this at their cost? Please advise.
    M
I have the same problem - the door opens but the compartment won't open up. My tape is stuck - help!
Posted on Jul 27, 2008
Frigidaire upright fridge freezer.The drainage hole at back of fridge part of item keeps freezing over blocking drainage from fridge
Yrur model number is missing the last three digits.... I will use FRT21H8CB1 as the example model number.
You need to do a total manual defrost with a catch basin and comprtment drain cleaning.
- Unplug the unit
- Remove fgreezer contents
- Direct an exteranl fan into the freezer compartment for just over 2 hours to ensure the compartment drain tube has defrosted.
- During the defrost period... open the fiberboard panel on the lower back of the refrigerator and clean out everything, Condensor coils, catch / drip pan (Called pan-defrost for parts), and the END of the compartment drain tube.
Model reference:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5158190&diagram_id=1311449#d1311449
Defrost pan Item 26 of above link needs to be cleaned.
Coils Item 1 need to be cleaned
Fan blade Item 61 needs to be cleaned.
The evaporator trough, drain item 17 also should be clear. Here is what you can do without tearing everything in the back of the freezer apart. Once your sure the comprtment drain tube (no item number / bulk hose) is clean on the end. Use the exhaust of a Vacuum cleaner and the hose to force air UP through the drain hose and float out any debris from the trough drain. Have a 2nd person listen for air flow into the freezer compartment if possible. The biggest problems with freezer compartment drains is the END of the hose at the defrost pan underneath the unit clogs up and then the compartment drain hose just loads up with scum. Then the freezer stops draining and you have the symtom your describing.
After the manual defrost and cleaning return the unit to normal service.
Having said all of that... if the refrigerator then freezer starts warming up in 3 - 4 days... you may have an automatic defrost problem causing the icing. I.e it is not defrosting so the evaporator eventually ices over and forms an ice block in the back and bottom of the freezer compartment. Usually if there is an ice block that forms you wil hear the evaporator fan striking the ice build up.
If this is happening... for sure there is an automatic defrosting problem and your stuck doing a manual defrost ever 3 - 4 days until repairs are complete.
One more note.. if there is NOT any compartment drain tubing visible... your unit may port evaporator tray water down the back of the fresh food compartment to the defrost pan under the unit... just clean everything that serves as a drain function best you can during the manual defrost and cleaning process.
Thanks for choosing FixYa,
Kelly
May 23, 2011 | Frigidaire FRT21H8 Top Freezer...
REPLACE HEADLIGHT
Inside the bulet you will see the headlight comprtment just remove the panel covering it then remove the bad bulb and the fix in the new one then cover back the compartment and the headlight starts working.
Jan 22, 2011 | 1995 Mitsubishi Montero
There a problem with the power to the deck it turns on for a few seconds then shuts off. There is a tape stuck in the deck that needs to be taken out before I can send it off to get fixed. Is there...
For this type of problem.first u need to take the tape out from the Compartment.open the unit also upper compartment unit.Use DC power supply to Main Cam motor.then Ur power problem be not there any more
Jan 18, 2011 | Sony HVR-M25U HDV VCR
Sony camcorder HDV 1080i model HVR A1U won't eject tape. Deck lid opens but compartment (tape) won't come up. C:32:11 flashes.
Sony A1U stopped functioning. Neither AC power or battery yields anything. Reset button yields brief flash only. Tape stuck in machine. Help?
Feb 22, 2010 | Sony Handycam DCR-DVD108 DVD Camcorder
CAMCORDER'S TAPE IS STUCK, WHEN I PRESS EJECT, THE OUTER COMPARTMENT OPENED BUT THE TAPE COMPARTMENT DID NOT. IT WILL NOT GO DOWN ALSO?
You might have a sony handycam? If so, it is a manufacturers problem that came with the camera. Mine does this all the time, just slap the outside of it and it works. I know it sounds harsh - only do this if you have a sony handycam.
Sep 25, 2009 | Sony 8mm Stantard Grade 120 Minute...
Sony Handi-Cam TR57. After being stored for a couple of weeks,the tape door, with tape in place has become stuck in the up position, and the tape cannot be either removed or pushed back down. The tape...
Follow this procedure to troubleshoot if the cassette compartment will not open or the tape is stuck and will not eject.
IMPORTANT: If your camcorder model has a RESET button, first try pressing this button. If there is no RESET button, or pressing the button does not resolve the issue, continue with the troubleshooting steps below.
  1. Turn off the camcorder.
  2. Remove the battery from the camera.
  3. Remove the AC power supply from the camera.
  4. Slide the power switch on the camera to the VTR , VCR or CAMERA mode for 15 seconds.
  5. Slide the power switch back to the OFF position.
  6. Connect the AC power supply to the camera.
  7. Attempt to open the cassette compartment.
NOTE: If the issue is still unresolved after completing all of the troubleshooting steps, service may be required .
Jul 31, 2009 | Sony Video Cameras
I have a panasonic mini dv video recorder. After
close the tape compartment take the batery of press the power button on and holding the power press put the batery back and wait let me know
Jul 07, 2009 | Panasonic PV-GS150 Mini DV Digital...
Tape compartment stuck & will not open!
try hitting it with your palm to pop the door open.
Sep 23, 2008 | Panasonic PV-GS31 Mini DV Digital...
Opening the tape compartment
something may be jammed in one of the hinges of the compartment door.
Jun 26, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Sony Handycam DCR-TRV27 Mini DV Digital Camcorder Logo
358 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
