Most digital devices can be restet by removing the battery and then powering it back on; but read the manual as that may cause you to lose your pictures depending on the device you have.
I just got a fuji digital camera. I was taking pictures and it said memory full and then the lcd screen went dark gray with a green dot in the middle. I then opened the memory card and installed it. I can still take pictures and see thru the focus lens but not the lcd screen.????? pls. help
I have 2 xelim camaras. One of which has a piece of some type of cover partially obstructing the view. This camara still displays the time and menus and older pictures. If I take pix now the picture is obscured. The other camara has no picture on the display but when I take a picture it turns out just fine. That camara will need disassembled and a connector hooked back up
Most screens on digital camaras are for aiming the camara and output (displaying the picture) therefore any problems with the screen do not translate to a picture.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
If you download the photos that are on the internal memory to your computer, the next time you take photos it should go to the memory card that is loaded. It worked for me, so I hope that helps
dont know how to take pictures with my new digital binocular camara
