Question about Car Audio & Video
Clock keeps changing back to 1:00
My delco radio clock (chevrolet 1995 truck) resets to 1 00 when engine shut off
    Genius:
  • 1,224 Answers
Your yellow power wire which is memmory is not connected to a constant power source or the fuse to the yellow wire is blown easy fix trace wire to fuse and or move yellow wire to powered
Posted on Jul 07, 2008
Everytime i reset the clock, it works fine, but when i shut the car off and then restart the car it goes back to 1 o'clock. don't know why it won't stay set to the time i put in
Sounds like the "power switch" is defective...(sticking) Try leaving the power to the radio on when you shut off your Seville...if this works great...there is no extra power drain...if this does not work...then it is cheapest to replace the radio...or if you want to maintain the AC Delco factory radio...there are a few web sites that advertise complete repair for AC Delco radios as low as $125....Hope this helps...:)
Dec 24, 2010 | 1989 Cadillac Seville
How to change time on pickup
Hold down either the hour or minute button until it changes....it takes a few seconds. Then when you have it set where you want, leave it alone and it'll keep track from there.
Jun 29, 2010 | 1995 Chevrolet S-10 CA Edition
2004 truck delco radio 5 disc cd player. cd
Common for the CD to get stuck on the Delco radio, Try resetting the radio by disconnecting the battery for 5 min and then reinstalling the cables. This will reset the radio and you should get your CD to work again, if there is an issue. You going to have to go to the dealer and they are going to have to use a Tech2 scanner to reset and reprogram the radio. If there is any mechanical issues the Tech2 scanner will identify the issues, but 90% of the time. It's just a simple reset and the other 10% is a reprogram or replacing the unit.
Thank you for using fixya and good luck.
May 09, 2010 | 2004 Chevrolet Suburban
Radio resets to AM
Take out your radio and make sure that the memory wire is getting a good connition(yellow wire)
Apr 08, 2010 | 1998 Chevrolet S-10 Pickup
Unlock code for delco radio in a chevy blazer
Try 0000 to unlock the radio, if the radio does not take any more codes you can reset the radio by disconnecting the battery and reconnecting it after 1 min. If 0000 does not work, go to radio-code.com. There is like $12.00 fee, but that's better then the dealer and you get to keep the code. Good luck
Nov 04, 2009 | 1997 Chevrolet Blazer
I changed the battery and now the radio is not working, is there a code to reset the radio? Thanks for your help!
it's not a delco loc is it?you have to pay $50 to your local Chevrolet dealer to get the unlock code
Jul 09, 2009 | 1985 Chevrolet Corvette
How do I change the time on the clock of an 1999 Chev Blazer?
turn radio off and hold the set button and use the seek/scan buttons to change hours and minutes
Jun 18, 2009 | 1997 Chevrolet Blazer
Cannot set the clock
Radio power switch off, key on but not started. Press "set" station up and scan up will then set minutes and seconds. Press set again when the time is right.
hope this helps
May 03, 2009 | 1992 Chevrolet C1500
Trying to set the clock on Delco Loc II 1990 Lumina
Turn the radio off. Push the set button until the : blinks. Push scan to change the hours and the seek to change the minutes. When complete, push the set button again and your done.
Mar 17, 2009 | 1990 Chevrolet Lumina
Delco radio in 95 blazer
With key in "on" position, but pickup not started, press the "SET" button and the "channel up" button (aka "TUNE +"). "SET" appears in radio window.
Now the "SEEK" button will increment hours and the "SCAN" button will increment minutes.
Once correct time is set, press "SET" button again to get out of clock set mode. "SET" will disappear from radio window.
Jan 08, 2009 | 1996 Chevrolet Blazer
Car Audio & Video Logo
189 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
