Question about Linksys Wireless-N WRT150N Router
After upgrading to DSL, router does not work
After I finally got DSL, my router won't allow me to connect to the internet. I can see all the lights on and my laptop shows that the wireless connection is good. But, neither it nor my desktop (that is hooked directly to the DSL and router) will access the internet.
Any help, suggestions would be appreciated!
  • sswindle Jul 06, 2008
    How do I change the ip of the router if I can't connect to the internet with it?
    President:
  • 1,314 Answers
Change the ip address of the router to 192.168.2.1. It will conflict with your dsl modem if it is set to 1.1.
Thanks and please take a moment to rate as fixya. Thank you.
Posted on Jul 06, 2008
  • Linksys Master
  • 6,487 Answers
  • Mark Gil
    Mark Gil Jul 07, 2008
    If you want to change the lan ip of the router you dont need any internet connection, you just need to connect a pc directly to the router and access the router setup page and there you can change the lan ip of the router..
    Hope that helps.......
Red flashing light on D-Lonk wireless router dsl-2750b
Means you have no internet connection. Try a new LAN cable between you router and internet modem. Connect directly to you internet modem make certain it is working. Reboot both devices.
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
Nov 27, 2013 | D-Link ADSL2/2+ Modem/Wireless Router...
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
1.Connect comp.--(gray port) router (yellow port)--modem
2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
4.On the far left column, click on "MAC address" under Internet WAN.
5.Click on clone and apply changes and finally check Internet status
6.If internet status > Not connected, we need to do a network power cycle
7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
Now, you may see proper lights lit on the router.
All my best wishes for a fast internet service through the router.
FOR PPPOE OR DSL CONNECTIONS
1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
3.CLICK ON APPLY CHANGES
For any advanced help, revert asap!
Thanks and regards,
MILAN
Jan 20, 2011 | Belkin Connect N150 Wireless Router...
Computer wont connect to internet with router
Troubleshooting steps:
1) Make sure that you can get it to work if you go from the cable/DSL modem directly to your computer
2) Assuming that works, disconnect the cable from the back of the computer and plug it into the WAN/INTERNET connection on the router and take a different cable and go from one of the LAN ports (labelled 1-4, typically) to the computer
3) turn off the computer, unplug the router and unplug the cable/DSL modem. Plug in the cable/DSL modem and wait for the lights to stabilize. Plug in the router and wait for the lights to stabilize. Finally, turn on the computer and try it.
Mar 07, 2010 | Blitzz Technology (BWA611) Router
No internet connectivity after upgrade firmware
1,there is a reset button
2,press this using any pin with power
3,automatically restart
4,connect your router with pc
5,type 192.168.1.1 on the browser
username:admin
password:admin12 or admin
configure router
enable dhcp
Oct 29, 2009 | D-Link DSL-G604T Wireless Router
IChat: No response with Audio/Video after modem/router changes
The local Apple Genius Bench was nice to reload iChat and OS for us. But he could not get iChat going for me and my relative. It looks like iChat will have trouble between DSL and Cable but DSL to DSL and Cable to Cable each case is fine. Anyway, after connecting to Apple iChat Test Site
Appleu3test04, my MacBook started to work better with iChat as my relative is able to see and hear us although on my end the incoming picture is not too clear. Then finally Upgrade of New OS seems to make the picture sharper. Thinking back, the original problem came from Modem upgrade to higher speed but I did not use the new DSL telephone filters. Please post this up to help other frustrated iChat users. Anyway, we still like Apple! By Jim on 05/30/2009
May 25, 2009 | Linksys WRT54G2 Wireless Router
Internet cutting on and off
If you haven't done a firmware upgrade I think doing so will be of a benefit to your problem! Just remember to backup your router settings beforehand! Hope this helps!
--Joshua79
Apr 05, 2009 | Linksys Wireless-G WRT54GS Router...
WAN
The wan port is what you hook your modem to. Wan stands for Wide Area Network, which in your case is the internet. Your house with your 2 pc's and networking equipment would be considered a Lan, local area network.
The 4 ports on the router are switch ports, when you hook the modem up to the switch instead of the wan port the modem will only allow traffic from one physical, (MAC) address to pass through, this is why only one of your pc's can access the internet. The wan port on the router has its own MAC address, so the modem will associate with the wan port and trust all traffic that comes from that port.
Finally, after you have connected the modem to the wan port, pull the power cord on the modem then plug it back in to reset it, this will force the modem to orient with the wan port.
Jun 01, 2008 | Computers & Internet
Hooking up rounter to cox cable
hello!
-- what is the operating system of your computer?
-- is the router working fine before or is it a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 27, 2008 | Linksys Wireless-G WRT54G Router
Lost internet connection
Change the calbe from the router to the dsl modem. Make sure you check labels on the rear of these devices to make sure the connections go where indicated. Is there and ethernet light on your modem. If that is on then the connection is made. Also check if the DSL modem works directly connected to the pc.
Jan 06, 2008 | Trendware TEW-452BRP Wireless Router...
Linksys Wireless-N WRT150N Router Logo
125 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
