Tv will not stop blinking - Televison & Video
  • 8,617 Answers
Need the model number to even begin to help you out. Please respond to this same post with your model number and I will see if I can help you out.
Posted on Jul 06, 2008
Question about a tv
You need to look up the codes for your TV.
Apr 05, 2016 | Televison & Video
How to stop my tv from blinking orange 8 times
These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 18, 2013 | Panasonic Televison & Video
Sony tv flat trinitron
Six blinks? No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 15, 2013 | Sony FD Trinitron WEGA KV-34HS420 34" TV
WHEN TV IS TURNED ON IT BLINKS RAPIDLY DOES NOT STOP WITH BLUE SCREEN
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 13, 2013 | Vizio Televison & Video
How do you stop tv light from blinking in the front?
do you mean the power indicator in the front panel is blinking?, ok does the tv working with picture and sound? if not working you can not get to stop the blinking since it tells that has an error detected by the board.
Oct 02, 2012 | JVC AV-32S33 32" TV
Panasonic tcp42x1 non stop blinking no powerup
It sounds that the main digital board has the fault. Non stop blinks of standby LED indicates that there is no serial clock, serial data flow. In other words, Bus circuit is blocked. This bus is generated from the main system control IC on the main board. As you know, there is no repair to this main board. Only replacement can be done as card basis.
Jul 07, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Our tv has a flashing power button. We cannot get it to stop flashing, and we cannot see anything on the screen.
blink--blink---blink or blink blink-----blink blink---blink blink?or blink with the OPC?
Mar 28, 2009 | Sharp LC46SB54U 46 in. LCD TV
Led has been blinking for two hours .
is it blinking constantly > or is it a number of blinks then a pause...count the blinks before the pause ..this is a repair code for your tv
Dec 09, 2008 | Mitsubishi WS-65313 65" Rear Projection...
Tv will not turn on but it constantly blinks and will not stop
You need to change the seven capacitors on the DM power supply board (inside the metal case on the left where your DTV tuner connects)They are 1000 MFD 16 VOLT capacitors and the tops are probably bulging outward because they are leaky- this is a common problem.When you lost power,the TV had to reboot itself but because of the leaky caps it never will and the green light keeps blinking.As long as you never lost power or unplugged the set the TV would of still worked.Once you change the parts and plug the set in the light will blink normaly for about a minute and when it stops blinking you can then turn on the TV.
Aug 30, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
