Question about Canon EOS-20D Body only Digital Camera
LCD Screen Okay, Like an idiot, I turned off my LCD screen, long ago, so that I could use the viewfinder since both cannot be used at once. I would simply like to know HOW TO TURN THE LCD SCREEN BACK ON!!! it has driven me crazy, the book doesn't help, I have gone through resetting to default settings and nothing. I think I have really changed something in the setup and I hope I can reverse it. Anyone with a solution??? Please??? Driven Crazy by cam Rebecca
  • 10 more comments
  • Rpalay Jul 07, 2008
    I'm afraid the problem is MUCH deeper and more like a setting issue....need real technical support. I have removed the battery MANY times because I still use the camera, just need to use the viewfinder, arrrgh, Would Like The LCD Screen back. Anyone else have a suggestion?
    I have reset this camera to default settings hoping the screen would come back but it did not even when returned to default settings....No live View Option - it seems to be much more of a complex camera, than that....
    thanks for pointing me toward site but that is not the problem.
    I did that, both regular settings and custom settings - screen still did not come back but all other settings were returned to normal.
    no That is not what I am trying to do, I am well aware that it needs to be one or the other when taking pictures. There is a series of settings that shut off the screen so the viewfinder can be used. I did that but I can not reverse the process so the screen comes back.....
    On this model, I know I cannot use the viewfinder and the screen at the same time, when I first got the camera, it was set up with the screen working. i went through a series of steps explained in the manual in order to use the viewfinder, shutting off the screen. Now I cannot get the screen back!
    why would the computer software have anything to do with the settings on the camera?
    And holding did do NOTHING.
    i am speaking about the screen viewer
    it is a setting issue because I was able to turn off the screen to use the viewfinder but not able to reverse the setting process and there seems to be no help in the manual.
    yes, I have found that also, unfortunately, this is not what I am trying to accomplish. I just want to turn the screen back on so that I can say...film movies and watch what I am filming w/out having to hold the camera to my face. When I first bought it I was able to use the screen and then I did a series of steps because I wanted to try with the viewfinder...now I only want to turn the screen back on for view purposes not picture taking purposes.....It is very confusing.
  • Rpalay Jul 08, 2008
    I really have tried everything that the manual says, restoring default settings, restoring custom settings and it is rather distressing because I know that it is a setting that I set and I can't remember the sequence nor reverse it...
    and to fix I would need to bring to a repair shop?
    Master:
  • 788 Answers
See this knowledge base article at Canon: http://canoncanada.custhelp.com/cgi-bin/canoncanada.cfg/php/enduser/std_adp.php?p_faqid=5512&p_created=1159803947&p_sid=8S1Ukf8j&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTImcF9wcm9kcz0xMywyNzEmcF9jYXRzPTAmcF9wdj0yLjI3MSZwX2N2PSZwX3NlYXJjaF90eXBlPWFuc3dlcnMuc2VhcmNoX2ZubCZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PWxjZA**&p_li=&p_topview=1
Most dSLR cameras from previous generation cannot use the LCD to compose shots as the imaging sensor in the camera si CMOS based and not CCD like most point and shoot cameras. I beleive newer dSLRs have rectified the problem but not in your EOS-20D. So you may think you changed a setting but in fact what you are trying to do is impossible.
Posted on Jul 08, 2008
    Genius:
  • 2,035 Answers
Please use these links:
http://www.advancecamera.com/repair/
http://www.precisioncamera.com/
Good luck.....
    Guru:
  • 1,894 Answers
The solution provided by voodoomox must help i think
have you tried pressing the DISP or DISPLAY button once or twice??
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Your computer may be in powersave mode, try typing something or moving the mouse
    Genius:
  • 1,665 Answers
Posted on Jul 07, 2008
  • 405 Answers
See this link from canon support under EOS 20 D support:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=215&modelid=10464
Issue: How do I use the LCD as a viewfinder?
Solution: Due to the design of the camera, this feature is not available.
Due to the design of the camera, this feature is not available. For this feature to be available, the camera must be capable of flipping the reflex mirror up, open the shutter, and read a live signal from the camera's LCD. Unfortunately this is not possible on this model.
  • Patrick McGee
    Patrick McGee Jul 08, 2008
    You are trying to do somehing that the mechanic's of the camera won't allow, there is nothing wrong with the camera so bringing it to a repair shop will do nothing other than waster your time. Your model of camera is not designed with that feature as many experts have already stated.
    Due to the design of the camera, this feature is not available. For this feature to be available, the camera must be capable of flipping the reflex mirror up, open the shutter, and read a live signal from the camera's LCD. Unfortunately this is not possible on this model!!!!!!!!!!!!!!!
    Sergeant:
    Champion:
  • 347 Answers
Hello Rpalay,
Did you already tryed changing the battery? Or recharging the current one?
  • 2 more comments
  • Santiago Vallejo
    Santiago Vallejo Jul 07, 2008
    Rpalay,
    follow this link.
    If it dosent help you, let me know and i will further assist you
    http://www.usa.canon.com/consumer/contro...
    Dahaka
  • Santiago Vallejo
    I think your current problem is that your LCD panel backlight is turned to 0.
  • Santiago Vallejo
    From canon's website
    The LCD panel is provided with illumination.
    Each time you press the <> button, the LCD panel illumination will turn on () or off. Use it to read the LCD panel in the dark. The illumination will turn off automatically after the shot is taken.
    Following this link you will see a detailed picture.
    http://usa.canon.com/app/images/service_...
    Dahaka
  • Santiago Vallejo
    Santiago Vallejo Jul 08, 2008
    @ maklean.
    i doubt that is going to work since i posted that solution here first, and he say "thx for trying"
    why do you come back again with the same solutions other have already posted?
    Genius:
  • 1,689 Answers
Well if this is a canon point and shoot or dslr, you may press the display button twice and that should turn the LCD back on.
    Guru:
  • 859 Answers
Its in your tools options. I'll look it up on my Canon and post back.
Worldvet
  • 1 more comment
  • Glenn Rogers
    Glenn Rogers Jul 07, 2008
    It is highly likely that your camera is SLR only, and this my explain why you can't find a compose via LCD panel. My Canon EOS won't, even though I was confused as we have three digital and two SLR film cameras here. We're outdoor photographers and shoot for magazines by assignment in Nevada.
    Sorry, but until these camera have OLCD or organic liquid crystal displays you will still always face the washed out LCD panel in daylight conditions. Kodak (naturally) bought into the patent for OLCD technology but the military is still using it in military fields. OLCD is not affected by sunlight, it is like looking at a photo in a magazine in daylight conditions because the organic molecules that make up the red, blue and green pixels are not back lit.
    Sorry.
    Worldvet
  • Glenn Rogers
    If you would be willing to give me/us some time we can get you an answer. Sorry, I thought your camera was close enough to my EOS to be the same, but apparently not.
    We/I will get your problem solved.
    Thanks for your patience,
    Worldvet
  • Glenn Rogers
    Sometimes our category selector doesn't always offer the actual models someone's has.
    Are you actually referring to the EOS 20D camera?
    The Canon web site at this page. Is resulting in this messge when I asked "How do I use the LCD as a viewfinder?
    If you feel this answer from Canon is not correct based on what you stated to us above you may contact Canon support at the below phone number.
    For toll-free technical support, please call 1 (800) 828-4040 during regular business hours (currently Monday-Friday 8:00 a.m. - 12:00 midnight. EST, Saturday 10:00 a.m. - 8:00 p.m., excluding holidays).
    Sergeant:
    Champion:
  • 250 Answers
There should be a live view option in your settings. Turn this on to have the LCD on to take pictures.
  • 2 more comments
  • Frank Gant
    Frank Gant Jul 07, 2008
    The manual states on page 32 "The LCD Monitor Can Not Be Used As A Viewfinder For Shooting."
  • Frank Gant
    Is this what you're trying to do? Use the LCD as a viewfinder? With that model that function doesn't exist per the manual on page 32.
  • Frank Gant
    A new use for the rear LCD is previewing your shot in Live View mode. We first saw this excellent feature on the 1D Mark III. Basically, you can preview your 40D shot just like on a typical point and shoot camera. Enable Live View (a menu option - I leave mine enabled), press the "Set" button (which raises the mirror and opens the shutter) and see the image live on the LCD. Live View focus is manual-only with one exception. During Live View, the "AF-ON" button can be pressed to enable autofocusing (the mirror temporarily lowers to make this happen).
  • Frank Gant
    that info is for the 40d. The 20d does not have the ability to do that as the mirror doesn't move.
  • Canon Master
  • 19,396 Answers
Try removing battery, it reset many models
  • 8 more comments
  • Ginko
    Ginko Jul 07, 2008
    check the option for superimposed display as illustrated at page 144 of
    INSTRUCTION MANUAL
    do also reset all custom functions as in page 140 of the manual.
  • Ginko
    Ginko Jul 07, 2008
    Check bottom of page 140. Resetting all custom function should fix it. Follow the instructions.
  • Ginko
    Ginko Jul 08, 2008
    Did you reset custom functions?
    If you tried all suggestions and display is not working at all it can be a faulty lcd display, in this case you need to contact a service, in this case follow instructions on the last pages of your owner manual to get a service in your area.
  • Ginko
    Ginko Jul 08, 2008
    also copy and paste, or type here the instructions you followed to disable display, it can help us to understand the problem.
  • Ginko
    Ginko Jul 08, 2008
    try also restoring camera default settings procedure, at page 32 of user manual.
  • Ginko
    Ginko Jul 08, 2008
    If you do not try procedures in the manual we are not going anywhere. do both reset suggested at page 32 and page 144 of this manual.
    If they do not work, it is not just a matter of settings, there is not much else to say.
  • Ginko
    Ginko Jul 08, 2008
    If you reset both settings, then there is a fault, or the lcd or one of the buttons, it coincided with your setting change by chance.
  • Ginko
    Ginko Jul 08, 2008
    Also check that the display button is not stuck, eventually keep it pressed for ten seconds.
  • Ginko
    Ginko Jul 08, 2008
    If there is a part to diagnose and eventually replace, then it is better to take it to a repair shop. Taking apart the camera require experience, unless you want tto risk causing further damage to the camera.
    In case the problem it is just a matter of settings (it should not at this point), you can try having it done at the shop bank, sometimes even for free. Unfortunately if I do not think this can be fixed just by pressing a couple of buttons.
  • Ginko
    Ginko Jul 08, 2008
    Let us know if you need further help.
Canon EOS-20D Body only Digital Camera Logo
224 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
