Question about Maytag Kitchen Ranges
F-o-on face of stove................keeps beeping
  • 868 Answers
Your touch pad (electronic -control ) Replace it and your problem is gone.My opinion is that water (sponge cleaned) has found its way through the touch pad and caused this.Tip: clean clock area with a damp towel only. Please rate This !
Posted on Jul 06, 2008
How do I fix my stove?
I would suspect the keypad having intermittent key contact, especially if this is a GE or older Whirlpool wall oven, check by model # on a parts site to see if a key panel is available for it and start there...
Apr 22, 2016 | Kitchen Ranges
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
My stove keeps beeping and the oven wont come on its reading f1 on the face
This is usually a failure in the control board. The control board can be repaired. Here's a discussion of error codes for the GE models:
fixyourboard.com/techzone/ovens/f1_error/f1_error.html
Sep 19, 2010 | Ovens
My stove has F1 on the screen,and i beeping. I
Sorry it can not be reset.
The F1 code is a failed electronic control. The clock/oven control must be replaced.
Jul 05, 2010 | Amana ACS7270AS Electric Kitchen Range
F4 comes up on my stove, keeps beeping what to do
Sorry to say you will need an engineer to check the heat sensors as they may be faulty
Sep 21, 2009 | GE Ovens
All igniters on my stove top won't turn off - keep beeping
Sounds like you might have a grounding or polarity issue with the power supply.
Jan 08, 2009 | Viking VGSC366-6B Gas Kitchen Range
Stove with LED clock display, need to be set
Try holding 2 buttons at a time and whilst doing so, press the button with time on it or clock face, or just keep trying different buttons until myou get the right combination, stick with it you will get it to go.
Dec 15, 2008 | Stoves Ovens
Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Jun 14, 2008 | Frigidaire FGF326AS Gas Kitchen Range
Kitchen Ranges Logo
81 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
