Question about SanDisk Sansa Clip MP3 Player
Problemmm i have a sansa clip and it doesn't turn on, and when i plug it into my computer, the computer just turns off. its so weird. please help.
  • 8,596 Answers
Make sure the hold/lock is not engaged - the full user's manual can be downloaded from Sandisk's website.
Oh, also, if you have Windows Vista, get the Vista compatible software from Sandisk's website
Posted on Jul 06, 2008
When i turn on my sansa clip, it says not enough space, please free 90 mb, and when i connect it to the computer, nothing shows in the sansa clip file, not even the songs i have. what should i do?
Try resetting the player.Hold down the Power/Reset button for about 15 seconds to perform a normal reset.
If it doesn't help then try the one below.
This will reset the player to its original factory settings.
1. Press Menu to return to the Main Menu.
2. Move to Reset All and select it.
3. Select Save to reset to factory settings or Cancel to stop
Aug 18, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Clip won't work. When I turn it on it says: Not enough space for music DB Please free 30 MB. But when i connect it to my computer it doesn't register. PLEASE HELP ME
Because you drag 7 drop songs or files too much into the sansa clip in MSC mode, it causes like that.
Turn it on, it will show " Not enough.....free 30 MB", and then automatically turn off. Plug it into pc, open my computer, it will be under name "Sansa clip..." or "removable disk ". If your pc does not recognize it, unplug again and replug it.
Open Sansa Clip..., or removable disk, and delete some songs.
Good luck
Apr 30, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip 2gb wont turn on! Not even when i plug it into the computer! Please Help Im Desperate.
Plug your device into computer and let it about 30 minutes to 1 hour.
Then, unplug and turn it on.
If it doesn't work, you should change another one.
Good luck
Jan 13, 2010 | SanDisk Sansa Clip MP3 Player
Sansa Clip won't charge
Here's the thing, technically it doesn't need to be turned on because it's supposed to turn on by itself.
I've had a problem sort of like that. It might be the plug, but it also might be the computer. I'd either suggest try plugging it into another computer or getting a new plug.
Apr 18, 2009 | SanDisk Sansa Clip MP3 Player
Sansa Clip does not show up on computer
I had the same problem all you've got to do is first turn on the sansa clip.Then go to settings. After that scroll down to USB mode (second from bottom) then it woul probably say auto detect. Scroll down to MSC then hit enter. If that doesn't work try MTP mode.
Jul 11, 2008 | SanDisk Sansa Clip MP3 Player
Frozen
There is a fix, but it is going to delete all the songs off the player, so you will have to reload them. Disconnect the Sansa Clip from the computer. Slide the power button up for 15 seconds to turn the Sansa Clip off. Hold in the volume + button, and reconnect the player to the computer
Apr 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip not turning on
I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Apr 20, 2008 | SanDisk Sansa Clip MP3 Player
Get the latest firmware for the player - should solve the problem (may require a restart of your computer after upgrading).
Computer not recognizing mp3 sansa clip
Comment by vickisanchez, posted on Mar 19, 2008 IT FINALLY WORKS !!!!
Sandisk Tech support had me do the following:
- Turn it OFF
- Put it in the HOLD position
- HOLD the center button IN while plugging into USB port, continue to hold for 5 to 7 sec even after plugged in.
At this point MY COMPUTER recognized it. And it worked.
He also had me to:
- go to WWW.MICROSOFT.COM
- In the upper right hand search bar, type in MTP PORTING KIT
I did this and downloaded the first one. Now my Sansa Clip work perfect. I wish I would have talked to him last week before I returned the last one, for the same reasons.
If this does not help call the 1-800 # , opt #4, and ask for GUY (yes that is really his name) out of 5 or so calls to Tech Support he is the only one who knew what he was doing, and how to actually HELP.
GOOD LUCK
Apr 09, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
