Question about Friedrich Heating & Cooling
Friedrich challenger air condition remains on high cool even when temperature is turned down
    Sergeant:
    Champion:
  • 330 Answers
Automatic thermometer doesn’t function
Posted on Jul 06, 2008
Friedrich CP24F30 money saver mode not working
Money saver mode dose not regulate room temperature. All that mode dose cycle fan on and off with the thermostat if in the yes position then fan cuts on and off with the call for cool. if in the no position than fan runs all the time even when cool is not needed. that switch is like the auto/on on a thermostat for central air. the thermostat is what regulates temp in room.
Jul 01, 2014 | Friedrich Heating & Cooling
Friedrich Breeze air conditioner is not cooling. Repairman says there is nothing wrong because cooling coils are cold. I now think it is the sensor that is not working because I cannot get a room...
Are you the owner of the air conditioner or the repairman.. haha.. this repair man tells you nothing wrong and you are not satisfied with that... did he tried to check the filter, repairman is right when cooling coils are cold you are supposed to feel a cold temperature but only when the filter is clean and i assume the fan is working good..
Sep 22, 2013 | Friedrich Breeze Br0412w1a
My Friedrich A/C is turning on and off by itself, can you help me?
when the room reaches the set temperature the unit is made to cut off until heating or cooling is needed again, this is the units way of not cooling or heating too much.
May 03, 2011 | Friedrich Heating & Cooling
Friedrich Wallmaster is not throwing cold air.
I have the same problem - bought mine 4-5 years ago been suffering ever since - spent so much money on Friedrich and still using fans. Piece of ****.
Aug 21, 2009 | Friedrich M18CF Split System Air...
Friedrich quietmaster fan does not come on and compressor sounds like it might be laboring when switch is turned to high,medium,low cool. The airconditioner does work if the money saver switch in on. Once...
Shut the power off to the unit, spin the fan blade to see if it spins freely. If it doesn't spin freely, (there appears to be a little drag when you spin it),the bearings are bad, if it does spin freely, then try moving the motor shaft from side to side if there’s any play in the shaft side to side then the bearings are worn and motor needs replaced. Then, check the capacitor, if it’s bulging even slightly, the capacitor is bad and needs replaced. Most of the time people replace the capacitor if motor seems ok. If capacitor is ok, turn power on to see if the motor is getting the proper voltage, if it is and not trying to run, then the windings are probably open, the motor's bad and needs replaced.
Jul 29, 2009 | Friedrich QuietMaster SL36L30 Air...
Squealing and sometimes doesn't blow cool
A squealing noise is most likely the bearings going bad in the blower motor. This will slow the motor down. If the blower is not operating at the proper speed this will affect the temperature pressure relationship of the refrigerant. This will cause the unit to put out the wrong temperature. Running the unit to long under these conditions can possibly cause further problems ( including a very high electric bill). I recommend that use do not use this unit untill it is repaired or replaced.
Good luck.....
May 03, 2009 | Friedrich M18CF Split System Air...
Central Air Conditioning
It sounds like a restriction in your ducting. Feel the A/C vents in the hot rooms to see if cold air is blowing out of them. If the ducts are restricted, then it is possible that the air conditioning coils are freezing up from lack of circulation. Inspect the ducts if you can to see if there is any restriction.
Note that even if you feel air coming out of the ducts, it could be ambient as opposed to cold. The best thing is to measure the air temperature coming out of the ducts. It should be around 20 degrees colder than the ambient air at the intake of the A/C.
Sep 03, 2008 | Computers & Internet
Heating & Cooling Logo
456 people viewed this question
Top Friedrich Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Michael Vincent Cruz
Are you a Friedrich Heating and Cooling Expert? Answer questions, earn points and help others
