Question about Whirlpool GGW9250PL Gas Dryer
Burning smell I have a new Whirlpool Duet Steam Dryer and the first time it was used, we smelled a burning smell.  Everything seems normal, but the smell is awful.
  • cwashuk Aug 31, 2008
    Same exact problem...seems to work fine, just the smell.
  • Anonymous Oct 26, 2008
    I just turned our new whirlpool gas dryer on for the first time and it has a burning smell. I hope it goes away as well!
We had the same problem. After we used it a few times, the smell went away.
Posted on Sep 07, 2008
Burning smell and rattle sound
The rubber drive belt is burning up most likely cause by bearing going. The bearings are your ratteling sound and the burning smell is the rubber belt dragging.
Apr 08, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Kenmore whirlpool dryer won't start and has a bad burning smell
You may have an overheat sensor that is burning up. The dryer won't start because the heat would be uncontrollably high otherwise
Jan 29, 2013 | GE Profile DPSF495EW Dryer
Dryer has a burning smell. repair man came and looked at it and said mechanically the dryer looked brand new (its only 11months old). He suggested we repair the exhaust tube and vent (which we did). ...
do you have pets ie a dog that moults, as quite often its is foung that pet hairs get inside on the elements and cause a burning smell. if so disconnect from supply. Remove back cover by removing screws and hoover the elements. Make sure electric is off hope this info is useful.
Dec 16, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
We purchased this product a month ago and it seems to be giving off a burning type of smell which we can smell both outside the vent and in the dryer itself. it seems to work fine
If it smells like an oily burn then it is just the oil burning off of the new parts in dryer, this is common. If it smells like electrical burning then call the manufacturer for repair. Could be a wire burning and if it is new it is covered under warranty.
Jun 14, 2010 | Whirlpool WED5800S Electric Dryer
Vent was cloged with a birds nest now it wont heat
IF POSSIBLE REMOVE THE DRYER VENT FROM THE REAR OF THE DRYER AND VACUME OUT AS MUCH LINT FROM THE DRYER ITSELF SOME LINT MAY HAVE GOTTEN BACK INTO THE BLOWER
Sep 02, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer keeps tripping breaker. slight burning
The heating element is shorted. This is an electric dryer, right? replace the heating element. Make damn sure it's un-plugged when you work on it!
Jul 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Brand new Whirlpool Duet Sport gas dryer & burning plastic smell
I would consult the place of purchase. If they do not stand behind the product, then get the manufacturers support #. They will stand behind their product, especially if it is a possible fire hazard. THe smell you are smelling could be anything, but without being there and taking off the cover and doing a visual check. it's hard to dianose. It is possible that something that is plastic has fallen out of a pocket and gotten inside the unit while it was drying clothes and fallen onto the igniter housing.
Nov 18, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Duet Dryer
burning smell would be coming on the coil of an electric dryer. the coils could have catch some lint that produces that distict burning smell..
i hope i was able to solve you problem..
pls rate me.
tnx
drcool
Jul 15, 2008 | Whirlpool GEW9250 Electric Dryer
Duet dryer
be sure wires on back at ac connection are tight loose connections generate heat and will cause wires to burn also be sure they connected properly this problem usually falls under installation problems not dryer problem
May 28, 2008 | Dryers
My Duet Whirlpool Dryer (had this #8519498) has burning smell
I am not the Dryer fixin' trade...but I have this dryer. To me, it sounds like it overheating or the heater unit has become lose from its hold rack. I would MOST definitely have a pro look at it and do NOT leave the dryer unattended...It may be a possible fire hazzard
Take Care
Wayne
Jan 03, 2008 | Whirlpool GEW9200L Electric Dryer
Open Questions:
Strange issue with my gas dryer and the control panel I am having a strange issue with my dryer. I have a Whirlpool gas dryer, Model: GGW9250PW0; and am having issues with the Electronic Control (mfg part 8558753). Yesterday, I went to go use the dryer and I press the "Control On" button like normal, but nothing happened. I did not get any lights or anything, yet when I open the door, the inside light comes on. I have a similar model washer plugged into the same electric outlet and everything there works fine. After researching the issue out a bit, I took off the toe panel and took off the duct-lint (mfg part W10128606) so that I could reach the wires connected to the dryer thermister and dryer thermal fuse better. I then took the wires off both of those as well as disconnected the sensor wiring harness (mfg part 3406653) and used a vacuum to clean out any lint as well as compressed air to clean off those connectors. I re-hooked all the wires back up and plugged the dryer in. I pressed the "Control On" button and all the proper lights lit up. I then pressed the "Cancel" button to turn it off, unplugged the dryer, and put the duct-lint back on. I plugged the dryer back in and tried the "Control On" and "Cancel" again, and it still worked. I then put the toe panel back on, pushed "Control On", then turned on the dryer using the "Hold to Start" button and everything worked like it used to. Here is the strange issue I am having. I ran a load in the washer and when done, I put in the dryer and tried the "Control On" button. Everything came up, but when I pressed the "Hold to Start", nothing happened. I then tried to press the "Cancel" button, and nothing happened. I could turn the knob and the different lights lit up, but none of the buttons seemed to be working. After holding the "Cancel" button for a few seconds it turned off the panel lights. I then pushed the "Control On" button again and had to press it a few times before the panel lights came on. After a little bit of playing with the buttons and knob, I was able to start the dryer. I stopped the dryer (didn't want to run it the whole time in case something is wrong) and tried to start it again. I can get the panel lights to come on, but it seems like the buttons are sticking and not fully working like they should. I don't want to have to buy an expensive part unless I absolutely need to and wanted to see if anyone can think of anything else that might be going on or that I could try before paying almost $200 for a new Electronic Control, especially if I will still have the same problem after replacing this part like some other people have reported. Thanks!
Jun 14, 2013 | Whirlpool GGW9250PL Gas Dryer
See all Whirlpool GGW9250PL Gas Dryer Questions
Whirlpool GGW9250PL Gas Dryer Logo
850 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
