Question about FIC P4M-915PD1 Motherboard
Wndows sp 3 took out my graphics , no video, amd processor
Help
SP 3 auto updated on my computer. AMD processor,now no video and no boot.
I cannot even get BIOS up.
Installed a new video card. no change.
no boot. no BIOS, No monitor.
Microsoft said they were sorry..
Any help?
thanks
Hi, I have a PC Win XP home SP 2 on CD, now SP 3 updated, Sockel 754 with a AMD Prozessor Sempron 3000+ and Chipsatz NVIDIA Force 6100 nForce 405 and sockel Purchase 2006/Sept. This is my...
have you tried to update drivers at ports(com&lpt)
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
hope this helps
Jul 22, 2011 | Asrock K8NF6G-VSTA Motherboard
Dear Sirs, After completed installing os to ibm notebook from Recovery discs.And having updated Winxp services Pack 2&3 and drivers etc., H/ever,it appears blue screen again & again when start...
A lot of times BSOD is caused by corrupted RAM you can try running a memory scan using memtest software available online. Or if you have multiple sticks of Ram trying removing one and booting, if that doesn't work put that one back in and remove the other.
May 11, 2011 | Microsoft Computers & Internet
I have no graphic driver for amd athlon(tm)64 processor 3800+ 2.40ghz for windows xp
Take a look at my guides they are as follows:
How to install Graphics Drivers, Nvidia and AMD Radeon!!!
As you will need to install the drivers for your graphics card to get a better resolution and video quality! You will need to know the make of graphic card you are using either Nvidia or ATI/AMD Radeon
How to Download AMD Processor Driver!!!
As you can download and install the latest Processor drivers for your computer.
Happy Computing!
Thanking you
damnor01
Feb 22, 2011 | AMD Athlon 64 X2 3800+ Dual Core Processor...
My hp vs19 computer screen was working fine when i shut down and now it won't power on at all.
HPw1907 monitor on "built up" computer. Processor is AMD Sempron 2800+(800)S754, Video card is Navidia, Albatron GF FX5500. Operating software is Windows XP home, SP 3.
Factory brightness setting is much too high. Each time that I restart the computer after shut down, I must reset the brightness setting. Immediately after startup, brightness is OK; after a few seconds, the monitor goes into auto adjustment, and goes back to factory setting and I have to reset.
I will appreciate any help that is provided.
Dec 03, 2009 | Office Equipment & Supplies
Listen!i had wndows sp2 and had 25 gb hard disk
some high configuration as 4 gb ram can not support sp-2. there we can use sp-3. what type of problem in your compputer? it isnot clear to say solve problem
Nov 03, 2009 | Intel Pentium D 915, 2.8 GHz (BX80553915)...
Computer Does not work correctly with Radeon 9250 Graphics Card
Hmm? Everything except replacing the motherboard, sometimes it does not get any better, but...go into your BIOS and turn off the Gateway splash screen. It will be an option in maybe the first or second menu choice. Make sure your on board video device is disabled and save your options when exiting. Good luck and let me know how it turns out.
Jul 02, 2009 | MSI MS-5185 Motherboard
I want an upgrade on my video card...
more cpu and a better graphics card, id say get a amd athlon x2 dual core [Cpu]
And a Nvidia Gefore 8800GT
May 28, 2009 | Computers & Internet
Where i can get the for free driver amd athlon(tm) xp 3000+
Processors don't need drivers. Drivers for your motherboard come from the motherboard manufacturer in most cases, unless you have a name brand computer in which case the come from the computer manufacturer.
Mar 10, 2009 | AMD Athlon XP 3000+, 2.1 GHz...
FIC P4M-915PD1 Motherboard Logo
41 people viewed this question
Top FIC Computers & Internet Experts
David
David
John Anderson
John Anderson
Are you a FIC Computer and Internet Expert? Answer questions, earn points and help others
