Question about Frigidaire FEF365AS Electric Kitchen Range
Still not working
The only one that seems to do anything is the first when I hold it in it then starts beeping and flashes F1. any suggestions?
  • Luchie26 Jul 08, 2008
    Thanks for all your help and for trying to fix the problem!!!!
  • 4,889 Answers
It looks like Clock/Timer and the Clock Overlay are toasted! You ill have to get them replaced. Estimated repair cost is around 100-150$
Posted on Jul 07, 2008
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
I am not able to wash any laundry. when I press start.....F1 flashes and a beeping noise sounds. I am unable to cancel it out, open door... anything. Nothing works.
Hello
F1 error and the beeping sounds in your Kenmore front load washer means that the Electronic control board has gone bad and needs replacement. You can buy the parts from Sears if you want to do the repair yourself. Please get back to me if you have any other questions.
Kevin
Nov 14, 2010 | Kenmore 46472 Front Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
The stove just says F1 and beeps won't let me do
Hello with the limited information and no make or model I can only give a generic response to this one. Most manufacturers F1 code indicates a bad control board (EOC) and or a bad touch-pad. If you have any other questions please feel free to comment. Mike
Nov 03, 2009 | Ovens
My stove has started to beep random--why
WE used the broil button last night and our stove started beeping nonstop.It also say F1 three hrs of beeping we unpluged it for the night.When we turned it back on today same thing happened with the beeping and F1.hOW CAN WE FIX THIS?
Oct 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Maytag MER5770AAW Oven
f1 is a bad range control/ touchpad, here the part number for a white clock for model number MER5770aww 74008106 approx 150 bucks
Apr 08, 2008 | Maytag MER5770 Electric Kitchen Range
Beeping, flashing, oven door locked, display shows F-1
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) BUT you also need to check the Oven Temperature Sensors The Oven Temperature Sensors should read room temperature, 70°F, the resistance is 1000-1200 ohms. make sure you pull off the wires to measure the sensor's resistance and it reads open it is bad. and you will have to replace it too. hope this helps.
Sep 05, 2007 | Jenn-Air SCE30600 Slide-In Electric...
Error code F1
Error code F1 is for a defective touch pad or membrane (usually the touch pad). In this case you will need replace touch pad or membrane. It seems that water entered the touch pad during the self cleaning process, remove the touch pad and try to dry it. Good luck !!
Jun 08, 2006 | Maytag MER5530 Electric Kitchen Range
Frigidaire FEF365AS Electric Kitchen Range Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
