Question about Amana Kitchen Ranges
MY OVEN WILL NOT HEAT UP MORE THAN 155 DEGREES
  • 868 Answers
Replace the control electric thermostat.
Please RATE This !
Posted on Jul 06, 2008
Thermoststat defective need new one
they only make 2 types...normally open or closed 155 degrees + or -
use a VOM reed the old one if it shows open you need a normally closed thermostat..$5 or less
Apr 11, 2014 | Thermador 30 inch Masterpiece Series...
Oven would not light. I replaced the igniter and now it lights but it will not heat past 200 degrees. Is this the thermostat acting up or is this connected to the gas supply? Any suggestions??? My oven...
when you say now it lights. is just the ignitor lighting?or can you hear the gas flowing??? can you feel it heating at all?? should start at 100 degrees and climb up from there. no reason for it not to heat past 200 (unless set to Celsius which default setting of 350 =190degress) therefore will not heat past 200. and wont let you try to heat to 425 , that would be off the charts of Celsius conversion. sensor problem would eitherno t let stove come on or wouldnt stop from heating eitherway a code would come up in the display
Mar 14, 2008 | Kitchen Ranges
Estate electric dryer
You will need to check the temperature coming out of the dryer when on high heat. It should read around 160 degrees on the high end, and 110 degrees on the low end. If it is cycling before the 155-160 degrees mark, you may have a bad cycling thermostat.
Here is the thermostat to order.
Here is a video to show you how to replace the thermostat.
Regards,
Richard Roth
http://appliancecafe.com
Nov 16, 2012 | Whirlpool Dryers
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
Jul 28, 2012 | Hotpoint Ovens
On my Kenmore Soft Heat Heavy duty gas dryer I am having problems with the the fire lighting and going off intermentently . The fact that it ignites and then goes out makes me think that it isn't...
Hello Jerry,
It is working like its supposed to when the flame goes off, the way all dryers work is the flame(heat element on electric heated dryers) comes on and when the drum exhaust temp reachs a maximum of 155degrees and the flame goes off, the air temp will cool off to 120degrees and the flame comes back on and cuts off once again the 155 degrees has been reached..much more that 155 degrees the clothing is very likely to combust and catch on fire.
Please reply and let me know if your having a dryability issue with your dryer or where you just concerned since the flame went off??
GENE
Sep 05, 2011 | Kenmore Dryers
The Amana oven will not heat over 250 degrees.
check the ovens thermocouple in the oven cavity roof,it sound like its defective and sending an erraneously bad signal to the control board
Nov 18, 2009 | Lands Phones
Amana Oven ARG7800E - Oven will only heat up to 150 degrees.
u sure the flame is lighting sounds like it isn't make sure u physically see the flame u might just be seeing the glow of the igniter if it doesn't light more than likely the igniter needs to be replaced
Jun 27, 2009 | Ovens
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
Kitchen Ranges Logo
54 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
