Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking 8 times
Turns on and turns right back off-- blinks up to 8 times. Is it worth fixing or should I trash it?? It is about 5 years old.
  • 2 more comments
  • jbrayman Jul 08, 2008
    I try to turn on my tv and the power/standby light just blinks. I try using the remote and the switch on the tv to try to turn it on and nothing happens. Eventually it will sometimes turn on after 10 or so tries, but it is getting worse. This just started happening about two weeks ago and I have had the tv for just over three years.
  • rustyjah Jul 18, 2008
    I turn on the tv the picture doesn't show or no sound but the stand by light blinks multiple times it sounds like it turns on but no picture shows up how can I fix it
  • candykisses4 Aug 10, 2008
    I have had the tv for almost 7 years. Just the other day I tried to turn it on and the tv sounded like it was coming on then would blink a few times and stop then blink some more before turning itself off. Neither pushing the remote nor the buttons on the tv help. I tried unplugging the tv to see if something was messed up during the storm we had but still no picture or sound comes from the television.
  • bareacal May 11, 2010
    What does repeated 6 blinks of standby light mean (when set is turned on and immediately tuns itself off)?
  • 125 Answers
This kind of tv have a good picture if you use the component input
most sure you have problems on the zero cross detector or the flyback
I did one like this one for 200.00 if we need the flyback goes up to 275.00
Posted on Aug 06, 2008
Toshiba 32av502r green power light flashes not turn
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 19, 2013 | Televison & Video
Powers on then right back of light flashes 8 times
Looks like a problem on the convergence board which requires repairing/replacing..
Oct 30, 2008 | Sony KP-51WS500 51" Rear Projection...
My 3 year old Sony kdf50e2000 lcd tv is shutting off then green indicator light blinks continuously. Sometimes it turns back on by itself. If I turn it off with the remote when the indicator light is...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 13, 2017 | Sony KDF-50E2000 50" HDTV
Sony wega and i get 4 blinking red lights
4 blinks code shows problem in Vertical Deflection section of TV. Of course it worth to be repaired. If you are not familiar with TV repair then call TV tech to fix it. And if you are tech person, let me know to help you out with tech info.
Jan 09, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
TV Turns self off- 4 blinks on standby light
Yes, the blinks are error codes. I would not bother trying to figure out what they mean, I can tell you right now. Expensive repair. Average repair costs are 1/4 to 1/2 of the TV's current worth. Most likely a bad transistor. The average expected life span of a TV set is 3-5 years. After that, stuff starts wearing out fast. Time to move on.
Nov 14, 2008 | Sony KV-28FX60 28" TV
Blue Screen and TV shuts off
Here's a shortcut to what the blinking codes mean.
http://www.somelifeblog.com/2007/08/sony-tv-led-blinking-codes-what-does-it.html
Strange how some people have 5 blinks. Most with this problem have 8 blinks (like myself)
I still have the blue-flash-then-shutting-off problem.. (8 blinks meaning voltage error) but I did fix the blue lines.. The lines across the screen can be very easily fixed whether they're blue green or red. . No, I mean REALLY easy. Took me longer to get the cover off. Once the front cover is off it takes 10 seconds. This link was also posted recently in one of the posts below as a solution..
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
(My lines didn't look like the ones in the picture mine were several evenly spaced blue arcs)
After some research I believe the flash/shutting off problem means the CRT is going. I've also read that it might be the D-board and I'm not even sure that that is... But If it is indeed the CRT then I'll let you know it's very difficult to find a replacement blue CRT as this part has been discontinued.. but I did eventually find an alternate to an alternate part (yes that's the 3rd alternate !)) online for $256. Here: http://store.tv-repair-service-salinas.com/8-733-649-35.html
If you're bold enough to attempt that then good luck and please let us know if it worked.
Or another alternative is there's a whole lot of Boxing Day sales goin' on right now.
Jul 12, 2008 | Sony KP-51WS500 51" Rear Projection...
Will not turn on blinks 9 times then 5 times
heat the deflection board with a hair dryer 1-2 min before turning on tv
May 28, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
42PF9630A 42
ssb:pnx2015 stby &control
b4e
7j00-5\pnx2015
STBY CPU
1LA0\16MB
X840GA
May 22, 2008 | Philips 42PF9630A 42 in. Plasma Television
MAGNAVOX 51MP6200D/37
You will have to give the set out for service. This is not something you can service yourself.
This can be some failed components in the CRT bias and drive circuits, or maybe a CRT has failed. This has to be determined by taking measurements and doing some tests.
I believe that your set may have been manufactured by Philips.
Philips Support:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=51MP6200D%2F37&session=20080214101141_66.249.66.131&slg=ENG
Jerry G.
Apr 16, 2008 | Philips Magnavox 27MS343S 27" TV
SONY TV KEEPS TURNING ITSELF OFF!!
Its the BULB people! You need to change it every 3 to 5 years! I have had my sony 55" for 6 years... I had Best Buy come out 3 years ago, changed the bulb... it worked fine. Just started flasshing and shut its self off and back on again. Time for another bulb.
May 23, 2007 | Sony KV-28FX60 28" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
93 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
