Question about HP Photosmart C4150 All-In-One InkJet Printer
False Paper Jam on HP C4150
No physical paper jam in machine, (from HP website) tried pressing OK and Help keys at same time and also tried unplugging and replugging while holding OK and Help keys simultaneously. Neither have cleared the paper jam msg. Website then suggests "servicing your product". Is there anything left to do other than taking it to a repair shop (I'll just buy a new machine for almost the same amount of money)
Thanks
  • 4 more comments
  • lafespark Sep 18, 2008
    I have a 4150 which is two years old. Ever since new it has been an unmitigated disaster!! Always jamming up but no paper in it. We have opened it up as the display shows and can never find any paper. After several tries; shutting it off; letting it rest and facing east and bowing to it, it will reluctantly print one or even TWO pages before it goes south on us again. Does anyone have a solution for this piece of junk? Now it has given up on the paper jam message and says we have no cartridges installed even though they are both in place and full of ink! It is not worth the cost of a repair visit or even the cost of sending it back to HP.
  • Anonymous Sep 18, 2008
    I as well have a false paper Jam on Hp C4150. I have an e-mail in to HP. No doubt this is an ongoing problem.
  • Anonymous Dec 01, 2008
    printwe instruct to clear paper jam from back side but thrie is no paper in th epath
  • zebpooh Feb 26, 2009
    I also have the clear paper jam message, have also tried holding the "ok" and help key with no luck. Someone help?
  • kwadhams Apr 09, 2009
    False jam on HPc4150 I tried the help and ok button.
  • LostAP Apr 22, 2009
    No paper stuck in printer, tried restarting, used techniques outlined in website and in online chat function, only option left is to take it in. Does anyone know how to manually fix it?
1) UNPLUG IT FIRST ... then take off the left side cover ... the envelope thing comes off by squeezing the lock tabs in slightly (they are on top and bottom off the envelope thingy near the front and you can just see the slots of the lock tab when you open it up ... press in the middle of the slots ... press the top one down while opening ... and bottom one up). Now you should be able to remove it and see two torx screws ... remove them and remove the cover.
2) You will see a few large gears and a clear plastic disc with some numbers on it. Gently turn the gear closest to the front corner of the printer ... the clear disc should turn too ... but if it doesn't, this is likely your problem. If it doesn't turn with the other gears, gently turn it at the same time you are turning the gears to free it. After it turns with the gears, align the square to the bottom.
3) Finally, slide the printer cartridges to the center of the printer carriage.
4) Now put it all back together and try it.
Posted on Aug 02, 2009
  • benqfan17
    benqfan17 Jan 26, 2012
    That Worked!!! Awesome, Thanks so much, justmethree!!
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
Paper jam message
Is any of the buttons on your printer flashing?
you might have a cartridge problem
Mar 04, 2010 | HP Photosmart C4150 All-In-One InkJet...
HP 2575 printer - paper jam message
Resetting the product may help with some false error messages. Press power button to turn printer off, unplug the power cord, wait a few seconds, plug it back in, press power button to turn printer back on. Any luck?
Dec 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
How can I fix a paper jam on HP OfficeJet 4580
hi,
Paper jam messages can be true or false. The product might report a paper jam when there is not any paper jam. The following steps resolve both true and false paper jam messages.
this link will help you out:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01368841&cc=us&lc=en&dlc=en&product=3645100
thank you for using fixya,rate my answer
vijay
Oct 05, 2009 | HP OfficeJet J4580 All-In-One Laser...
C4150 Is stuck on or continues to repeat out of paper
probably you have jam paper check if the printer do not have paper on it or go control
panel and delete the printer and then installed again
Aug 15, 2009 | HP Photosmart C4150 All-In-One InkJet...
My HP PHotosmart C4150 is reporting a carriage jam. I have removed all paper , opened the door, and reclosed it. It is not working. I cannot see any carriage jam.
Hi
Please see this link from HP, and check how to clear the carriage jam(link includes the pictures aswell)--
HP Photosmart C4150 Carriage jam Troubleshooting
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | HP Office Equipment & Supplies
Paper jam but nothing inside
taking it to the service center is much advisable as there is a sensor which detects the paper in the printer is either moved from its position or broken so this error is showing.
Nov 01, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp photosmart c4180 - phantom paper jam
Had the same paper jam problem. Opened the LHS panel what Mitryp had suggested but just with a light push of the clear wheel back to its place and it worked perfectly. No glue was applied. Make sure you don't mess with the sensa.
(See best solution above for detail on how to open the LHS panel)
Sep 19, 2007 | HP PhotoSmart C4180 All-in-One Color...
HP Photosmart C4150 All-In-One InkJet Printer Logo
889 people viewed this question
Seeker5211
Seeker5211
