Question about HP Office Equipment & Supplies
Cannot print photos from photo tray. automatic paper sensor failed.
  • HP Master
  • 6,487 Answers
It sounds like your regular paper area is your default (which is the standard setting). To change so that is prints from the photo paper tray, once you hit print, go into the (usually third) drop down menu (usually says Copies & Pages). Go into the summary menu, and you should be able to expand all of the various options.
Depending on which OS you have , either with the paper quality and type settings or the duplex settings, you should be able to select the tray the paper is in. Just click on the photo paper tray.
Another fast trick is to make sure that the paper is all the way into the tray so that the tray can "sense" it
Hope that helps........
Posted on Jul 06, 2008
    Sergeant:
  • 275 Answers
If your automatic paper sensor is failed then you have to do repairing by taking it to a repairing center. if it is under warranty period then you can do servicing for free.
http://welcome.hp.com/country/us/en/contact_us.html
  • 689 Answers
Make sure there is no paper pieces left inside the printer. Change the paper orientation. Reset the printer. If issue persist please post. Include your Printer's model number and the photo paper size/type that you are using.
  • HP Master
  • 13,433 Answers
Issue An Automatic paper sensor failed. error message displays on the printer screen when the paper sensor is obstructed or damaged. Solution Follow the steps below to resolve this issue.
  1. Move the printer out of direct sunlight.
  2. Press the OK button.
  3. Try printing again.
  • Ekse Jul 06, 2008
    If the problem is not solved, unplug the device for a while, make sure its not in sunlight. let it be for a hour or two. If the same error comes up you have to take the printer in for service.
    If you have warranty, repairs should be free.
  • Ekse Jul 06, 2008
    also check that noting is obstructing the sensors, you can also attempt to clean them.
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100 All-in-One
Just click below;
Set Up the Printer Hardware
Remove packing materials, check contents of the box, connect the power cord, set the menus, load paper, and install the print cartridges. s.gif » Product Specifications
Minimum system requirements, connectivity, print cartridges, specifications for print, copy, paper, print margins, paper tray capacity, memory card, scan, physical size, power, and ... s.gif » Printing Instructions for 4 x 12 and 5 x 7 Inch Paper
Generic printing instructions. s.gif » Creating Borderless Photo Prints with the HP All-in-One Software
... 4 by 6-inch photo paper with tab (snapshot paper) ... Remove the paper from the paper tray and load the snapshot paper. Insert tabbed paper with the perforated, tear-off ... Click Photo Prints . The HP Photo Prints window will appear. ..
hope this may help;
Regards,
VOTIT
Jul 31, 2008 | HP Photosmart C6100 All-In-One Printer
I can't get my hp photosmart printer to print photos from my hard drive onto the photo paper. It will print the photos from the paper tray.
You have to shift the paper tray. Click on start, click on printer/faxes right click click on your printer, click on printer preferences, select photo printing borderless. This shifts your paper tray to photo paper.
Dec 20, 2010 | Computers & Internet
Trying to print photos from the photo tray. I can't find any place to select the photo tray. I've selected Photo and PhotoL paper, but it keeps printing from the main tray. Using Win 7 and driver...
pull out the paper tray. depress the blue button located to the right of the photo paper insert slot and slide the entire top section of the paper tray forward until it latches into place. be sure to place your photo paper finish side down. the printer will automatically recognize the paper size and select it for you by default. i assure you this will solve your problem. heres a link to the manual. the illistrations you need are located in chapter 2 page 13 and 14. please leave a testimonial on my page to show appreciation. thanks.
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_495CW_EN_1855.PDF
Dec 18, 2010 | Brother MFC495CW
HP photosmart 8250 wont print from photo tray.
Follow these steps in the order presented to resolve the issue. Step one: Reset the product
  1. While the product is still on, disconnect the power cord from the back of the product.
  2. Wait 30 seconds, and then plug the power cord into the back of the product.
  3. If the product does not automatically turn on, press the On (c01453128.gif ) button.
Step two: Check the condition of the paper and reload it
  1. Lift the photo tray lid.
  2. Slide the paper width guide all the way to the left.
  3. Remove the paper from the tray.
  4. Replace any ripped, dusty, wrinkled, or bent paper.
  5. Make sure that the stack of paper contains only one type of paper.
  6. Tap the paper stack on a flat surface to align the edges.
  7. Load photo paper with the print side down and short edge first into the photo tray. Slide the stack of photo paper forward until it stops. NOTE: If the photo paper has perforated tabs, load the photo paper so that the tabs are facing away from the product.
  8. Slide the paper width guide snugly against the paper. NOTE: Do not overload the photo tray. Make sure the stack of photo paper fits within the photo tray and is no higher than the top of the paper width guide.
  9. Lower the photo tray lid.
  10. Extend the paper catch.
  11. Try to print the job one more time.
  • If these steps resolved the issue , there is no need to continue troubleshooting.
  • If the issue persists , see the next step.
Step three: Choose the photo tray in the print driver settings
  1. Open the document to print.
  2. Click File , and then click Print . The Print window opens.
  3. Click Properties . The Properties window opens.
  4. Click Printing Shortcuts , and then click the shortcut you want to use.
  5. From the Paper source drop down list, click the paper source.
  6. From the Size is drop down list, click the paper size.
  7. From the Type is drop down list, click the paper type.
  8. Click OK , and then click OK again to print the document.
  • If the issue persists , try the following Workaround.
Step four: Service the printer If you have completed all the steps listed above and are still experiencing a problem, service the product.
Sep 08, 2009 | HP Photosmart 8250 InkJet Printer
Smaller items will only feed crookedly into the printer document
Check to see if you are feeding the envelopes and 4x6 cards/photo paper correctly.
Both envelopes and 4x6 cards must be loaded and centered on the paper exit tray (not inside the paper input tray).
Printing envelopes:
  • Up to 15 envelopes can be loaded at a time.
  • The print side of the envelope faces down.
  • The envelopesare centered on the paper exit tray.
  • You print the envelopes with Landscape orientation.
Printing cards:
  • Up to 35 greeting cards, index cards, postcards, or photo cardscan be loaded at a time.
  • The print side of the cards faces down.
  • The cards are centered on the paper exit tray.
  • You select Automatic, Normal, or Photo print quality.
For images on how to correctly load the paper, download your printer user's guide:
http://support.dell.com/support/edocs/systems/prn946/en/index.htm
Aug 16, 2009 | Dell 946 All-In-One InkJet Printer
Will not print photo from main tray
The printer will automatically select the "Print Quality" Media based on its driver settings or the device settings.
You will need to access the properties of your printers software to assure that you have selected photo paper for the tray you wish.
Depending on which model of printer your using, you may have to access the Settings/Options/Page Setup/Tray Setup Menu. Consult your Owners Manual for settings these Tray options. Make sure you have set the tray you wish for Photo Paper (or comparable quality option)
Let us know
Good luck
Apr 14, 2009 | HP Media Center m7250n (ED842AA) PC...
Printing from the photo tray
I have found that when you put the photo paper in to the photo tray you have to slide the photo paper in to the printer gently as far as it will go, then slide the side and rear guides to the photo paper. If you just put the photo paper in to photo tray without doing this, the printer will not take up the photo paper at all.
Nov 01, 2008 | HP PhotoSmart 7760 InkJet Printer
The photo tray
Go to printer then right click and select printer preferences. Under the tab features make sure beside paper source it says select automatically
Oct 30, 2008 | HP Photosmart C6280 Printer
74 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
