Question about Panasonic Televison & Video
I have a DVD burner/Video Recorder by Panasonic and one day after working fine the DVD drive won't recognize ANY media - it even thinks that there's a DVD in there when there isn't! It would cost me about what a new one would to fix and it's 2 years old anyway. So - is there ANY way that I could tinker with it to see if I can get it working again? I even tried dust-off to see if something was covering a sensor.....
  • 1 more comment
  • spgreenfield Jul 06, 2008
    This is a Panasonic DMR-ES46V. I have tried rebooting it, unplugging it, all kinds of media both blank and pre-recorded - even the RAM disk that came with it - nothing works. It makes 3 high hums and one low one (which it's never ever done before) and then that same sequence once again - then says the disk is unreadable - even when the drive is empty. SOMETHING has to be in there!!????
    That would be great IF it would even recognize that DVD cleaner!!!!!!!!!!!
    Already attempted to use a cleaning disk - sorry forgot to add that in my original post. It won't even recognize that there is a DVD of ANY KIND inside it!!!!!!!!
    Sergeant:
  • 275 Answers
Your dvd lens power is weak or may be faulty so it need replacement. if your dvd is under warranty period then it can be replaced for free of cost.
check your dvd manufacturer website for support
http://www2.panasonic.com/consumer-electronics/support
Posted on Jul 06, 2008
  • 6,487 Answers
You can try first using a CD cleaner to clean the optics of it, then if still doesn't work you can try updating the firmware of it if there's any available one from the manufacturer..
Hope that helps........
  • Mark Gil
    Mark Gil Jul 06, 2008
    Ok so go ahead and check for a firmware update for this device on your manufacturer's web site..
  • Mark Gil
    There's really a possibilty that the optics of this device is already damage if you already update the firmware if there is you need to replace the unit now....
    Good luck....
Panasonic DVD Recorder DMR-EZ48VEB. Colour missing
I have a Panasonic DMR EH50 DVD recorder and have just discovered this evening that everything on it is displayed in Black & White (tuner, recordings, menu, dvds etc). Yesterday everything was working in full colour. I have checked all my leads and have no solution to this problem and also need help.
Jan 03, 2010 | Panasonic Televison & Video
Panasonic DMR-EH75V DVD Recorder
What a story ! Clean your laser eye with Rubbing Alcohol and a Q-Tip. Down updates to your Recorder from Panasonics Website., and install in your Recorder. Order your replacement parts from Panasonic but I do doubt you will need them.
Jun 03, 2009 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Line Of Distortion Along The Bottom of an Em20 Burned Disc
It's possible there is either a codec problem with your computer player. I would recommend trying a player such as VLC Media Player, to see if that works. If that isn't it, what kind of TV's are you watching the video on? Are they "tubed" or flat screen? If they are tubed, you wouldn't be able to see the line at the bottom like you do when you play the video on the computer.
Jan 09, 2009 | Panasonic DMR-E20 DVD Recorder
Pinnale Dazzle DVD recorder doesn't recognize VCR
On the start up of the instant DVD recorder program, you can either use the "let the wizard guide you" or "advance mode"
1. Select source:
you should select the options:
Video standard NTSC (Because this is the default in our region)
Video composite - if you are using RCA (red, yellow and white cables)
S-video - if you are using the cable with several pins in it.
2. Select Burner
You should select the options:
Hard disc folder - if you will be saving the content in your hard drive, the format of this files are DVD such as VOB and IFO etc.
TSST - _ _ _ _ - if you will selecting your DVD drive.
(If you have selected your DVD Burner and you cannot click "next" to proceed to the Third option,
this means that your DVD drive is not able to burn a DVD)
3. Select menus
It must be NO
4. Recording
select total recording time (make sure that dazzle is selected in the "select source" to set the total recording time)
Dec 09, 2008 | Pinnacle Dazzle DVD Recorder
"NO READ" on Panasonic DMR-EZ27 DVD Recorder
This is the most common problem, in most cases the burner must be replaced.
May 03, 2017 | Panasonic DMR-E80H DVD Recorder
ekimt,
Yes, it would not recognize any type of disc. The disc icon was always present on the display even though no disc was inserted. Also, mine went out while recording from HDD to DVD. Panasonic had mine repaired in two business days and it' s working great.
mjs8
Aug 04, 2008 | Panasonic Diga DMR-EH75V DVD...
Drive won't recognize discs
the blank media must be compatible with the burner drive that you're using... meaning if the drive is for CD-R you can only use CD-R blanks not CD+R. if the drive is CD-/+R then you can use either CD-R or CD+R
May 30, 2008 | Panasonic LF D311SC DVD-RAM/DVD-R Burner
I have the same unit and luckily there is a service center here in dallas tx called bayard electronics. I just dropped mine off there. check out the website at www.bayardelectronics.com
Mar 29, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Will not play dvd video
I have a Samsung DVD writer model SE-S184. At one time, it worked fine. Then, for some unknown reason, it stopped playing my DVDs. Can anyone help me with a solution.
dvarmstrn@gmail.com
Apr 03, 2007 | Panasonic DMR-E85H DVD Recorder
Televison & Video Logo
15 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
