Question about DeLonghi Pinguino PAC-02 Air Conditioner
Pinguino pac-166 not cooling enough
Hi
i have this pac-166 ac it cools but not enough it is 9000 btu and room size 10 by 12 foot .
i called the technician from delonghi last year he said its good room is too big he did not paid any attention now my warranty is over so need some suggestions.
i open covers high pressure line get very hot and low pressure is cold too i put temperature Gage on the grill it shows about 17 Celsius.
  • 1 more comment
  • malhotraaman Jul 06, 2008
    i cleaned my filters and blower is working fine but still same problem not cool enough.
    need for help suggestions.
    thanks
    aman
  • malhotraaman Jul 07, 2008
    Hi
    Fan is working fine, i cleaned dust filter (they are two in the back side of the unit).
    compressor is very hot,highi pressure line very hot condenser coil is hot and blowing hot air.
    low pressure line is cold the cooling coil is not freezing but cold.
    so some thing is missing that's why its not cooling enough(room is normal size no air leak) .
    need suggestions please
    thanks
    aman
    it is 3 years old . there is a new substitute for R-22 which is made by Red-Tek 22A they claim it is good any suggestions on it.i found high pressure filler valve but cannot find low pressure filler valve.filler valve fitting looks diffrent then Central ac need more suggestions.
    thanks
    aman
    Sergeant:
    Champion:
  • 330 Answers
CHECK AND CLEAN THE DUST FIELTER AND ALSO CHECK THE BLOWER THEN TRY IT
Posted on Jul 06, 2008
  • 2 more comments
  • Frank Chen Jul 06, 2008
    add freon
    Is the fan working?
  • Frank Chen Jul 07, 2008
    How long have you had this unit, maybe you need add freon R-22. you can not do it yourself, unless you have the tools and know how?
    Hi Aman,
    Is Red Tek 22A a stop leak feron? if it is , you can use.
    about the low pressure fitting, need to research, I am going to try to help you, if it's possible.
    Frank
How many btu
Btu's are no longer used as size measurement in air conditioners
it is now kvw
reference can be found on line but quickly
9000 btu is equal to 2.5 and 32000 btu is around 7.5
if you have a knowledgable salesman that is honest they will be able to convert the rates for you
Apr 12, 2015 | Heating & Cooling
Ok So We Bought This. But We Have A Problem Does It Take Water Or Not? Thats What I Need To Know! Please Help!
The DeLonghi PACA120E Portable Air Conditioner quickly cools rooms up to 400 square feet and comes equipped with several functions that make operation easy and low maintenance. Its 3 operating modes are supplemented with no-drip technology, an adjustable thermostat, 24-hour timer, and much more. This unit truly takes the work out of cooling medium- to large-sized spaces. Multiple Modes and Functions The DeLonghi A120E-also known as the Delonghi Pinguino PAC A120E-offers 3 operating modes and 3 additional operating functions that make this model versatile and energy efficient. Cool Mode: 12,000 BTUs of cooling power help cool large rooms, offices, or basements. Dry Mode: Reduce room humidity by removing excess moisture from the air. Fan Mode: Circulate air to keep your room comfortable without using a lot of energy. Low, medium, high, and an auto-speed are all included (auto speed selects a fan speed for you). Smart Function: Your AC uses Cool and Fan mode based on ambient room temperature. This function will also select your fan speed and keeps your room comfortable without wasting energy. Sleep Function: Using a low fan speed, the AC gradually reduces operation so your room remains comfortable but the AC runs more quietly and efficiently while you sleep. Boost Function: This function is ideal for the summer months and uses the maximum fan speed to rapidly reduce your room temperature. Useful Features Using DeLonghi's patented no-drip technology, this unit is "dripless" under normal conditions, meaning the AC will discharge all of the moisture collected from the air-so you typically won't have to worry about draining the water. When dehumidifying a lot of moisture in Dry mode, excess water may collect in the internal collection tank. Once the tank is full, the air conditioner will automatically turn off to avoid overflow damage. You can also use the included continuous drain hose as a no-fuss way to eliminate excess water as needed. An adjustable thermostat provides additional convenience by allowing you to set your room temperature. The DeLonghi portable AC will cycle on and off to eliminate over-cooling and maintain the set temperature. Additional Features Washable Air Filter: A washable air filter helps remove allergens and other particles from incoming air and saves you money on replacement filters. Quiet Operation: High efficiency compressor and components result in quiet performance. Electronic Controls: The LCD screen displays the timer and temperature settings, while intuitive indicator lights accompany each operating mode. 24-Hour Timer: This feature lets you program your AC to turn on or off up to 24 hours in advance, so it only runs when needed. Window Bracket: Double window bracket is included with purchase for flexible installation. Self-Diagnosis System: The unit includes a self-diagnostic maintenance system that identifies malfunctions should they occur. Remote Control: Use the full-featured remote control to change modes, set the timer, and select a fan speed up to 23 feet away from the receiver (on the front of the unit). Portability: Easy-roll casters and dual carrying handles make it simple to move this model from space to space.
Aug 06, 2012 | DeLonghi PAC A120E 12000 BTU Portable Air...
I do not have the exhaust hose for my AC. Should I not run the AC since it is blowing hot air into the room as well as cool?
No you should not because it is counterproductive. You can always purchase a new exhaust hose at your local hardware store!!!
Aug 10, 2011 | DeLonghi Pinguino PAC-210 Air Conditioner
My delonghi pinguino pacl17 does not cool enough, doyou have a telephone number i canreach you. It only cools to 64 and its not cooling enough,
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Aug 27, 2010 | DeLonghi Pinguino PAC-GSRU Air Conditioner
Delonghi pac260 ac unit blowing hot air
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 21, 2010 | DeLonghi Pinguino PAC-260 Air Conditioner
DeLonghi Pinguino PAC CT90 It is less than a year has quit coolin
Read instructions and see if it says anything about cleaning or filters. A.C units **** air in and there is a filter that probably needs cleaned.Also,while cooling, the vent to the outside should put out warm air. Also, if it is less than a year old, contact the manufacturer and they should help you out. Good luck.
Feb 13, 2010 | DeLonghi Pinguino PACL90 Portable Air...
Our air conditoner is throwing out cold air but the room is very hot the fan is blowing out cold air too it is not cooling the room down.
sounds like it does not have enough BTUs
so many BTUs can cool somany cu-feet if sealed space
Like leaving the freezer door open too seal that room
Jul 31, 2009 | DeLonghi Pinguino PAC-290 Air Conditioner
Danby ALSO does not cool 3 days old
Take it back where you bought it. A 12,000 BTU unit should be more than enough for a 192 square foot room, so there is some problem with the unit.
Jul 10, 2009 | Danby Portable Air Conditioner
DeLonghi Pinguino PAC-02 Air Conditioner Logo
797 people viewed this question
Top DeLonghi Heating & Cooling Experts
paulcarew
Donni Steen
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
