Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1995 Harley Classic: problems starting....replaced part of the starter, not that. Replaced the battery, not that. What now???
    Genius:
  • 2,028 Answers
What is it doing exactly, when you try starting?
Posted on Aug 06, 2008
2007 FLHTCUI Ultra will not turn over
Hi, Davidbeer before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand, clutch, neutral safety switch.
9. Security alarm needs a reset.
10. Starter relay, solenoid, starter motor or circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. Faulty ignition relay.
14. The electric starter is working but starter clutch has failed.
15. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below and for more specific information or questions at no charge please feel free to contact me at xlch@mail.com. Good luck and have a wonderful day.
Ultra Classic won start no sound nothing Harley Davidson Forums
Harley Davidson Touring Workshop Service Repair Manual 2007 $10
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?make=hdmc
http://mybikemanuals.com/harley-davidson/007-harley-davidson-owners-manuals
Instant Tech Relief To speak to me personally absolutely "FREE"
Aug 27, 2017 | 2008 Harley Davidson FLHTCU Ultra Classic...
2001 Harley Davidson FLHTCUI Electra Glide Ultra Classic will not turn over
Hi, Danny great talking to you on 6ya, before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
Harley Davidson Touring Models Workshop Service Repair Manual 2001 $9 cheap
http://www.harley-davidson.com/content/h-d/en_US/home/owners/maintain-your-bike/owners-manual.html
Jul 17, 2017 | 2001 Harley Davidson FLHTCUI Electra Glide...
REMOVE STARTER SOLENOID 1995 HERITAGE SOFTAIL
The starter silinoid is connected to to starter and can't be replaced with out the starter itself when you buy a new starter it'll come with a new silinoid on it pretty expensive too
May 21, 2014 | 2000 Harley Davidson FLSTC Heritage...
1986 harley electriglide classic start starts slow if doesnot start i hear something release from starter or solinoid
First make sure your battery is fully charged & your gas is good but it sounds as tho you have a bad starter solenoid or bad battery cable or loose connections at the battery itself.
Apr 18, 2014 | 2003 Harley Davidson FLHTC Electra Glide...
1985 fxst starter problem
Hi Anonymous, try replacing starter relay. Good luck
Jul 02, 2013 | 2000 Harley Davidson FLSTC Heritage...
Diagnosing starter problems with 1995 heritage softail classic won't start, charged battery- now no power when I turn ignition on
Hi Anonymous, and the usual suspects are:
1.Ignition/Light Key Switch not in IGNITION position.
2.Engine Stop switch in the OFF position.
3.Discharged battery, loose or corroded connections (solenoid chatters).
4. Bank Angle Sensor tripped and Ignition/Light Key Switch not cycled to Off and then back to Ignition
5. Starter control circuit, relay or solenoid faulty.
6. Electric starter shaft pinion gear not engaging or over-running clutch slipping.
May 06, 2012 | 2000 Harley Davidson FLSTC Heritage...
1995 HD Heritage Softail Classic ,Starter when i push the start button i get a silinoid Click sound i repaced relay switch could it be the jack shaft seal i just replaced the seals on the inner primery...
Hi Anonymous, first when checking anything in the starter circuit you must make sure the battery connections are clean and tight especially the negative cable at both ends and has a 12.5 volt or better charge. It must not fall below 9 volts during the cranking procedure with a volt meter hooked up. If it does fall below 9 volts do a proper load test on the battery and replace if necessary. Second replace the starter relay cheap $6 and make sure it's well grounded and getting 11.5 volts or better to activate. Third remove the back cover of the starter solenoid and de-arc/refurbish the contact plate and shoes making sure they are tight. If it still chatters replace the solenoid. Good luck and have nice day.
Apr 22, 2012 | 2000 Harley Davidson FLHTCUI Electra Glide...
MY 1995 BY CAPRICE CLASSIC WILL START BUT WON'T STAY RUNNING
The fuel pump is shorting out,replace the fuel pump in the tank to repair the problem.
Apr 06, 2010 | 1995 Chevrolet Caprice Classic
Replaced battery. engine will not crank. 2003 harley
Sounds like your starter relay under your seat. take a jumper wire from your batter positive to the starter you will be touching the large copper stud under the rubber grommet. if the motor kicks in its your starter relay,
Jul 14, 2009 | 2000 Harley Davidson FLSTC Heritage...
Lands Phones Logo
256 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
